Old 10-27-2015, 08:56 AM   #21
HowieE's Avatar
Princeton , New Jersey
Images: 12
Originally Posted by Airstream 22 View Post
The video by Airstream nerds shows the addition of 3M 2" Outdoor Tape to the levelers I expect to improve traction when pulling onto the levelers. Has anyone found this a necessary add on or are they sufficient as delivered?
I watched the Official Andersen youtube and saw no mention of tape applied to the leveler.
There is no need for "traction" between the tire and the leveler. Traction is a mean of defining the interaction between two surfaces that are moving against each other, ie tire to ground. There is no movement between the leveler and the tire or the leveler and the ground.
The only thing I can imagine might be if you are on soft ground the chock might have a tendency to fly out from under the leveler as it is pushed into the ground. Is that the surfaces they mention in the video?
2004 Excursion 4x4
Old 10-27-2015, 09:42 AM   #22
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
I guess if you switch to tandem 16" rims/tires you'll have to trim them to make them work?
Kelvin
Old 10-27-2015, 09:55 AM   #23
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I forgot to mention I have 16" wheels.
2019 Ford Expedition Platinum
Old 10-27-2015, 10:20 AM   #24
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
No trimming was required with our 16" wheels on a 27' EB. I don't know if the wheel spacing could be different on other models, making things a tighter fit. Joe
jayseejay is offline   Reply With Quote
Old 10-27-2015, 12:18 PM   #25
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
Ok - so instead of using the word "traction" try this instead....for just a couple dollars you can get peace of mind if you think there may be issues with tire slippage on the smooth plastic surface. And of course this is not a manufacture recommended application and I am no engineer but I am fairly certain that in no way does adding grip tape to these devices adversely effect their usage for those of you that do not feel that it is necessary.
Our Website: https://airstreamnerds.com/
You Tube Channel "Airstream Nerds": https://www.youtube.com/airstreamnerds
Find Us on Facebook: https://www.facebook.com/AirstreamNerd/
AStreamNerds is offline   Reply With Quote
Old 10-27-2015, 01:41 PM   #26
2016 28' Flying Cloud
2009 30' Classic
2008 27' Safari FB SE
Sussex , New Jersey
Thanks for both your video and your responses to my question about "traction". Based on the minimal cost of adding the 3M tape to the levelers, I'm going to "take the plunge" and add it to my levelers. I certainly appreciate all of the input that I've received to my question.
Airstream 22 is offline   Reply With Quote
Old 10-27-2015, 02:52 PM   #27
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
I have never once needed to put grip tape on my levelers and we camp on all types of surfaces since we live in our Airstream. But I'm sure it won't hurt either.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 10-27-2015, 07:02 PM   #28
2020 Classic 33
Box Elder , South Dakota
No trimming for a 2015 Classic with 16" tires.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 11-22-2015, 03:04 PM   #29
wecoyote's Avatar
2014 30' Flying Cloud
Royal Oak , Michigan
Our Andersen Levelers arrived just as the snow began here in Michigan. I guess we are going to have to wait for either a thaw or next season!
I'm looking forward to not carrying the "lumberyard" of ramp sections I had built.
Royal Oak, MI
WBCCI #: 8356 (the same number my grandparents had from 1963 to 1981)
AIR #: 104322
Henry - 2013 F150 Super Crew XLT w/ HD Towing
wecoyote is offline   Reply With Quote
Old 11-29-2015, 05:50 AM   #30
wecoyote's Avatar
We had a nice enough weekend here in SE Michigan to go out. We are at the Algonac State Park camping in 25 degree weather!
With our 2014 Flying Cloud 30, the levelers work great! What used to take 10 minutes, now takes 1. We were leveled in no time.
Using the Andersen Levelers and the X-chocks, this is the fastest we have ever been able to level. Why didn't we get these sooner?!?!
Royal Oak, MI
AIR #: 104322
Old 11-29-2015, 05:19 PM   #31
We have really enjoyed our Anderson levelers. So far they are durable and have done the trick. The only slight issue I have had is when packing up to go, I have to back onto them a bit more to release the pressure on the chock. These levelers have made my leveling experience much better!
ras.robshort is offline   Reply With Quote
Old 11-29-2015, 05:34 PM   #32
Tincampers's Avatar
Sneedville , Tennessee
We've only used ours once and that was on a pea gravel pad so they sank some. But they were easy to use and we were level pretty quickly. My wife even picked them up fast.
