Old 01-11-2015, 12:02 PM   #1
2014 30' FB FC Bunk
Ventura , California
Walk through Checklist
Hi there, my husband and I are first time airstream owners. We just purchased a 2014 30' Flying Cloud Fb Bunk. We do our walk through inspection on Jan 20th. We wanted to know if there was a certain checklist we should have with us to make sure we go over every part of the coach. Thank you.
KTBug75 is offline   Reply With Quote
Old 01-11-2015, 02:14 PM   #2
Pat Cassity's Avatar
2015 27' FB International
Montgomery , Texas
KT, great question! We are currently on our third AS (not by choice by any means). My first suggestion is to find out if your dealer
has the ability to let you camp (with full hookups) in the packing lot, the first night. If so, try out everything. AC, heat pump,
furnace, Stove, oven, microwave, both TV's, etc... And , don't forget the shower, so you can check for leaks. Make sure your
Dealer explains how everything operates. Don't let them off the hook with anything. They love to assume you already know
how to operate a particular item and you'll end up getting home without knowing how to open or start something. Get a good
understanding of how to open and close your awning. Don't be surprised if the person giving you your walk through isn't
completely familiar with the way something operates. Again, don't let them off the hook. Have them find someone that does!
During your walk through, open all drawers and cabinets to insure that there are no problems. Raise and lower your shades and
inspect for rip, tears or stains. Yes, I have found them all! Turn all lights off and on. Make sure you understand the use of the
control panel for the fresh water, black water, grey water, and battery. The dealer should have put some water in your fresh water
tank, so check to make sure your your water pump is working correctly. Open and close your windows to make sure there are
no problems. Walk the outside and check to make sure that all storage doors and vent covers close properly. Check your
stabilizers to insure they open and close correctly. Inspect the aluminum all the way around the trailer for scratches and
excessive sealant around windows that was smeared on the aluminum at the factory. Be sure to make a list of all
problems as they are discovered. Have the dealer either fix all items before you leave, or if this not possible, set up an
appointment with the service department to address each item. Last but not least, if you are having a hitch installed,
observe the installation. Make sure that all bolts are tightened properly. Whatever you do, DO NOT assume they know what they
are doing. The TV and TT should be completely level during installation. If it is not, there is good possibility that the
specifications for installation mandated by the hitch manufacturer will not be adhered to! I hate to be to dramatic, but
your life and and that of your family and other motorists depend on that hitch being installed and set up correctly!
You are going to find problems. One would think that by spending close to $100,000 for anything, that you were buying
a flawless, perfect item. This is not the case. Many RV dealers are just like car dealers. They are the greatest people in the
world right up to the time that they get your money. After that....well you know the drill. My first AS was a complete lemon and
the dealer with Airstream's approval gave me a complete refund after two frustrating months. Good luck to you!
Retirement! Every day's a Saturday and Monday's no longer exist!
Pat Cassity is offline   Reply With Quote
Old 01-11-2015, 11:49 PM   #3
2014 30' FB FC Bunk
Pat, I can not thank you enough for this information. I am so overwhelmed right now. This gives me a starting point and I can not begin to tell you this is just the direction I was looking for. Take care.
Kate
Old 01-12-2015, 09:16 AM   #4
2016 30' Classic
Erie , Colorado
Also would suggest getting a creeper to take a look at the underbody. It is educational, you can find jack points and the like, but you may find areas where there are gaps in the sheet metal that were not properly sealed.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 01-12-2015, 11:50 AM   #5
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden , Colorado
The live in it for a day or two is a must if at all possible. If the dealer can not accommodate this on site ask them to arrange it at local campground etc..
Besides what has been said above.
Make sure they burn in the furnace at least a few hours twice over a two day period. This is a big one. If not you will spend two days in a smoke filled trailer the first time you need to use it.
This time of year they ship the trailers winterized and the dealers don't like to put fluids in. This you must insist on and then they need to re-winterize, if you live in a cold climate or will be traveling in the cold have them install the winterizing kit or you can also look at http://www.airforums.com/forums/f516...-a-127922.html.
Have them walk you through a complete winterize including the hot water heater bypass and drain.
Make sure they can connect the trailer to 50A power and run both zones in AC and HP modes. Check for function and vibrations/rattles.
Run the furnace and check inside and out for vibrations/rattles.
Check the UL carefully for stress cracks where drawn tight.
Look at all the cubby holes for bad interior trim or edge banding. It will undoubtedly need repairing.
Take a DVD with you for them to play in the player. Make sure all 3 TVs work and sound comes through the overhead speakers.
Run all the appliances in each mode (i.e. fridge on electric and gas, hot water heater electric and gas).
Look behind the toilet, sink, in all the cabinets everywhere you can for leaks and plumbing pinch/rub points etc..
Check the exterior stove vent as the plastic keeper arms came out the first time tried to use it. I have ordered a stainless steel replacement.
Look at the windows carefully inside and out for proper installation. I have seen a couple that were flat wrong.
Almost forgot, take pictures of the stupid stickers in the shower and have the dealer remove them. Also make sure the bottom of the shower looks new as mine was very dirty from others stepping into it with their shoes on. It still does not look that good.
The more time you spend in it and operating stuff the better off you will be.
Better to have them make all corrections before accepting it.
2012FB is offline   Reply With Quote
Old 01-12-2015, 10:54 PM   #6
2014 30' FB FC Bunk
2+ Years , Fulltime
We have that model that you are getting and everything that is mentioned here is great advice. It does seem a bit overwhelming but having things taken care of before getting it off the lot is always the easier route to go.
In our bunkhouse the shower in areas was poorly caulked which might be something to look for or maybe my guy was ready to leave for the day.
MO
mopillar is offline   Reply With Quote
Old 01-12-2015, 11:25 PM   #7
Len and Jeanne
Len n Jeanne's Avatar
2005 16' International CCD
2015 19' Flying Cloud
Creston Valley , British Columbia
Having been through this process 2x (and assuming you are buying through a dealer,) take copious notes as you go through absolutely everything, one item or system at a time. Your AS should come with a big instruction manual, but these seem more written for mechanics and electricians than ordinary Mom and Pop RVers. These notes proved more helpful than the manual with our previous AS.
I second camping on the dealership lot: in fact, our previous (Can-Am) and current (Airstream of Spokane) dealers requested that we do this. Your night should be on a weekday Monday-Thursday, such that (a) if there's a malfunction, or (b) you can't figure out how the heck to make something work, the mechanic is on duty the next morning to fix it or help you. If your next overnight is in a nearby campground, so much the better.
Your trailer is under warranty, so it's up to the dealer to fix anything that isn't as it should be.
How great to have a new Airstream! Happy Trails to you!
Len n Jeanne is offline   Reply With Quote
Old 01-13-2015, 05:25 AM   #8
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Video the entire walk thru, and ask all the 'dumb' questions you can think of...on tape.
Good Luck & have FUN!!!
TT Arrival Checklist & Departure Checklist Rocinante On The Road... 20 04-17-2017 09:11 AM
Enclosing a walk through bath Roadtoaster General Interior Topics 7 01-30-2011 05:01 PM
Picking up first trailer this month what do i look for during the final walk-through? @irstream Our Community 8 07-14-2007 12:10 AM
Mid bath as a walk through? malconium General Interior Topics 5 11-25-2004 07:32 PM
Walk through Wednesday, any suggestions for new owners? CaliforniaStreamin Buyer Guidelines 6 08-24-2004 01:46 PM
