Old 10-03-2016, 09:03 AM   #1
2016 26' Flying Cloud
2011 25' FB Flying Cloud
reno , Nevada
As winter is almost here, its time to winterize...Any ideas on the easiest way
to get this done? I will probably be using it a couple of times during the winter, so I will have to do it multiple times.
Thanx for any help.
jomondnv is offline   Reply With Quote
Old 10-03-2016, 10:11 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
More than one way to skin the cat but this is what I do:
1. Drain the tanks, lines and low point drains
2. Use the water pump inlet to pump RV antifreeze. (kit makes this easy)
3. Open faucets till antifreeze comes out, pour a little in sink and shower drains
4. Water heater bypass will save you a lot of time, and work
Old 10-03-2016, 05:49 PM   #3
LilBigfoot's Avatar
London , Ontario
You'll need to add this water heater by-pass kit from Camco. Installs on your pump connections. Will suck the RV Anti Freeze through the system. It was an easy mod for me....I did have to raise up the pump about 1/2" to clear the bottom board...see post 84
Then read from post 135 as Kaunut had a bit of a work around.
You're a long time underground!
LilBigfoot is offline   Reply With Quote
winterizing tips for 1971 Safari frydmans Winterizing, Storage, Carports & Covers 9 11-25-2002 06:50 PM
Winterizing question PatCrusse Our Community 15 11-14-2002 12:08 PM
Winterizing and stuff Curtis-79MH Airstream Motorhome Forums 2 10-03-2002 09:27 AM
What can happen w/o Winterizing Craig Plumbing - Systems & Fixtures 1 09-23-2002 09:10 PM
Air pressure for winterizing montanaandy Winterizing, Storage, Carports & Covers 10 09-23-2002 05:13 PM
Copyright 2002-2015 Social Knowledge, LLC All Rights Reserved.
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
