Old 07-23-2012, 10:14 PM   #29
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Collimare
I have recently removed the original Armstrong Rooftop AC unit from my 66 Tradewind and am cooling my trailer with only a 5k window unit. I started a thread if you are curious. I have tinted windows, keep the curtains closed and have LED lights. I will be replacing all 3 vents with Fantastic vents plus one more where the AC unit was located for a total of 4 FV. I will insulate these vents with an rv vent insulator I just ordered from Amazon. Here is the link:
http://www.amazon.com/gp/product/B00...ls_o00_s00_i00
Here is what I recommend for your trailer:
1. Tinted windows
2. White roof coating
3. Keep curtains closed on windows that you are not looking out of.
4. Insulate all windows that you are not looking out of with reflectix (bathroom, bedroom, etc.)
5. Insulate all vents.
6. Only use LED lights- They give off only about 10% of the heat compared to halegan and incandescent light bulbs.
7. Park in the shade whenever possible
8. Don't cool bathroom or bedroom during the day unless they are being used.
9. Use a fan to circulate the air in the trailer so it feels cooler.
The last change I would make would be the 15k AC unit. I don't think you will need it if you make the above changes.
Good luck, Dan
Old 07-23-2012, 11:03 PM   #30
richinny's Avatar
2011 34' Classic
Originally Posted by Collimare View Post
richinny, Thank you for the link. I might consider the Relectix in the rear most/wrap bedroom windows as we donít typically open those curtains much, but I would prefer not deal with it when we do.
I really want to be able to open the blinds/curtains and enjoy even when it is hot.
make note of lewsters post:
http://www.airforums.com/forums/f454...tml#post590574
the screen seems to reduce the heat while letting you see outside
Ricky
Old 07-24-2012, 05:10 AM   #31
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
Other than replacing your AC with a 15BTU unit you might try a couple of portable fans to keep the air moving over you which should reduce the temp you feel by a couple of degrees much as ceiling fans do in a residence.
As mentioned by a previous poster, closing off a portion of the trailer will help during the heat of the day. We do this when first setting up camp in the heat and our cat loves the warmer bedroom.
Make certain your filters on the AC are as clean as they can be.
Welcome to this forum.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
New Warm white Recessed Puck Lights Dan@LED4RV Commercial Listings 17 11-11-2015 09:10 PM
fridge mystery- freezer cold, refer warm hertfordnc Refrigerators 4 04-25-2011 07:16 AM
OMG It's the sun and it's warm!!! wheel interested Off Topic Forum 30 04-17-2011 06:50 AM
Warm weather here - itchin' to do some fixin' ltenbrink General Repair Forum 4 01-02-2011 07:36 AM
