Old 10-27-2014, 04:23 AM   #29
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
This is what I have for my new Serenity: Progressive Industries PT50C 50 Amp Portable Electrical Management System. It plugs into the power for shoreline and one plugs the RV cord into it.
This tells me the voltage on both legs, checks for proper wiring, cuts off power if too low, I think about 103v, and sows the Hz of the source. This is made in 30 Amp as well.
On my Moho, I was plugged into an RV park which had low voltage and killed the transformer in my converter/inverter/charger, costing over $800 just get repaired. Could have cost close to $3,000 at a dealer I am told. This Progressive Industries PT50C 50 Amp Portable Electrical Management System may have prevented this.
It is available on Amazon and other places as well.
Ms Tommie Lauer
Greensboro, NC
2015 Serenity 30 RB / 2008 Dodge Cummins 4 X 4
WBCCI #4165 AIR #31871
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 10-27-2014, 06:46 AM   #30
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Originally Posted by TinTin View Post
Surge protectors on sale:
RV Surge Protectors
Thanks for the link!
I just bought one. One more item checked off the list.
Now for the solar, inverter, agm batteries, 16" tires and wheels, ProPride, shed, and so on and so on and Scooby Dooby Doo...
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-27-2014, 08:40 AM   #31
m.hony's Avatar
2013 30' Classic
Question:
If I am at a campground and only have access to a 30 amp receptacle will the 50 amp surge protector still work? Or will I have to also buy a 30 amp?
In my pea brain I think it might work, because the 50 amp to 30 amp adapter is just using 1 leg of the 50 amp service, but that may also be the very reason it doesn't work-
TAC #MS-10
Airforums #70955
Old 10-27-2014, 02:42 PM   #32
Van1's Avatar
2014 27' Flying Cloud
New Bern , North Carolina
M. Honey, you shouldn't have a problem. I called Surge Guard who advised me I could use the 50amp surge protector for my 30amp AS. I used it without a problem.
Van1 is offline   Reply With Quote
Old 10-27-2014, 06:22 PM   #33
m.hony's Avatar
2013 30' Classic
I'm talking about the other way around-
Plugging a 50 amp trailer into a 30 amp receptacle when there is no 50 amp service available-
It still might work, though-
I guess we'll find out next year when we go to Salmon Lake Park.
TAC #MS-10
Airforums #70955
Old 10-27-2014, 06:35 PM   #34
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Surge Protector Needed on 2015 Flying Cloud?
mh: According to the Surge Guard manual, you'll be fine regarding surge protection using the 50 amp protector when plugged into either 30 amp or 50 amp power.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 12-28-2014, 08:41 PM   #35
silverbp's Avatar
2014 25' FB Flying Cloud
LaMarque , Texas
Name:	ImageUploadedByAirstream Forums1419824446.794745.jpg
Sent from my iPhone using Airstream Forums silver bp
silverbp is offline   Reply With Quote
Old 12-31-2014, 08:35 AM   #36
Slympicins
Slympicins's Avatar
2015 27' Flying Cloud
Sevierville , Tennessee
Here is an idea to protect your surge protector from walking off. It's a simple coated wire with a loop crimped on the plug end and another loop for a lock on the other. I just lock it on the power cable and leave it. It's not fool proof but it's better than the manufacturers cheap bulky plastic box they sell for $25.00. This cost about $5.00.
Slympicins is offline   Reply With Quote
Old 12-31-2014, 06:31 PM   #37
Msmoto's Avatar
2007 25' Safari
Images: 135
That looks familiar.....
Alana_Surge_Protec_12.14.14-2 by Fantinesvoice.com, on Flickr
I wrap one or both cables around the power pole in such a way that it cannot be removed.
This is actually in my garage.
AIR #31871 K4MTL
Old 12-31-2014, 08:46 PM   #38
Slympicins
Slympicins's Avatar
Great minds think alike. Remember though, if someone wants it bad enough, it's gone. Thankfully camping folks are not like that.
Old 01-01-2015, 04:33 AM   #39
Msmoto's Avatar
2007 25' Safari
Images: 135
I think for me the idea behind a lock is to make it very difficult and time consuming for a thief to steal it, hopefully encouraging them to look elsewhere....
AIR #31871 K4MTL
Old 01-01-2015, 05:30 AM   #40
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Our new AS is 50AMP, I've got a 30 AMP Surge Protector, used only four times if someone is interested let me know
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 01-01-2015, 10:27 PM   #41
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
I did a hard wire install inside of the trailer. I'm lazy and did not want yet another thing to hook up when parking the trailer.
TinCan
graysailor is offline   Reply With Quote
Old 01-03-2015, 08:04 AM   #42
David
Bend , Oregon
Paiceman, I'm interested!
Davz2k is offline   Reply With Quote
I'm new. Need for surge protector? bcombs Member Introductions 14 11-09-2013 07:47 AM
1968 - Progressive Ind. 30 amp surge protector? Randy Gates 1965 - 1969 Globetrotter 13 10-17-2011 01:35 PM
Room for in-line surge protector in 23' Intl? Hoonanea Electrical - Systems, Generators, Batteries & Solar 0 10-03-2011 11:07 AM
Loud Humming Noise from Surge Protector Michigander Land Yacht/Legacy Motorhomes 8 07-23-2011 03:56 AM
surge protector pip8688 Batteries, Univolts, Converters & Inverters 15 08-09-2010 05:14 AM
