Old 01-10-2015, 07:04 PM   #211
SteveH's Avatar
Common Sense , Texas
Originally Posted by tjdonahoe View Post
Yea ! that would save 4 lbs per gallon,and the batteries far behind the rear axle thus lifting the tongue somewhat. I think in will have another glass of pre mixed egg nog.
You've probably had enough when you misspell "I".
Regards,
Steve
Old 01-10-2015, 07:21 PM   #212
2017 27' International
Fall City , Washington
I think it would be a great article if a one of the RV trailer publications were to conduct a series of tests involving 1/2 and 3/4 trucks, towing two trailers, say a 25' and a 30'.
If I was the author, I'd choose the same brand truck, and option it for tow capability, with the same wheelbase. I'd stick with either gas or diesel engines, not mix them up, since the issue is really about towing capability, not engine performance. Only concession would be to choose a larger displacement engine, especially for the 3/4 ton, since it has to carry about 1000 extra pounds (or 2klbs if a diesel). I'd also use the same WD hitch to see the effect.
I'd make sure the trucks and trailer have the types of weight to simulate real-world passenger weight, cargo, gear.
Tests I would conduct:
1. Measurement of axle loads, hitch loads, and general scale measurements, with and without a WD hitch.
2. Acceleration, passing, and braking tests including flat and real world conditions, such as on a steeper grade, panic braking.
3. Fuel efficiency.
4. Operating temps for oil and transmission fluid.
5. Handling, including slalom and quick lane changes, to see how the rigs handle.
6. For fun, rig up a Chrysler 300 sedan like you've read about, just to see
All of these are pretty easy to do, using over-the-counter ODB2 readers that take the data right off the trucks computer, and using available scales. It would really give the reader a perspective
That would be a nice objective article so a reader could accurately see how each type of vehicle performs. And perhaps put a chill to the saga of the "will my vehicle safely tow this trailer" debates.
My good friend has a nearly identically optioned eco-diesel 1500 crew cab, albeit with a shorter bed/wheelbase. Hmm......
2014 28' Flying Cloud
2013 Ram 2500 Laramie Crew Cab CTD 4x4
Lara Me is offline   Reply With Quote
Old 01-11-2015, 09:07 AM   #213
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
You could get the information from your local salesman,why not try your friends 1/2 ton out with your trailer then use yours on the next run and report back your findings......no such thing as too much horsepower or money.".....
Old 01-11-2015, 11:49 AM   #214
mefly2's Avatar
2015 25' FB Eddie Bauer
A person could move the batteries to the rear of the trailer along with the propane tanks like that one dude,and I am out of popcorn,I guess I better go out and plow some more snow..
What?
You have snow to plow? Mon dieu ...
Another 10" here this morning!
Old 01-11-2015, 04:34 PM   #215
1986 31' Sovereign
Miami , Florida
Could be worse, I have to mow my lawn tomorrow...
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 01-11-2015, 04:42 PM   #216
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Yes but you guys have a lot of snakes , I mean bid snakes, all kinds of bugs,wild iguana 's and all them things,we have just snow and cold.....
Old 02-27-2015, 06:11 PM   #217
2015 27' Flying Cloud
Washington , Washington, D.C.
Wow. The OP has probably jumped out of a second story window after slogging thru this. No one mentioned that per gov't requirements, every car and 1/2 ton truck has a sticker on the driver's side door frame, giving the maximum payload for that particular vehicle, reflecting its unique combination of options, tires, etc. I believe this is supposed to reflect a 175 lb driver and all fluids, including a full tank of fuel. In my experience, these vary widely between the same model truck with the same engine and drivetrain. Things that eat your payload are skid plates, sun roofs, low aspect ratio tires (e.g. 20" wheels) and power seats. Also extra capacity fuel tanks, such as Ford offers on its 1/2 tons. Also, of course, a second seat (crew cab, extended cab). So, if you care about this, there's at least one real number that you have to work with when figuring out what to buy. Although I haven't tried it out yet, I'm pretty comfortable with the idea of towing my new FC 27 FB with an F-150 and the max payload package. I'm thousands of pounds under the max towing capacity of the truck with either the V8 or the Ecoboost V-6, and while this is difficult to predict before I get the truck, I should have a rated cargo capacity of over 2,000 lbs. even with the Lariat model which has power seats. Interestingly, this package includes unique wheels as well. I had probably feel ok towing the 30 FC with this as well. The Classic 30, with a GVWR of 10,000 lbs might be pushing it. The thing is, as soon as you step up to a 3/4 ton, you have a truck that's about 1500 lbs heavier, dripping wet.
DC Bruce is offline   Reply With Quote
Old 03-01-2015, 06:34 PM   #218
2015 30' Flying Cloud
Springfield , Virginia
Based on all the discussions and additional research, I cancelled my order for the 1500 and purchased 2500 Cummins Turbo Diesel. More than enough truck and I'm comfortable with it. Thanks to all.
VernH is offline   Reply With Quote
Old 03-01-2015, 06:49 PM   #219
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
The Duramax/Allison is a fine machine.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
m.hony is online now   Reply With Quote
Old 03-02-2015, 02:06 PM   #220
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
you will like it ,vern
Old 03-02-2015, 03:38 PM   #221
silverbp's Avatar
2014 25' FB Flying Cloud
LaMarque , Texas
So is the new Diesel 2015 F-250 for that matter. More HP and Torque then both of the other two.
Sent from my iPhone using Airstream Forums silver bp
silverbp is offline   Reply With Quote
Old 12-11-2015, 02:08 PM   #222
I ended up buying the RAM 2500 Crew Cab with Cummins Diesel. Best decision I ever made. Tows my 30ft Flying Cloud like a dream, up Hill or down.
Old 12-11-2015, 03:40 PM   #223
Gainesville , Florida
You did good!
avionstream is offline   Reply With Quote
Trailer Tires vs. Truck Tires ON Trailer jvcolaizzi Tires 34 11-21-2014 06:26 PM
Truck and trailer worked great, but all toys broke Lothlorian Off Topic Forum 4 06-29-2012 12:57 PM
New Reese System for old truck and Trailer JLD Hitches, Couplers & Balls 12 03-17-2003 08:46 AM
