Old 10-19-2016, 10:53 AM   #1
honi soit qui mal y pense
Robere's Avatar
2015 23' FB Flying Cloud
Bend , Oregon
Twelve months in our 2015 23' FC FB
This is a list of problems during our first twelve months which were resolved under warranty or by owner modification.
2015 23’ FC FB Airstream VIN 1STK9AG29FJ533030 - purchased November 2015
since delivery.
Screen door sticks.
Screen door adjusted by Sky River RV, Paso Robles, CA. 24 May
Stove igniter unreliable.
Igniters adjusted by Sky River RV, Paso Robles, CA 24 May (unresolved)
Propane tanks rusting and paint peeling.
Tanks replaced by Airstream 13 Jun
Shower door bottom sweep torn.
Airstream supplied part 20 Jun. Owner installed.
Window in bath entrance door is tilted 3/16” top to bottom.
Owner will live with it. (leaning window of Airstream)
Tank monitors unreliable. We have been advised that the monitors are problematic.
noted first week:
Drapes at front window do not provide privacy - velcro wrong configuration.
Owner resolved with double sided velcro.
discovered 18 Feb while using cooktop fan.
Aluminum debris left in cook top exhaust fan duct during manufacture..
Owner removed.
discovered 18 Feb while checking wheel lug torques.
Lug nut aluminum caps split.
Replaced with steel capped lug nuts at Discount Tire, Tucson, AZ. 16 Mar.
Airstream reimbursed.
discovered 20 Feb.
Dometic refrigerator fan inoperative. Unable to maintain low temp.
Owner repaired connector to fan 24 Feb
Dometic refrigerator fan on/off switch missing.
Fan kit sent to owner at Ajo, AZ by Airstream Adventures NW. 5 Mar
Owner installed.
occurred 16 Mar.
Wire racks in slide out cabinet tumbled loose spilling contents and breaking containers
Owner secured with plastic wire ties 18 Mar.
occurred 26 Apr.
Dometic refrigerator would not ignite on propane.
Professional Camper Care, Cortez, CO adjusted. 2 May
Dometic reimbursed.
occurred 27 Apr.
Propane tanks were not full as indicated during sale.
Owner had tanks filled necessitating trip change.
Propane regulator empty / full indicator faulty. Ran out of propane.
Regulator replaced by Sky River RV, Paso Robles, CA 24 May
No confidence in regulator indicator. One tank used at a time.
occurred 5 May.
Batteries would not maintain a charge. Dead cell in both batteries.
Batteries replaced at Interstate Battery Company, St George, UT 10 May.
Airstream Adventures NW covered replacement cost under warranty.
occurred 11 May.
Fantastic Fans failed (both units within 5 minutes)
Diagnosed by FF. Rain sensors received 24 May. Unresolved.
Diagnosed by Sky River RV. Motor/fan received 13 Jun
Airstream Adventures NW installed motor/fan 23 Jun. Unresolved.
Diagnosed by Airstream Adventures NW.
Circuit board assembly & lift motors received 30 Jun.
Owner installed. Resolved (50 days without fans)
occurred 13 May.
Unable to flush-out black water tank.
Repaired by Sky River RV, Paso Robles, CA 24 May
occurred 15 May.
USB ports at sound system failed.
Airstream supplied replacement ports 30 May. Owner installed.
since July.
Toilet would not maintain water in bowl.
Thetford provided rubber seal kit. Owner replaced.
Cooktop igniter failed.
Atwood supplied part through local RV dealer. Owner replaced.
City water connector - regulator port leaking inside trailer.
Airstream supplied part. Owner replaced.
Reinforced PVC hose added at interior connection point to reduce stress.
Owner added.
Shower door sweep failed again.
Owner purchased locally & replaced.
redesigned / upgraded:
Converter upgraded to multi-stage unit to prolong battery life.
Owner replaced
Dining table reduced in size for functionality. (Walnut - 30 3/4” x 20”)
Cabinet maker supplied. Owner stained.
Microwave removed for additional storage.
Cabinet door constructed & installed by professional to match cabinets.
Accumulator added to plumbing system to reduce water pressure issues when heated.
Owner installed accumulator adjacent to water pump.
Furnace ducting near water pump crushed / duct longer than necessary. Owner resolved by shortening ducting.
