Old 03-13-2016, 02:11 PM   #1
SMLJeep's Avatar
2017 27' Flying Cloud
Moneta , Virginia
Valve Stem Size Question.
Yes, I have search the forum using the Google option. No, I don't want to change to 15 in. wheels. Now that I have that out of the way here is my questions:
Does anyone know if the valve stem size on the stock 14 inch wheels of a 2015 23FB are .453 or .625 diameter?
Thank You.
SMLJeep is offline   Reply With Quote
Old 03-14-2016, 11:07 PM   #2
2016 26' Flying Cloud
Southlake , Texas
It would be the smaller one. The large one is for wheels that were originally used with tube-type tires.
Bgibbs is offline   Reply With Quote
Old 03-17-2016, 02:36 PM   #3
SMLJeep's Avatar
Moneta , Virginia
What length valve stems are people using? I purchased the TST Flow-Thru system and they couldn't tell me what length metal valve stem to use. Only advice was to get short ones as the Flow-Thru sensors are 2 inches long. Looking on-line I've found ones 1/2", 3/4" and 1". My concern is the TST sensor is 1.1" at the base. With the angle of the wheel at the hole for the valve stem if I get one that is to short the sensor will not screw on. If I get one that is to long the sensor will stick out to far and could get broken off. FYI, Jackson Center was no help!
Old 03-18-2016, 02:32 PM   #4
Southlake , Texas
I just returned the flow thru sensors for the "cap" sensors. In talking to TST, this is what they recommend. I had the same concern with the flow through sensor sticking out and getting hit by something. Contact Debbie at TST and she will swap them out.
Old 03-18-2016, 06:44 PM   #5
2015 23' Flying Cloud
Livermore , California
I would like to know what replacement metal stems are best on the 14" FC 23 wheels. I have the 507 non flow through caps.
cactusjk is offline   Reply With Quote
Valve stem size? AWCHIEF Wheels, Hubs & Bearings 5 05-08-2015 07:26 PM
Replacement cartridge valve stem for my Moen shower, Help???? jerrodwong Plumbing - Systems & Fixtures 4 09-10-2006 08:42 PM
Followup to valve stem failure dtbw Wheels, Hubs & Bearings 0 10-29-2003 08:40 AM
Valve stem failure on '02 Bambi dtbw Wheels, Hubs & Bearings 12 10-25-2003 10:17 AM
Valve stem Craig Wheels, Hubs & Bearings 1 08-04-2003 05:34 PM
