11-20-2014, 12:22 PM
2014 27' Flying Cloud
New Bern
, North Carolina
Size of socket for lugs
I have a 2014 27FB Flying Cloud. I am having difficulty finding the correct socket size for the wheel lug nuts. The problem I am having is the sockets I have is too large for the walls of the holes of the rim. I know this isn't very clear but hopefully someone will understand what Im attempting to communicate.
11-20-2014, 12:23 PM
Oswego
Thin wall deep well 3/4" socket will work.
-Rich-
11-20-2014, 12:26 PM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
You need a 3/4" six sided deep socket, preferably for a 1/2" drive. Most torque wrenches for the torque that you need are 1/2" drive.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
11-20-2014, 02:16 PM
1974 Argosy 20
Kooskia
, Idaho
At Wal Mart I found a very nice L shaped lug nut wrench with an offset so it would remove the nuts easily, and it had several sockets including the correct size. They are thin enough for the Airstream wheels and nuts, and the wrench collapses to a nice small size. Under $20. I just leave it in the trailer all the time.
11-20-2014, 02:36 PM
2014 25' Flying Cloud
Cuddebackville
, New York
And make it a 6 point.
2019 Ford Expedition Platinum
11-20-2014, 02:41 PM
Santa Rosa Beach
If you want to stay on top of the torque value on the lug nuts on your Airstream, you are going to need to have a torque wrench with values up to about 150 ft.lbs.
Brian
11-21-2014, 11:37 AM
2013 30' Classic
Greenwood
, Mississippi
Why does my lug wrench go on most of the lug nuts easily, but it won't go easily on a couple? Are the lug nuts steel with a chrome cap on them that might be bent/warped/distorted?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
11-21-2014, 11:38 AM
Oswego
Yup.
-Rich-
11-21-2014, 12:15 PM
2016 28' Pendleton
Scottsdale
Hi from AZ. . .as Rich said " yup" just replaced mine with solid steel nuts, not chrome caps, no more worries thank you. regards, Craig
WBCCI 2851,4CU
11-21-2014, 05:19 PM
2022 25' Flying Cloud
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden
Costco has the solid chromed nuts. I replaced mine when I had the Michelins put on.
11-21-2014, 06:01 PM
2013 30' Classic
Greenwood
, Mississippi
What would be the interest/purpose in making something cheesy like lug nuts with chrome covers?
TAC #MS-10
Airforums #70955
11-21-2014, 06:03 PM
New Bern
, North Carolina
11-21-2014, 06:39 PM
Lexington
, Oklahoma
Van1,
I also have a 2014 FC. When I went to torque my wheel nuts for the first time I experienced the same problem you described. I had to hammer the socket on two of the nuts to get the socket on. When I removed them I found the Chrome cover was cracked on both. I assumed I had cracked them during removal but went ahead and checked the "good" nuts and found a total of 15 of the twenty four nuts had cracked outer covers. My concern was two fold. First with the outer cover cracked its looser on the nut and could slip a little giving a false reading when I torqued them. Secondly, In the event I needed to remove the wheel while on the road. I didn't want to get in a situation where I had to ruin a nut getting it off and not having a replacement. I ended up replacing all mine with McGuard Tough Nuts. They are a solid chrome nut, made in the USA.
Good luck!
2013 31' Classic
billings
, Montana
Amen...
11-21-2014, 06:41 PM
New Bern
, North Carolina
Stream....where did you purchase them?
11-21-2014, 06:46 PM
Lexington
, Oklahoma
On line. Google McGard Tough Nuts. I ordered the 1/2-20, PN 64010.
11-21-2014, 07:09 PM
ToyHouse
2014 27' FB Classic
Quesnel
, British Columbia
Van1: I realize your question regards the rims on your AS but let me relate an issue I have with some after market rims for my tow vehicle. These rims also require a thin wall 3/4" deep socket for the wheel nuts. In addition I have to exercise some care with the sequence of tightening the nuts. I have to torque each nut finger tight first before I really start to apply any serious torque. If I don't do this or the tire shop doesn't do this, the result is identical to your problem. If one of the first 2 or 3 nuts is torqued too much at the start it seems to tilt or pull the rim cockeyed just enough that the eigthth nut (in my case) and socket interfere in the final bore. Yes the deep socket is a 6 point and not a 12 point.
.....Tom
11-21-2014, 07:10 PM
New Bern
, North Carolina
Thank you all for the info
11-21-2014, 09:36 PM
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
Or ...19mm socket ...
