Old 10-01-2016, 01:59 PM   #15
New Borockton , Alabama
Images: 21
Progressive Industries units are not necessarily sacrificial and that is why they have a lifetime warranty. I wouldn't decide on hard wire vs portable based on whether it were to ever fail but rather personal preference. Its nice to have the display of the EMS-HW types inside the coach to monitor error codes but its permanent so some prefer portable when they have more than one RV or might share it. I can't think of any other reason except maybe since they require no installation.
Randy 208-514-8950
Converters, Inverters, Monitors, EMS, Zamp Solar
Old 10-01-2016, 06:17 PM   #16
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
I went with the hard wired unit. So far no problems.
graysailor is offline   Reply With Quote
Old 10-01-2016, 06:33 PM   #17
Southwestern , Ohio
On the other hand, we have Airstreamed for 14 years without a surge protector, and so far no problems.
Nuvite-F is offline   Reply With Quote
Old 10-01-2016, 08:33 PM   #18
SilverBuddha's Avatar
2014 25' FB Flying Cloud
Columbia , Missouri
Progressive Industries HW
I too selected the hard wire option. In addition to the benefits of the remote/ bypass, by having the remote located "inside" you can monitor your total electrical load (amperage) as you juggle using various appliances.
Either way (In-E or an Out-E) splurge on a quality Surge Protection Device.
In addition to surge protection, the Progressive Industries (and others) unit will protect you from both "low and high" voltage conditions.
SilverBuddha is offline   Reply With Quote
Old 10-01-2016, 10:40 PM   #19
graysailor's Avatar
2016 30' Classic
A good point was made in that with the hard wired option you can monitor your electrical usage. I find that very helpful when using 30amp service when 50amp is not available.
Old 10-03-2016, 06:40 AM   #20
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I still use a Progressive Industries (?) surge protector at the power pole.
I just leave my power cord plugged into it and roll it and the power cord up together for storage.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-03-2016, 07:42 AM   #21
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
I chose built in. Installed right next to breaker box. Sure, if it takes a hit I have to consider wiring around it temporarily. What I don't like about pedestal type is a poor receptacle can damage male plug not enough pigtail to easily repair? And you added additional connection points to your cord.
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
I'm new. Need for surge protector? bcombs Member Introductions 14 11-09-2013 07:47 AM
1968 - Progressive Ind. 30 amp surge protector? Randy Gates 1965 - 1969 Globetrotter 13 10-17-2011 01:35 PM
Room for in-line surge protector in 23' Intl? Hoonanea Electrical - Systems, Generators, Batteries & Solar 0 10-03-2011 11:07 AM
Loud Humming Noise from Surge Protector Michigander Land Yacht/Legacy Motorhomes 8 07-23-2011 03:56 AM
surge protector pip8688 Batteries, Univolts, Converters & Inverters 15 08-09-2010 05:14 AM
Copyright 2002-2015 Social Knowledge, LLC All Rights Reserved.
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
