Old 02-07-2013, 12:42 AM   #1
Wild Robot's Avatar
Washington , D.C.
Why the hitch weight difference?
This has been bugging me for about a week. Why the difference in hitch weights between the 23D at 720lbs and the 23FB at 467lbs?
Is the furnace heavier on the 23D or something? Heck I don't even know if a 25,000 BTU furnace is much heavier than an 18,000 unit but the specs are so close in every category but that one.
Wild Robot is offline   Reply With Quote
Old 02-07-2013, 01:37 AM   #2
RUMSHIP's Avatar
1988 32' Excella
Bonita , California
Images: 16
I would guess its the floor plan layout with what is front of the axles.
Happiness only real when shared.
Christopher Johnson McCandless
2/12/68 - 8/18/92
RUMSHIP is offline   Reply With Quote
Old 02-07-2013, 05:18 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Could be the location of the freshwater and holding tanks, if they're different between the two models. Tanks behind the axles act as a counterweight and reduce tongue weight. Tanks in front of the axles add to tongue weight.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 02-07-2013, 05:35 AM   #4
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
It is all about layout and corresponding loading due to equipment location.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 02-07-2013, 09:41 AM   #5
1988 32' Excella
Robbinsville , New Jersey
The 23FB is 9" longer then the 23D and might have a different axle placement, as in the extra 9" is behind the axle.
Old 02-07-2013, 11:05 PM   #6
Wild Robot's Avatar
Washington , D.C.
Thanks for the responses.
I'm almost of the mind that either configuration would work for me. The lower tongue is somewhat appealing. Still trying to sort out the tow vehicle. This is not going as fast as I thought. <chuckle> Oh well, I will just take my time.
Old 02-08-2013, 04:35 AM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Be advised.....
....the published tongue weights are just "guesstimates"....add 300-400lbs to be safe.
Published----860#
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 02-11-2013, 12:12 AM   #8
Wild Robot's Avatar
Washington , D.C.
Geez, "guesstimates"? Really? Ugh...I generally err on the side of safety but this is pushing me into BAT (BigAssTruck) territory and that's not where I want to be.
Old 02-11-2013, 12:20 AM   #9
RUMSHIP's Avatar
1988 32' Excella
Bonita , California
Images: 16
Relax, you don't need a big ass truck to pull a 23' trailer. A jeep grand Cherokee will do fine. Maybe a 1/2 ton truck of your choice if you need the cargo space.
2/12/68 - 8/18/92
Old 02-11-2013, 12:46 AM   #10
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Dear Wild - consider the importance of loading your A/S efficiently... and camping LEAN. Don't carry outdoor furniture that you never use, do you really need 2 televisions in a 23 foot trailer? THINK before you buy and load onto the trailer!
I have had to admit I have the hoarding gene... and periodically purge my stuff. No one needs 25 blouses and T-shirts, but I had that many until last weekend, just bought 2 threw away one for too long. And kitchen stuff, and cleaning stuff, and brooms and and and.... I didn't weigh what I donated and threw away but it was probably well over 100 lbs. And I fulltime, so I do need to carry more than the "weekend camper."
If you travel with all tanks full - even with 20 gallon black, white and gray, you're adding almost 500 lbs to the gross weight of the trailer, and most of that will usually be tongue weight.
A half ton truck will do fine for a 23 footer! Paula
Old 02-11-2013, 10:23 PM   #11
Wild Robot's Avatar
Washington , D.C.
Thanks for the feedback folks.
I'm thinking I really need to think of tongue weight a lot more now, that's why I'm feeling pushed toward the heavier duty trucks. For some reason I have visions of the rear suspension crashing into the ground on day one.
I don't really have the hoarding gene (chuckle) as I'm a bit of a minimalist to start with, but I'm notorious for my 'what if' gene. LOL
The new diesel Cherokee is high on my list. I'm a photographer so I do need something with decent cargo space that I can use for work when the trailer is not attached. LOVE the Odyssey, too bad it can't tow much of anything.
Old 02-13-2013, 01:07 PM   #12
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I have weighed my tongue with the Sherline scale and it really varies with what I've loaded. Found it interesting when I was researching models that my 28 has a higher tongue weight than the 30' same year/same model. So, it's about the way they place stuff. Has to be it!
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 02-16-2013, 06:50 PM   #13
2011 23' Flying Cloud
Durango , Colorado
Wild,
My 201123FB tongue weight is an actual 785 lbs with propane and water tanks full, waste tanks empty and 'normal' camping load. Can't imagine where Airstream got the 467 lbs that they list for this unit. The good news is that my 08 Jeep GC Diesel tows her just fine with a 10K Equalizer. I'm also holding out for the new GC Diesel.
Safe Travels,
Joe & Joan Donnaway
Durango, CO
JamuJoe is offline   Reply With Quote
Old 02-16-2013, 09:54 PM   #14
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
What is the tongue weight of a 23D with a "normal" camping load? If the 23FB is 785lbs is the 23D 1000lbs?
Kelvin