Tincampers is offline   Reply With Quote
Old 11-29-2015, 07:11 PM   #33
silverlabs's Avatar
2015 28' Flying Cloud
Waxahachie , Texas
I have used these for the last year and a half and never had them slip. Probably a total of 80 uses. Plenty of room on both my 25FC and 28FC. Just put 16" wheels and tires on the 28 and they are a little tighter between the tires, but they fit by basically jamming them in under the tire a little more. I love these as I can basically look at my level initially and I know by how far off I am, how much I need to pull onto the levelers. I pretty much hit it first time every time. Great accessory. I have had to use once with a couple of lynx blocks on ground as we were in a very uneven site. Still worked fine.
silverlabs is offline   Reply With Quote
Old 09-29-2016, 06:50 PM   #34
The Aluminum Tent 3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Need 2 Anderson levelers for 2-axle trailer?
I'm purchasing a 2014 FC 23 FB, 14 inch tires. I have an anderson leveler that I used on my Bambi, but curious--do I need another for the double axle, using 2 of them, or is it OK to just use one under one tire and let the other wheel hang in the air.
Actually...just reading my own words I think I know the answer, but I'll send it anyway. If I need two, will I need to cut them down to fit?
pcskier is offline   Reply With Quote
Old 09-29-2016, 07:21 PM   #35
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Buy another. You might have to trim a bit off one. I would wait and see before doing the surgery.
MICHAEL
Old 09-30-2016, 08:39 AM   #36
Manassas , Virginia
We did not have to trim ours for our 25 FB
Old 09-30-2016, 08:55 AM   #37
HowieE's Avatar
Images: 12
The need to trim is a function of the ground you are parked on. Flat concrete or asphalt is not the place to check if trimming is necessary. If you are on soft ground or on grass they may lift the leveler just enough to make it hard or impossible to slip the leveler in place.
Trim one before you travel and be ready for the unexpected.
2004 Excursion 4x4
Old 01-03-2017, 11:54 PM   #38
Journeyman
2016 25' International
Amherst , Massachusetts
Originally Posted by ghaynes755 View Post
90% of the time solo with the Andersens. Electronic LevelUp mounts to a small 3m Lock loop on the the bottom of the front window. Get full aligned, identify low side, position the Andersens, slowly pull forward until the LevelUp turns green. Set the parking brake (as mentioned just putting in park usually results in some roll).
What is this "Electronic LevelUp" magic that you speak of? I must have it!
Some (hopefully useful) Airstream videos here:
https://www.youtube.com/c/journeymanvideos
thiel is offline   Reply With Quote
Old 01-04-2017, 06:30 AM   #39
2017 27' Flying Cloud
London , Ontario
Maybe something like this? I'm getting one for the upcoming season, but held off buying so far because I hate it when I buy something and a new one is released shortly after I buy it!
https://www.amazon.com/LevelMatePRO-.../dp/B01FGGSWPW
Philip Jones is offline   Reply With Quote
Old 01-04-2017, 09:25 AM   #40
jayseejay's Avatar
Here is the LevelMatePRO unit installed in the closet of our 27' EB. It connects by BT to your phone even while your driving, so you can evaluate the levelness of sites on the fly, as well as when you drive up on leveling blocks or rollers. It graphically indicates on your phone not only which way your AS is leaning, but by how many inches. All this can be accomplished with exterior physical levels, but I find this device little easier, particularly when traveling alone. Joe
Name:	ImageUploadedByAirstream Forums1483547079.081345.jpg
Andersen Levelers-Anyone tried them. interstateflyer Towing, Tow Vehicles & Hitches 45 06-14-2021 05:26 PM
Andersen levelers and a 25' reelfastgreg 2009-2015 Flying Cloud 22 06-12-2015 10:23 AM
Levelers and airbags CBBOB Mechanics Corner - Engines, Transmission & More... 2 09-01-2003 03:25 PM
Airbags and self-levelers fangthorpe Mechanics Corner - Engines, Transmission & More... 7 08-12-2003 10:16 AM
