I was just reading my owners manual and if I'm reading correctly I should have a "remote water pump switch" on the bathroom wall. For the life of me I can't locate it. I do see the switch for lighting the hot water heater.
Are there owners of the same model as mine that has a remote water pump switch? If so, where is it located?
My 2006 manual also says there is one on the bathroom wall, guess what, not one there. Mine is also on the wall above the galley sink on the monitor panel.
MICHAEL
You'd think they could have corrected that sometime in the last 14 years.
The manual has been wrong since at least my 2001. I posted the same question several months ago.
Al
2002 31' Classic
Monroe
, Iowa
My '02 31' Classic has one on the control panel and one clearly marked as "water pump" on the bathroom wall with the water heater switch and the bathroom fan switch. You can turn the pump on or off from either switch.
Sometimes Owner's Manuals are somewhat generic and cover many models. It wouldn't take too many more words to tell you just which models apply.
My 28' classic water pump switch in the bathroom stopped working. Used to be either the bathroom switch or the kitchen fan console could turn on the water pump. Now, the bathroom water pump switch will only turn on if the kitchen switch is set to on. Funny, though, I can turn off the water pump in the bathroom when he kitchen water pump switch is on. If the kitchen water pump switch is set to off, then the bathroom switch cannot turn on the water. Any ideas ? I tried changing the bathroom water pump
Switch to no avail.
2015 30' Flying Cloud
Evansville
, Indiana
My 2004 Land Yacht MH had two water pump switches, but the 2015 FC only has the one water pump switch at the monitor control panel I guess it was a "cost savings" move.
