Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Flying Cloud > 2009-2015 Flying Cloud
Old 09-16-2015, 11:40 AM   #1
2010 25' FB Flying Cloud
Snoqualmie , Washington
Replacement External Storage Handle/Lock Mechanism?
On my 2010 25FB, the curbside storage door handle / lock is very sensitive; and if i unlock it and turn it past ~30 degrees as i open it, the locking mechanism gets stuck in the open position. I ended up having to take it all apart. I am wondering if there is a better replacement?
Anders79 is offline   Reply With Quote
Old 09-16-2015, 11:43 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Check out www.ch751.com.
MICHAEL
Old 09-16-2015, 10:04 PM   #3
2014 27' Flying Cloud
Wenatchee , Washington
replace external storage handle/lock mechanism?
Thanks for posting the link. I had no idea... and our 27FB has the same lock. Will get right on this when we return home.
2018 Ram 3500 SLT CTD 4X4 pickup
2014 Airstream Flying Cloud 27FB
WBCCI #7180
21Airstream is offline   Reply With Quote
Old 09-16-2015, 10:30 PM   #4
olympia , Washington
Thanks for sharing that link AWCHIEF. I've added it to my reference list for when I get my AS.
Xicaque is offline   Reply With Quote
Old 09-17-2015, 04:39 AM   #5
Airstream12557's Avatar
2015 30' Flying Cloud
Evansville , Indiana
I don't know when Airstream changed the storage compartment locks, but my 2015 Flying Cloud locks are not the CH751. They are a Southco lock.
Airstream12557 is offline   Reply With Quote
Old 09-17-2015, 07:42 AM   #6
daboose's Avatar
2014 25' FB Flying Cloud
Matthews , North Carolina
Images: 11
My key has "SOUTHCO" on one side and "CH751" on the other.
I need help on this one: can you use the CH751.com lock when the storage locking mechanism has the cam/locking arm separate from the key-lock device?
Thanks.
ID:	248269   Click image for larger version
daboose is offline   Reply With Quote
Old 09-18-2015, 05:34 AM   #7
daboose -- My key has Southco on one side and a two letter, three digit code on the other side. I also have a CH751 key for the outside shower compartment. My Southco lockset looks like your photo above. The CH751 key looks to be a stamped key, since the plating is around the notches (it is apparent it was not a cut key). The Southco key is a cut key and the notches are different than the CH751.
Old 09-19-2015, 07:00 AM   #8
AWCHIEF's Avatar
Images: 33
daboose, I would give ch751.com a call and ask them your fitment question. They were very helpful when I called.
MICHAEL
Door lock mechanism SilverEagle6 Exterior Storage Compartments & Access Doors 5 11-16-2017 11:36 AM
Window opening/locking mechanism replacement jtsanchez Windows & Screens 5 05-14-2012 11:47 AM
Changing lock mechanism on coach door. robber2711 Land Yacht/Legacy Motorhomes 6 08-23-2011 08:07 AM
Lock mechanism for refer door 1978 jkrauk Exterior Storage Compartments & Access Doors 0 08-23-2008 04:58 PM
