Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Flying Cloud > 2009-2015 Flying Cloud
Old 08-09-2014, 09:40 PM   #1
2014 25' FB Flying Cloud
Monroe , Washington
Rabaldi over temperature cutoff
My 2014 25FB has a Baraldi Range hood and a three burner stove top. When all three burners are used the fan cuts off in about 4 to 5 minutes due to the heat load. It takes about 45 minutes to reset. I think it is a system design problem rather than a part problem.
2014 FC 25' FB
2014 Ford F-150 XLT 4x4 EcoBoost V6
EQ WD Hitch
waltc is offline   Reply With Quote
Old 08-09-2014, 09:52 PM   #2
AWCHIEF's Avatar
2006 23' Safari SE
Biloxi , Mississippi
Images: 33
Obvious question, is your outside vent cover unlatched and open?
MICHAEL
Old 08-10-2014, 05:09 PM   #3
Monroe , Washington
Yes, vent cover is open
2014 FC 25' FB
EQ WD Hitch
Old 05-04-2016, 09:32 PM   #4
From Beautiful Egg Harbor
2016 25' Flying Cloud
Egg Harbor , Wisconsin
Waltc. What was end resolution. Our 2016 25fb delivered last month has same problem. Fan stops when using range from heat sensor. Thanks.
efaehw is offline   Reply With Quote
Old 05-04-2016, 11:46 PM   #5
Monroe , Washington
We had the Baraldi heat sensor bypassed last October. It has been working fine since then. It was done on warranty. They drop the range hood and pull the motor and change the wiring.
2014 FC 25' FB
EQ WD Hitch
Battery Cutoff Swithes noiva Mechanics Corner - Engines, Transmission & More... 19 05-28-2018 09:27 AM
Shower cutoff? mocus Sinks, Showers & Toilets 14 04-21-2012 02:19 PM
Battery cutoff switch contradiction - 2007 Classic dznf0g 2006 - 2010 Classic (all lengths) 0 09-29-2010 08:10 PM
Battery Cutoff Switch Silverbee Electrical - Systems, Generators, Batteries & Solar 16 09-13-2010 06:00 PM
