Old 08-14-2015, 05:41 PM   #1
Senior Member
sheriff1's Avatar
2014 30' Flying Cloud
Sparks , Nevada
Vinyl flooring and laminate info?
Doing a remodel on our 2010 Flying Cloud 27FB and need to know what brand and color to finish the oak look flooring and I guess bamboo look cabinet laminate.
Thanks!
2015 F350 CC 4X4 6.7 Diesel
2010 27FB Silver Cloud "The Silver Spoon"
sheriff1 is offline   Reply With Quote
Old 08-15-2015, 05:10 AM   #2
Airstream12557's Avatar
2015 30' Flying Cloud
Evansville , Indiana
Consider solid cork tile flooring. Easy to cut, light weight, good insulator, flixible, renewable (green) product, and looks great. We had in our Airstream motorhome for about three years and loved it.
Airstream12557 is offline   Reply With Quote
Old 08-15-2015, 07:05 AM   #3
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Is solid cork a floating floor or is it glued down?
Is it resistant to water spills?
Does it resist expansion/contraction due to extremes in seasonal temperatures. That is the biggest issue with floors in RVs.
Kelvin
Old 08-15-2015, 07:14 AM   #4
carver 1's Avatar
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo , Florida
Images: 30
The newer Beau Flor roll vinyls are really nice and easy to install. Most everybody who sees ours, thinks that it is laminate or real wood.
>>ron<<
Name:	Airstream lounge new floor (4).JPG
ID:	245539   Click image for larger version
Name:	Airstream lounge new floor (12).JPG
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
carver 1 is offline   Reply With Quote
Old 08-15-2015, 05:42 PM   #5
gecko's Avatar
2009 28' International
Pacific Palisades , California
Rolled vinyl is neat. Easy to clean and care for, waterproof, and looks great. Almost everyone thinks that the "floating" vinyl "cork" floor in our 2009 28' Ocean Breeze is real cork. Can you post a before pic of your coach?
What are you planning for the remodel? Are you changing the decor or do you like it and just want to make it new? Are you doing the work yourself or hiring someone to do it?
gecko is offline   Reply With Quote
Old 08-15-2015, 06:05 PM   #6
Senior Member
sheriff1's Avatar
Sparks , Nevada
I'm actually looking to match the factory flooring. I just have a small area on the side to patch.
Old 08-17-2015, 05:13 AM   #7
Kelvin
Cork is naturally water resistant. The solid cork tiles are glued down with a water soluable contact cement. Cork does not have a high coefficient of termal expansion. In our 30 ft. Airstream Land Yacht motorhome, there were no visible signs of any expansion due to temperature extremes. We lived in the motorhome over the winter and after two winters, it showed no signs of wear. The manufacturer recomends recoating it with urethane when it needs refinished. We never felt it was needed on our floor. Cork, since it is flexible, takes the normal movement of the floor without a problem. I think it is an ideal floor for an RV.
Old 08-18-2015, 05:26 AM   #8
'15 Flying Loud 20' Bambi
renderit's Avatar
2014 16' Sport
small city outside a big one , south of some, north of some
I would like to know the Airstream actual choices as well. Everybody responding is ignoring the question. Mine is a 2015 with the dark green tabletops, is that what yours has? I've heard them call the wall and cabinet laminate "rice paper" and "Bambo". I'll try to find some Wilsonart chips, maybe it's theirs.
renderit is offline   Reply With Quote
Old 08-20-2015, 09:35 AM   #9
Senior Member
sheriff1's Avatar
Sparks , Nevada
Mine has the silver-grey laminate counters but I think all FCs have the same walls and floors. I'm going to check with the mother ship and will post what I find out.
Old 08-24-2015, 02:20 PM   #10
Senior Member
sheriff1's Avatar
Sparks , Nevada
http://www.airstream.com/wp-content/...gcloud2010.pdf
Everything you need to know for colors
Beauflor is brand of flooring.
Wilsonart is wall laminate. Just ordered some from Lowes.
Old 08-25-2015, 04:59 AM   #11
renderit's Avatar
2014 16' Sport
Awesome! I was not finding the rice paper even in the Wilsonart chips I was searching through. But then again, I have always suspected not all places carry all of them.
Old 08-25-2015, 09:07 AM   #12
Senior Member
sheriff1's Avatar
Sparks , Nevada
Wilsonart 4861K-07 Gold Alchemy
http://m.lowes.com/pd/Wilsonart-48-i...-Sheet/3493165
Laminate flooring over old VAT tiles? jadedacres Floor Finishes 16 07-24-2007 02:31 AM
Laminate vs. Vinyl-any regrets? BillTex Floor Finishes 18 04-27-2007 07:30 PM
Requesting Advice on Laminate Flooring Atlantica Floor Finishes 19 07-27-2006 09:35 AM
Laminate flooring up for grabs pinkflamingoes Upholstery, Blinds, Walls & Interior Finishes 0 07-11-2006 11:38 AM
Laminate Flooring Help! Safari Tim Floor Finishes 26 03-05-2005 04:31 PM
