My 2014 25FB has a Baraldi Range hood and a three burner stove top. When all three burners are used the fan cuts off in about 4 to 5 minutes due to the heat load. It takes about 45 minutes to reset. I think it is a system design problem rather than a part problem.
2014 FC 25' FB
2014 Ford F-150 XLT 4x4 EcoBoost V6
EQ WD Hitch
Obvious question, is your outside vent cover unlatched and open?
MICHAEL
Waltc. What was end resolution. Our 2016 25fb delivered last month has same problem. Fan stops when using range from heat sensor. Thanks.
We had the Baraldi heat sensor bypassed last October. It has been working fine since then. It was done on warranty. They drop the range hood and pull the motor and change the wiring.
2014 FC 25' FB
EQ WD Hitch
