Old 04-04-2014, 10:26 PM   #1
Skid Rollers for Flying Cloud 27FB?
My Flying Cloud rear skids drag entering the driveway. Are skid rollers a viable option to minimizing damage? What does dragging do to the chassis or rest of the structure?
rgarza348 is offline   Reply With Quote
Old 04-04-2014, 11:03 PM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Welcome to the forum.
Hi, try removing your WD bars to give you more clearance.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-05-2014, 12:41 AM   #3
BicycleStreamers
BicycleStream's Avatar
2016 28' Pendleton
Buxton , Oregon
I had the rollers attached to the rear end to reduce dragging on my driveway. They work great. The only suggestion I have is to make sure the rollers stay lubed so they can rotate when you're coming in at an angle.
Good luck,
BicycleStreamers
"Don't forget, be excellent to each other!" Bill or Ted
BicycleStream is offline   Reply With Quote
Old 04-07-2014, 10:36 PM   #4
Thanks for the feedback. I tried it with WD removed, but didn't help enough. Finally got sufficient clearance by building up the ramps another 2 1/2". Scheduled an appoint to get skid rollers installed.
Old 04-07-2014, 11:30 PM   #5
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I will be raising my Airstream up two inches when I get around to putting new axles on, it is just too low for my taste.
It is too much of a PITA to get in and out of too many places.
Old 04-08-2014, 04:29 AM   #6
Baltimore , Maryland
If the trailer rolls on the wheel it is just like jacking the trailer from that location. I strongly suggest you do not install them. Better is to gain the height by taking off the weight distro and using boards.
Old 04-30-2014, 06:09 AM   #7
2011 23' Flying Cloud
Durango , Colorado
The jack point on my 23FB is at the rear near the skids. The chassis is obviously designed for taking this force. No difference in skidding vs rolling as far as vertical force, just less drag.
Safe Travels,
Joe & Joan Donnaway
Durango, CO
JamuJoe is offline   Reply With Quote
Old 04-30-2014, 12:22 PM   #8
The chassis is not designed to take that force. The skids are there just incase.
Good luck, you obviously know better.
Old 04-30-2014, 12:41 PM   #9
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Ever hear of "point loading"? That is what the wheels do, skids spread the load out over a larger area.
Aaron
WBCCI #XXXX AIR #2495
Old 04-30-2014, 10:22 PM   #10
Thanks for all the input and discussion everyone. This has been a frustrating problem to solve. Ramps seem to have a positive but limited affect at reducing the rear skid plates from dragging. This is in large part because it is not a simple straight in approach into the dipped and inclining driveway, but also adds an immediate curve in the path of travel. I cringe when the skid plates drag, more so when I know the tail end is also feeling the effects of side forces. Because of these challenges and to minimize stressing the trailer, we've temporarily stored the Flying Cloud in local (but not near by) RV storage. We've also decided to have rear skid casters installed by the Airstream dealer in the next few weeks. I'll post how these work out for us.
Old 05-01-2014, 12:16 AM   #11
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
Change driveway or never park on it would be the simple solution?!
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 05-01-2014, 12:39 AM   #12
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
20 years of parking the trailer in my driveway bottoming out entering and exiting contributed to my cracked frame. New axles finally fixed the problem.
4RXLA is offline   Reply With Quote
Old 05-01-2014, 05:44 AM   #13
LAWBC's Avatar
2013 27' FB International
2012 23' Flying Cloud
Victoria , British Columbia
I have a 27 fb international with a 8 degree driveway . My solution was to buy a 5 inch drop hitch witch I use to get her off my hill , both coming and going , it means changing the w/d hitch each time to get on and off the property but it works and I getting more efficient every time I do it. The only other answer would be to change out your wheels to a 16 inch and that might do it , by adding an additional 1/2 inch to the height of road clearance .
LAWBC is offline   Reply With Quote
Old 05-01-2014, 06:42 AM   #14
dznf0g's Avatar
Oswego , Illinois
I was quite surprised at how even a 1/2" difference made when going to 16" wheels. Of course I have healthy axles as well. I would think that is the #1 cause of excessive tail dragging. I'd rather just drag on the sacrificial skid plates and weld on new angle when the ends wear through.
-Rich-
Skid Wheels on a 25' 1985 Sovereign Sbpilot Hitches, Couplers & Balls 1 04-10-2012 05:02 PM
Skid plates? mybyebye Repairing/Replacing Floor &/or Frame 16 11-09-2011 08:46 AM
dragging the rear end of my 30' excella in the skid wheels gtmellon Repairing/Replacing Floor &/or Frame 7 12-03-2006 08:08 AM
Skid rollers/plate fbaileysr Towing, Tow Vehicles & Hitches 6 03-24-2004 07:58 PM
