Old 04-04-2015, 12:29 AM   #1
2016 30' International
Scottsdale , Arizona
Recliners to replace sofa
Has anyone replaced the sofa with two recliners?
We are experienced RVers and have learned that RV sofas are not comfortable for us for more than a few minutes, but recliners are perfect for hours. So, for the Airstream we are considering... we're going to have to get or convert to recliners.
I know that the 2015 International 30 and Flying Cloud 30 have recliner options and we're considering those, but they're hard to find. So, I was wondering if converting from a sofa model to two aftermarket recliners is a viable option. Has anyone done this? What are your thoughts on this?
We're looking at 30' 2015 models and it seems that there are no components under the sofas that would need to be moved, if converting to recliners? Is this true and does it apply to the slightly shorter models as well?
DHart is offline   Reply With Quote
Old 04-04-2015, 06:43 AM   #2
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Check the interior restoration and remodeling threads on here. A lot of us have done that conversion, it can be simple, or very complicated, your choice. I just finished an interior remodel of a 1996, 34' Excella 1000.
If you are doing your own work, it would help to have a fairly well equipped shop.
Larry C
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 04-04-2015, 06:54 AM   #3
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
I've done it twice. Simple fix to uncomfortable couches. Now have a 2015 which we ordered with AS recliners. If you do it look for the narrowest, wall hugger you are comfortable in. Simply remove the interior you no longer want and install the recliners. In our 25' I did not fasten to the floor, but secured them with a bungy cord while moving. On our other 30' I screwed them into the floor. In both cases when we sold the units I put the original interior back in.
SAFE TRAVELS
Bud
Starting to Look (AGAIN) Number 5 Hopefully
USAF Training Instructor (TI) - 68-72
Old 04-04-2015, 07:27 AM   #4
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
The secret is finding the right recliner that will not only fit in your Airstream without taking up all of the room in the living area but also to fit through the door. You will never miss the old back breaker couch. Here are some pics of interior of my 1976 Sovereign including the 2 wall away recliners. These fairly small footprint recliners that don't take up a lot of room and the fold up tables on both sides still work as well.
Airstream Interior 2010.pdf
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 04-04-2015, 08:33 AM   #5
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Our trailer was converted at JC for the original owner. The only thing that doesn't work well is eating while seated in the recliners. If you can find some that don't rock or lock out the rocker mechanism that would be better than trying to eat off of tv trays with the chair rocked back which happens as soon as you sit in it.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Old 04-04-2015, 08:46 AM   #6
Good to know that we're not alone in finding the sofas to be terrible to sit on for more than about 2 minutes.
I looked under the sofa on a 2015 International 30' and didn't see any battery boxes or equipment that would have to be moved. Where does Airstream put the battery boxes on these new units? Looked like they might be under the side closet?
Old 04-04-2015, 09:13 AM   #7
carver 1's Avatar
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo , Florida
Images: 30
Just to give you an idea what we did on our previous 25' International. The recliner is made for RVs with a width of 25". It was previously in our 35' Nu-Way Premier 5th wheel. there were two in her in addition to the couch. We relocated the recliner to our living room and then to the AS when we made the changes with the flip top replacing the original table. When we sold the 25' this was a big plus for the buyer. Our 30' Classic has the couch and we love it. The PO changed the foam and replaced it with much firmer and I would not think about replacing and loosing the ability to use as a bed for the possibility of extra sleeping space.
>>ron<<
Name:	my solution (1).JPG
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
carver 1 is offline   Reply With Quote
Old 04-04-2015, 10:50 AM   #8
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
I used two recliners from a theater room I had in my home. You're so right about functionality - these are a huge improvement for us.
Cheers,
John
John & Vicki
WBCCI #4291
Two roads diverged in a wood, and I took the one less traveled. ~ Robert Frost
John&Vicki is offline   Reply With Quote
Old 04-04-2015, 11:15 AM   #9
Did Airstream move the batteries and aux. equipment away from under the front sofa to somewhere else on the trailer, on the 2015 30 footers?
Old 04-04-2015, 11:19 AM   #10
paiceman's Avatar
We have a 30' 2015 FC, batteries are outside on the tongue behind the propane bottles in a metal box. Were on our 2010 25' as well.
