Old 10-27-2015, 04:10 PM   #29
Long Island , New York
Originally Posted by Mike S. View Post
The brass valve is a water drain for the plumbing system, not the tank. The white valve drains the tank. I broke the brass valve while my trailer was sitting in my shop trying to figure out what is was for. Had a hose hooked up to the water supply and turned the valve. Water came out and the valve broke off. The 90 fittings have a thin wall and are easy to break. It is a pita to fix, had to cut an access hole to gain access to the pex tubing. If it breaks, the brass fittings will just spin in the pex. I put a smaller valve, like that found on a car radiator, to reduce the chances of being hit, eliminating the 90 fittings. Hope this helps.
Originally Posted by 111 View Post
Nothing in the owners manual about the brass. Dealer doesn't know anything.
Thanks Mike for solving the mystery here. I believed you but thought it best that 111 confirm the diagnosis for HIS coach's valve.
Could you guys please comment on the left end of the valve being convex/bulbous to receive flared copper tubing, or is it NPT as wander-west suggests?
Old 10-27-2015, 05:45 PM   #30
111
2015 23' Flying Cloud
Moses Lake , Washington
No flare on the brass, Its a low point drain for the lines but its in a exposed area. Just asking to be knocked off or turned on so all my water gets pumped out.
Great for winterizing though..
111 is offline   Reply With Quote
Old 10-27-2015, 08:09 PM   #31
2017 25' International
Joliet , Illinois
I have the same setup on my 23D. Mike S. has it right. It's a drain on the plumbing side (after the water pump). If I remember right, take out the converter/ fuse box and you can see the tube go straight down through the floor.
I am going to put on a winterizing kit this year and have everything apart......again. Can get a picture if someone needs.
bel73 is offline   Reply With Quote
Old 10-27-2015, 08:53 PM   #32
Value
Probably low point drain for water lines.
We have. 25' Flying Cloud. Had to replace one of our low point valves. Airstream sent us a brass value just like this one.
RChristian is offline   Reply With Quote
Fresh water drains? cwf Fresh Water Systems 8 05-28-2013 08:42 AM
Grey water tank nothing drains mrmossyone Waste Systems, Tanks & Totes 12 01-08-2008 11:30 PM
1986 AS 345 MH AC Drains Jim Tyrney Airstream Motorhome Forums 2 06-18-2004 10:18 PM
Standing water in drains hhuber Our Community 11 07-30-2003 07:20 AM
coconut oil lubricant for drains murphy Waste Systems, Tanks & Totes 9 05-12-2003 08:01 AM