Robere (aka Pepe) & Jacqueline (aka Gigi)
with pups Ella (the miniature poodle)
and Tibet (the Lhasa Apso)
2016 Chev Silverado LT Crew 4x4
Robere is offline   Reply With Quote
Old 10-19-2016, 11:14 AM   #2
london1201's Avatar
2015 25' Flying Cloud
2003 19' Bambi
Union Grove , Texas
sounds familiar - disappointing from AS - we are going to Jackson in about 2 weeks
london1201 is offline   Reply With Quote
Old 10-19-2016, 11:25 AM   #3
2012 25' FB Flying Cloud
Parker , Colorado
I too have had similar multiple part replacement issues with the Fantastic fans. One still doesn't work. After 4 different parts sent, I requested that I be able to send the whole fan in for diagnosis, or they just send me a whole new one. No dice. They always want to walk through a diagnosis, and have me do electrical testing.
I'm done with them. Replaced with Maxxfan Plus's. Very happy. Much quieter, reversible, 10 speeds variable, and come with remotes which is great when you are lying in bed.
2012 25FB with solar
2012 Toyota Tundra 5.7L V8
mfrez is offline   Reply With Quote
Old 10-24-2016, 02:48 AM   #4
2018 27' Flying Cloud
Stock ones are reversible as well, but you have to buy and add the switch yourself.
-Wayne
wbrisett is offline   Reply With Quote
Old 10-24-2016, 02:53 AM   #5
I would never trust it. Plus using them one tank at a time ensures you always have one that works and that you can fill it later, while always having a good one.
since July.
How hard is that? I noticed that same issue in my 23D. You fill it and it drains fairly quickly. I assumed it was the seal. Did you go through AS first, or just contact Thetford directly?
-Wayne
Old 10-24-2016, 12:52 PM   #6
dames7's Avatar
GILBERT , Arizona
When do you get your check from AS for all the manual work you had to do.
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
dames7 is offline   Reply With Quote
Old 10-24-2016, 12:56 PM   #7
dames7's Avatar
GILBERT , Arizona
Our AS is in the shop for the convertor, not having them replacing with a 1 Stage, I am getting a 4-Stage Boondocker BD 1260HW (60 Amp 4-Stage Converter/Charger Hard Wire).
They are paying to have it installed.
David & Nancy Ames
2015 FC 25' RB
Old 10-24-2016, 12:59 PM   #8
B00merang's Avatar
2010 20' Flying Cloud
Hailey , Idaho
Pobere...this sad experience with a brand new AS will help those folks who keep asking about the risks of buying a used AS vs buying new...with the assumption being that EVERYTHING works if they buy new. Good post. jon
B00merang is offline   Reply With Quote
Old 10-24-2016, 04:36 PM   #9
Free bird's Avatar
2016 22' Sport
Grayslake , Illinois
I HAVE A 2016 22FB...with a list as long if not longer. Wish I never brought. Don't have the tools or smarts to fix by myself. It has been in for service on another list now for almost 3 weeks. I was told that I am not their only customer. Bought thinking AS was a quality product. I feel my dream to camp is gone.
Free bird is offline   Reply With Quote
Old 10-24-2016, 04:54 PM   #10
FCStreamer's Avatar
2014 30' Flying Cloud
Sorry to hear that. Our 2014 FC 30' has been virtually problem free. Don't become discouraged. They do exist. I hope you get your problems resolved soon.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 10-24-2016, 04:59 PM   #11
Robere's Avatar
Bend , Oregon
I'll get the check the same day my taxes are cut in half.
Robere
Old 10-24-2016, 05:02 PM   #12
Robere's Avatar
Bend , Oregon
Good for you. We are happy with the multi-stage converter we purchased from Best Converter in Idaho. Very easy to install.
Robere
Old 10-24-2016, 05:26 PM   #13
Robere's Avatar
Bend , Oregon
Elementary "Dear Watson". I am wiser for the experience. Robere
-Wayne
Thetford came through. I contacted them, supplied the appropriate info, and they sent a gasket kit. Utilized You Tube to move forward and within an hour everything was up and working properly. Robere
Old 10-24-2016, 05:31 PM   #14
Robere's Avatar
Bend , Oregon
Sorry you've experienced much of what we have. My wife a former sailor and RVers aplenty have reminded me that if it moves, was designed and built by men, it will need repairs. Soon everything will be dialed in and you'll forget these issues as you enjoy songs and laughter with new friends around a campfire and adult beverages. Robere
Six Months into our Airstream Adventure... wiredforless Airstream Lifestyle 24 09-06-2013 06:06 AM
6.5 volts instead of twelve photoguy Batteries, Univolts, Converters & Inverters 4 05-28-2010 03:10 PM
First two months in our new 23' Safari SE LS OrangeKid 2007 Safari SE 5 03-28-2007 01:20 PM
A twelve or two sixes ? Torii Electrical - Systems, Generators, Batteries & Solar 21 02-25-2006 08:08 PM
Looking for somewhere to park our coach for 2 months in the Los Angeles area!! HELP!! williamhenshall Our Community 5 10-22-2003 08:58 PM