SAFE TRAVELS
Bud
Old 04-04-2015, 11:30 AM   #11
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
I switched from a 25 Cloud to a 30 Cloud for that very reason. They are working exceptionally well. Along with the fold up table in front of the recliners is almost like adding another room to your Stream. Totally comfortable.
TinCan
graysailor is offline   Reply With Quote
Old 04-04-2015, 11:38 AM   #12
mineral , Virginia
Yes, we replaced our sofa with 2 recliners and love it.
Mrhany is offline   Reply With Quote
Old 04-04-2015, 12:33 PM   #13
Argy 78's Avatar
1978 Argosy 27
Fenton , Michigan
We replaced our kitchen table/sofa on our 78 Argosy with 2 Lane swivel recliners with ottomans and have truly enjoyed them. Yes you do lose the eating table but we eat outside most of the time and if we eat inside we just use some plastic eating trays or go out to dinner.
Argy 78 is offline   Reply With Quote
Old 04-04-2015, 02:37 PM   #14
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
Noted question about getting recliners through door in AS.
Most recliners come with detachable backs - they are shipped that way - at least on the last 6 I have bought. They go through the Airstream door on their sides and you attach the back inside - takes two people to get through, one on the inside and one outside.
Also - about eating on them - the ones I bought the last time had a swing out and removable table built-in (they were made especially for trailers) to the arm rest - works great.
The last ones have the recliner lever on the inside of the arm rest so you can put them against the wall or bookcase which is neat in a narrow trailer.
Silver Hawk is offline   Reply With Quote
Old 04-04-2015, 02:38 PM   #15
2004 28' International CCD
Edmond , Oklahoma
Recliners replaced bench seat
We were in our 60's when we bought our 2004 International. Recliners were a must after finding the bench seating uncomfortable. After much measuring and research we found a website called Glasstop Furniture for Marine and RV. They had a large selection of recliners and material. My husband removed the seating across the front and left the portion where the breaker/fuse box /HWT/ and storage are housed. I can access the breakers without moving a chair. To access the HWT or storage I can easily move the chair out. No regrets here. It was simple.
Consue is offline   Reply With Quote
Old 04-04-2015, 03:47 PM   #16
ckottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We removed the bench seating and took it to Airstream to have the FC 30 Recliner factory components installed, plus build a storage cabinet.
ID:	235588   Click image for larger version
ckottum is offline   Reply With Quote
Old 04-04-2015, 05:56 PM   #17
ckottum... that looks great! Is that in the 25 foot model? Amazing.
Was your bench seating the "L-shape" setup where there was nothing under the sofa at the front of the trailer, but there is some equipment/storage under the sofa on the side?
The 2015 30' Flying Cloud we are considering has the L-shpaed sofa with no encumbrance under the front-end sofa, but there is some equipment or storage under the L-side sofa that might complicate our switching to recliners.
Did Airstream need to relocate any equipment from the side of your trailer when they converted to recliner set-up?
Old 04-04-2015, 08:07 PM   #18
2015 27' FB International
Mary Esther , Florida
Recliner
We built a cabinet and put in a recliner fb27 international
Grateful2 is offline   Reply With Quote
Old 04-04-2015, 08:36 PM   #19
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
Consue, love the red recliners!
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 04-04-2015, 09:47 PM   #20
ckottum's Avatar
This conversion is to our 25' Front Dinette model which is the only mid-size late model which has no equipment preventing the changes to be made, is pretty much open in the front and side when the dinette and bench seats are out.
Only the converter and inverter were on the side and towards the rear so we designed the cabinet that Airstream built over them. We added the drawers.
All things considered, you ought to look for or order a 30' Recliner model rather than convert to one. Our conversion was near $4,000 for components and labor. Certainly worth it to us, but not if Airstream had a stock model so equipped.
cheryl
replace gaucho with store bought sleeper sofa? nu2as Cabinets, Counter Tops & Furnishings 20 05-07-2019 05:30 PM
Sofa replacement with 2 recliners on 19 footer mocus Interior Restoration Forum 15 04-30-2015 12:44 PM
Replace gaucho with recliners? Anniedog General Interior Topics 19 02-05-2011 09:40 PM
Removing sofa and replacing with recliners. Bandits Cabinets, Counter Tops & Furnishings 13 09-25-2010 07:55 PM
Replace Gaucho with recliners? Anniedog Cabinets, Counter Tops & Furnishings 18 12-09-2007 05:19 PM
