Old 08-31-2016, 09:33 AM   #1
Water drip underneath
I have a small drip leak running underneath from rear to before wheel. Seams to be related to fresh or gray water tanks. Hard to tell with belly pan. I've been on a long road trip and road hazards may have loosened something. I have 20 ft Flying cloud 2014. Thanks in advance for any ideas. Diane S.
dsheridan is offline   Reply With Quote
Old 08-31-2016, 09:43 AM   #2
bigjohnn's Avatar
los lunas , New Mexico
Its your drain for your AC
bigjohnn is offline   Reply With Quote
Old 08-31-2016, 09:45 AM   #3
M. Smith's Avatar
2012 25' Flying Cloud
Tuttle , Oklahoma
I have a 2012 Flying Cloud that had a leak from the fresh water tank that sounds similar. Took it to dealership for repair. The low point drains are plumbed next to the pump pickup line, causing stress on the fitting, which caused the fitting to crack and leak. The dealership had to remove the fresh water tank to weld repair the cracked fitting. They replumbed the low point drains so they do not contact other lines and that should alleviate the stress problem.
If your fresh water tank is draining without your using it, that my be the problem. Or, as noted, it may be the drain from your air conditioner, which comes out a tube right behind the wheel.
M. Smith is offline   Reply With Quote
Old 08-31-2016, 09:49 AM   #4
Thanks M Smith. Seams similar to my problem.
Drip, drip, drip Skamper1 Fresh Water Systems 8 06-12-2010 06:33 PM
drip- drip-drip-drip-drip.... AIR-Quarius Furnaces, Heaters, Fireplaces & Air Conditioning 3 08-09-2009 07:32 AM
Arrggggg! Drip, Drip, Drip—Warning, plumbing questions Jim & Susan Sinks, Showers & Toilets 16 06-10-2009 08:04 PM
Drip, Drip, Drip kamadeca Fresh Water Systems 4 05-20-2008 08:22 PM
AC drip,drip,drip,drip,drip Canuks Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-02-2006 02:05 PM
