Old 10-26-2010, 05:08 PM   #15
2011 27' FB Flying Cloud
Bradenton and Saluda , Florida & North Carolina
Hi Pat,
Well it seems to be a consensus that the direct sun heats up the panels and like anything causes expansion and contraction in doing so. As it heats up you get a dimple, when it cools it goes away. This seems to be localized to longer trailers that have more space exposed between windows, etc.
I am planning on getting the awning package installed spring/summer next year, so this should take care of the sides.
If you have heard your trailer popping, and we all have, this is the expansion and contraction.
Airstream and others have all said the same thing.
I will post pics when I get the trailer in a couple weeks.
ncbambi is offline   Reply With Quote
Old 10-27-2010, 08:31 AM   #16
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Originally Posted by ncbambi View Post
Hi Pat,
The awning package will reduce, not eliminate the puckering.
Michelle TAC MT-0
Sarah, Snowball
Old 10-27-2010, 09:18 AM   #17
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
You'll love the awning package. Not only functional, but I think they are really dressy. As for the pucker, it's natural and nothing to be concerned about.
I don't think I remember hearing popping, but if I did, I probably dismissed it as being heat-related.
I bet you can't wait, either. I'd be about to bust.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 10-27-2010, 05:37 PM   #18
2004 22' International CCD
2011 25' FB Flying Cloud
South of Fort Worth , Texas
After my trailer is exposed to 100+ degrees temperature, then running the AC, I hear a lot of popping as well. This is normal under this circumstance and eventually stops. I haven’t noticed any exterior puckering.
Airstreamer@ is offline   Reply With Quote
Old 10-27-2010, 09:22 PM   #19
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
For what it's worth, my 77 31 footer has had a noticeable pucker in that same location since it was new and a smaller pucker just aft of the wheel well. They do not go away or get larger in the heat. I've had it checked for frame sag and the frame is fine. I call them the mother pucker and little pucker.
4RXLA is offline   Reply With Quote
Old 03-25-2011, 03:58 PM   #20
AlanMcD's Avatar
Cincinnati , Ohio
Skin Ripple On One Side
Check out the side pics of this 2010 Flying Cloud. What is causing this whole side to ripple like this and not the other side?
Airstream 2010 25 FB FLYING CLOUD TWIN BEDS
AlanMcD is offline   Reply With Quote
Old 03-25-2011, 04:07 PM   #21
CanoeStream's Avatar
St. Cloud , Minnesota
There's nothing there that concerns me. It looks like the Airstream was pulled up next to a ridged-metal industrial or pole building (that's the vertical lines you see). The window frames to the right of the door & the stove vent pulled the skin tight to the frame. That pulled in the skin a bit more and that's the sole reason that the reflected sheet metal ridges are distorted IMO. I would particularly question what was happening if this if it was occurring aft of the wheel wells.
5 meter Langford Nahanni
Old 03-25-2011, 04:10 PM   #22
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I think that's just the usual shape of the skin around various vents and rivets and such, but it looks really weird because there's a metal building behind the camera being reflected off the side of the shiny new trailer, and the vertical lines of the panels on the metal building are really showing the fun-house-mirror effect off the FC's skin.
Old 03-25-2011, 04:45 PM   #23
AlanMcD's Avatar
Cincinnati , Ohio
You're right! It's the reflection of the building.
-Alan
Old 03-29-2011, 05:46 PM   #24
I think I would be more concerned about the buckling in the glass!!!
Old 03-29-2011, 05:58 PM   #25
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
After a half dozen Pinacoladas I see lots of ripples and buckling...
Old 06-15-2011, 12:45 PM   #26
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
I've never seen anything like that in ours. We've been in temps up to at least 106˚. Surely expansion and contraction have effects, but why would some trailers do that and others do not?
I think there's something different in the workmanship when they were built. Considering that different workers do things differently and over the years there have been complaints about workmanship by some people and not by others, it could have to do with who built what on what day.
Gene
Old 06-15-2011, 06:04 PM   #27
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I have the same concerns as Gene, why are other AS in the same climate conditions not effected.
Never noticed anything like that, but why would you even be looking for it?
It's not something that is likely to "self repair".
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Shiny Trailer Caused Fire Lucky 13 Cleaning, Stripping & Polishing 11 09-12-2010 06:55 PM
Vibration caused by the highway gil Morris Member Introductions 18 05-29-2006 05:36 PM
Changes that caused some errors... Andy R Forum Admin, News and Member Account Info 0 08-28-2004 05:48 PM
Urgent: frame damage caused by improper jacking? Rog0525 1969-1971 Caravel 39 03-31-2004 05:35 PM
