04-03-2018, 07:10 PM
2011 23' Flying Cloud
Anchorage
, Alaska
Under-Bed Dimensions 19' or 23' D
Hello All. Does anyone happen to know (or able to find out) what the dimensions of the long, narrow-ish storage area is under the corner bed of the Flying Cloud 23’ D (rear bed)? The 19’ would have same dimensions as would International models I believe. We bought a 2011 in December that I have yet to see....many states away, and trying to order storage containers. Thank you!
04-03-2018, 07:24 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
36”deep, 17.5”wide, 14”tall.
That’s for my 2014 23D
04-03-2018, 10:30 PM
Anchorage
, Alaska
Thank you so much GMFL. That helps a bunch. The Container Store has what seems to be a perfect fit for that space. 32” deep, 17” wide and 13” tall with inset wheels and a pull handle (and airline checkable size exactly). $39.99. Reviews aren’t perfect but for these purposes could work well. Thanks again!
04-04-2018, 05:35 AM
Overkill Specialist
Dadeville
, Alabama
Welcome. Mine is here at home with me so if you need any other measurements don’t hesitate to ask.
04-04-2018, 08:18 AM
Anchorage
, Alaska
Thanks much!
04-08-2018, 12:24 PM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Was able to get to our 23D yesterday. We added LED strips on either side of the middle of the bed web support after cutting an opening to make for additional storage of larger items and blocking off where the items can slide to under the bed in the new space. The LED switch is by the door as shown in the bottom left photo (if they don't move around later). This is the large container Airstream supplies. The two smaller units I forgot to measure as the labels were gone.
04-08-2018, 02:27 PM
2014 31' Classic
Apache Junction
Went back to the trailer today and checked the measurements of the two smaller containers showing in the the two bottom photos above. They are nominally 17" x 11.75" x 6.75" tall.
04-11-2018, 07:51 AM
Anchorage
, Alaska
Thank you so much! This is super helpful. That Sterilite they supplied is a great size. I don’t think ours is there any longer.
I have 6 trunks from container store arriving Friday that will be used as checked luggage (meets airline specs perfectly) and then 5 will be used in back of truck and one fits perfectly under here. Dimensions above.
Interesting that there is more storage space to access. Hard to reach in there?
Thanks again for the detail! I really appreciate it! Might need to look online for more Sterilites.
Do you know if the panels open under pantry, closet and bathroom sink?
