Old 08-14-2015, 02:33 PM   #1
2014 25' FB Flying Cloud
Vancouver , British Columbia
Tail Light Assembly
Several LED tail light bulbs are out on my 2014 FC25FB. I suspect loose connections from rough gravel roads. The tail light assembly has four screws, two on each side, and some gray sealant between the assembly and the trailer body. No gasket is visible. The assembly does not come off when I remove the screws. The sealant seems to be holding it on. If I cut the sealant will the assembly pop off?
RubyDog is offline   Reply With Quote
Old 08-21-2015, 06:52 AM   #2
TRIPPPIN's Avatar
2012 25' FB Eddie Bauer
Southwestern Ontario , Ontario
Send a message via AIM to TRIPPPIN Send a message via MSN to TRIPPPIN Send a message via Yahoo to TRIPPPIN
I can tell you the clearance lights and side marker I removed needed to have the sealant cut to remove them so I assume the tail lights are similar. Careful not to scratch what you can't cover up with sealant later.
TRIPPPIN is offline   Reply With Quote
Old 08-21-2015, 08:45 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
I've used a length of heavy,(25lb), mono fishing line to cut a sealant bond.
Old 08-21-2015, 01:01 PM   #4
richw46's Avatar
Lexington , Kentucky
I thought I saw where someone else was replacing the LEDs in the taillight and they said they didn't remove the light assembly, just the ring around the LED itself, that it just snapped in. http://www.airforums.com/forums/f447...ml#post1670375
The attached image isn't visible, however.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 08-21-2015, 10:06 PM   #5
richw46's Avatar
There was an update from the person who originally posted his experience. He bought the LEDs from his local AS dealership who ordered them from Airstream in Jackson Center. You can see the additional post in the same thread
http://www.airforums.com/forums/f447...ml#post1672744
-Rich
Rich & Yvonne
2004 4Runner SE
Replacement Tail Light Lense Assembly Swanny Lights - Interior & Exterior 5 07-02-2015 11:30 PM
Need to Replace Argosy Tail Light Assembly josephhhh All Argosy Trailers 25 02-11-2014 05:48 PM
Leak near tail light, but it's not the tail light adwriter73 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 03-31-2013 11:34 AM
Need '77 Argosy Motorhome Tail Light Assembly Panel adamstarr Lights - Interior & Exterior 1 09-29-2006 01:58 PM
Tail light assembly needed. AccessMaster Airstream Motorhome Forums 6 08-05-2003 07:35 AM
