Old 08-10-2014, 10:48 AM   #1
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden , Colorado
Refrigerator front panel coming off.
On our 2012 refrigerator the stainless steel front panel has come completely loose the full length at the front edge of the door frame on the open side. I don't see any glue or tape and can not seem to push the outer door frame back in to cover it. Any others with same? Suggestions?? I won't mention how old all the constant little issues that pop up nearly every trip are getting. Love the design hate the build.
2015 30' FC Bunk, Dual A/C, Full Awning, RV550, Sleep Number, ProPride, Nokian Rotiiva AT 15" Tires
2015 Chevrolet 2500HD 4WD Duramax/Allison LTZ Crew Cab Short Bed, Huper Optik, Bull Dog Spray In, Roll-N-Lock, Full Amsoil, Denali SoundBomb, Yakima
2012FB is offline   Reply With Quote
Old 08-10-2014, 01:13 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If it was frame issue and a floating panel the hole panel would have come off once the edge was away from the frame. That and the fact the panel is still held in place tells me it was glued on originally. If you can work to rest of the panel free without putting bend in it you can put it back with contact cement.
If you go that route remove the door and place it on a table. Apply the cement to both the panel and the door and after it has dried for 15 minutes. Test a small piece of brown paper first to make sure it does not stick to the cement. Place 2 pieces of brown paper on the door so they overlap a few inches at the center of the door. Make the upper piece of paper so it just touching the upper door frame. This gives you an edge for alignment of the panel. With paper in place place the panel on the paper and align at the top edge. Check the bottom corners to be sure they fit within the frame. Alignment is important as you are only going to get one chance. While someone hold pressure on the panel half along the top edge lift the lower edge enough to remove the lower piece of pager and fold the panel down into place from the center out. Once the lower half is secure lift the upper half and remove the paper and fold the panel down into place.
Normally when applying Formica to a counter top you would have an edge that could be finished off after the panel was set. You don't have that advantage so make sure the alignment is correct before you remove the paper.
2004 Excursion 4x4
Old 08-10-2014, 11:01 PM   #3
daveswenson's Avatar
2012 28' International
Issaquah , Washington
The stainless panel floats and is not fastened. You should be able to slide it into position so the edges are covered by the frame which snaps on.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Refrigerator Front Door Panel SGT DAVE Sprinter and B-van Forum 4 04-26-2014 10:55 PM
5 day trip coming up- Refrigerator question bendstream Electrical - Systems, Generators, Batteries & Solar 7 07-20-2013 06:46 PM
Noise coming from behind panel board AirEPotter General Repair Forum 8 07-16-2013 05:16 AM
The welder is coming, the welder is coming... Safari Tim General Interior Topics 13 09-01-2006 10:00 AM
The Airstreams are Coming!! The Airstreams are Coming!! j54mark Airstream "In the News" 7 07-07-2005 07:06 AM
