09-30-2016, 03:57 PM
2017 27' Flying Cloud
Alto
, New Mexico
Surge Protector on Elec Post or Built-in?
Friends,
I'm taking delivery of our 27' FC FB in a few weeks. We want a great surge protector. We currently use one (in our current AS) that plugs into the Electrical post in the camp. We wonder if having one wired inside the new trailer makes sense? Appreciate your thoughts.
09-30-2016, 04:05 PM
2012 28' International
Olympia
Originally Posted by BoerneBrogan
Friends,
I hardwired this one into my 28'. http://www.bestconverter.com/EMS-HW3...l#.V-7hEpGZORt
I like the convenience of not having to carry the external one and not worry about theft.
It was easy to access the back of the power center for installation. If I remember correctly the 27 may be more difficult.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
09-30-2016, 04:11 PM
Vintage Kin
Fort Worth
They eventually fail. Same for the auto formers. The latter may spark and smoke when it dies. The former?
After a few of those reports I decided I'd rather have them outside.
09-30-2016, 05:16 PM
2010 27' FB International
Deforest
, Wisconsin
I bought this one:
http://www.progressiveindustries.net/ems-pt30c
If you have a hardwired surge protector and it malfunctions, unless you have a bypass of some type you are out of luck.
External one malfunctions.....just plug your trailer in.
09-30-2016, 06:14 PM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
I use and like the one that plugs into the pole. I decided it was just too much hassle to wire one in.
09-30-2016, 06:15 PM
2008 34' Classic S/O
Arnprior
, Ontario
I beleive if either one of them fail, you have had a serge and they have done their job. You can unplug the fried portable one and maybe the root cause of the failure has passed........... or not. You should know for sure shortly after you reconnect your unprotected trailer.
Both systems have their pros and cons. Have a good look at both.
Pete Crook
"Put it all behind you!"
S/OS#88
09-30-2016, 06:31 PM
2015 30' FB FC Bunk
Ayer
, Massachusetts
I have a hard wired unit and love it. Haven't had problems though. The dealer installed it prior to delivery.
10-01-2016, 11:34 AM
2016 27' Flying Cloud
Sunriver
, Oregon
Pt30
Think twice about hardwiring. I use the portable PT30 from progressive and have a piece of mind. I use a check list on setup and packup. Like one poster mentioned if unit is hardwired and smokes then what do you do? Great question.
Regards
Mike
10-01-2016, 12:02 PM
2015 25' FB Flying Cloud
Nebo
, North Carolina
Surge protector.
I also bought the Progressive Industeries 30amp surge protector. Works fine on shore power and my Honda generators. I really like it, easy to use.
I ran electrical wire and a water line for a shore power outlet when I built a shed for my airstream. 270 feet from the my home. Then I plugged in the surge protector just to be shure everything was as it should be. Voltage was what I had calculated and everything else checked good also.
Lkjdude
10-01-2016, 12:08 PM
Watertown
, Massachusetts
Hardwired Progressive
We have a hardwired Progressive Industries unit. Since we are "belts and suspenders" type of people, we also invested in spare boards for the unit. There are three boards in our unit (30 amp) and we have a spare of each. That way if there is a failure, we can just call them and they will walk us through the diagnostics to determine which board blew and we will replace it right then.
10-01-2016, 01:45 PM
Watertown
, Massachusetts
Bypass switch
Re: "If your hard wired in unit fails, then you have NO power at all."
Well, actually, that isn't always true. On the unit we have there is a bypass switch. You just flip the switch and it bypasses the unit. Then you have power again but no surge protection until the unit is repaired - depending on which board failed. I'm guessing not all manufacturers / units have this switch. So, maybe that is something to we aware of while you are shopping
10-01-2016, 01:46 PM
Full Timer
2006 28' Safari S/O
Newport
, North Carolina
Note that the Progressive external units (which seem to be the very best of their kind available) each have a robust collar with an eye, allowing you to secure the unit to the power post to discourage theft.
Michael
10-01-2016, 01:58 PM
2017 25' International
Niagara-on-the-Lake
, ON Canada
Surge Protector By-Pass
Originally Posted by Doc Foster
If your hard wired in unit fails, then you have NO power at all. If a portable one fails (or in both cases, either one fries because it did its job), then you just buy another one, and until you do, you can still get unprotected power.
There is a simple, low cost solution if the hard-wired surge protector fails. Progressive has a by-pass switch for about $25 that allows you to go into ByPass mode without opening the unit.
Ray B.
10-01-2016, 01:59 PM
New Borockton
, Alabama
Progressive Industries units are not necessarily sacrificial and that is why they have a lifetime warranty. I wouldn't decide on hard wire vs portable based on whether it were to ever fail but rather personal preference. Its nice to have the display of the EMS-HW types inside the coach to monitor error codes but its permanent so some prefer portable when they have more than one RV or might share it. I can't think of any other reason except maybe since they require no installation.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
10-01-2016, 06:17 PM
TinCan
2016 30' Classic
Apache Junction
I went with the hard wired unit. So far no problems.
TinCan
10-01-2016, 06:33 PM
Southwestern
, Ohio
On the other hand, we have Airstreamed for 14 years without a surge protector, and so far no problems.
10-01-2016, 08:33 PM
2014 25' FB Flying Cloud
Prescott
Progressive Industries HW
I too selected the hard wire option. In addition to the benefits of the remote/ bypass, by having the remote located "inside" you can monitor your total electrical load (amperage) as you juggle using various appliances.
Either way (In-E or an Out-E) splurge on a quality Surge Protection Device.
In addition to surge protection, the Progressive Industries (and others) unit will protect you from both "low and high" voltage conditions.
Cheers
Eric
10-01-2016, 10:40 PM
TinCan
2016 30' Classic
Apache Junction
A good point was made in that with the hard wired option you can monitor your electrical usage. I find that very helpful when using 30amp service when 50amp is not available.
TinCan
10-03-2016, 06:40 AM
2013 30' Classic
Greenwood
, Mississippi
I still use a Progressive Industries (?) surge protector at the power pole.
I just leave my power cord plugged into it and roll it and the power cord up together for storage.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
