Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Flying Cloud > 2009-2015 Flying Cloud
Old 03-25-2017, 08:50 AM   #1
Natick , Massachusetts
Newby question
Hi:
I'm new to the site. This question has probably been asked before but is there an SUV that can pull a 27' airstream?
Matt Kehoe is offline   Reply With Quote
Old 03-25-2017, 10:21 PM   #2
2018 30' International
2016 28' International
2010 25' FB Flying Cloud
St Augustine , Florida
Sure but a lot of consideration needs to go into what SUV and what anti-sway device you get.
Power to pull is one item, hitch weight is another, towing capacity, and where are you going to pull it (mountains you'll be going down or flat lands), all need to be considered.
I haul my 28ft with a Range Rover Sport but that is in relatively flat Michigan and with a ProPride hitch. Larger mountains like the Smokey's, Rockies, etc., I use a truck as you can get pushed around pretty easy going down big hills using an SUV.
ArkFortyCal is offline   Reply With Quote
Old 03-25-2017, 10:28 PM   #3
Boxite's Avatar
2008 22' Safari
Yes,...the bigger the SUV the better.
Old 03-26-2017, 05:07 AM   #4
ShinyPete
ShinyPete's Avatar
2014 27' Flying Cloud
Bushnell , Florida
Matt-
Check out the "Towing & Hitches" subforum from the pick list at top left of the forum, and once in, there is a Tow Vehicles tab as well. Lots of good reading there to start your research.....
Hope this helps, and welcome to AirForums!
ShinyPete is offline   Reply With Quote
Old 03-26-2017, 09:00 AM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
First off, welcome to the Forums. We're glad to have you with us. As to your question, we have extensive experience in towing Airstreams all over the United States with SUV's. Our 25FB's weigh around 7,400# with a 900# tongue weight.
We have had two Airstream 25FB's (a 2005 and a 2015) over the past eleven years. We have towed them primarily with two Suburbans, a 2004 and a 2005. Both of these suburbans are the 2500 (3/4 ton). We still have the 2005 and tow our Airstream with it regularly.
Unfortunately, there are no more new 3/4 ton SUV's. Ford's last Excursion was made in 2005. GM discontinued their 2500's in 2014.
Our 3/4 ton Suburbans always did an adequate and comfortable job of towing our Airstreams. The 2500's have a more powerful engine (6.0 liter), heavy duty leaf spring rear suspension, and heavy duty brakes. The half ton SUV's that are still available are marginal tow vehicles for the larger Airstreams.
As our 2005 3/4 Suburban approaches 200,000 miles, we are hopeful that the suburban will soon get the new 6.2 liter engine and the eight speed transmission. The current Suburban's 5.7/6 speed falls short for towing heavy trailers adequately.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
moosetags is online now   Reply With Quote
Old 03-26-2017, 09:11 AM   #6
Mantua , Ohio
Moose tags, excellent comments!
Old 03-26-2017, 09:44 AM   #7
Granbury , Texas
The only one I know of currently that comes close is the Ford Expedition EL.
We used a Ford Expedition EL 3.5 ecoboost to pull our 23FB. It did a decent job but I'm not sure I would have been comfortable with any larger Airstream. The problem is the tongue weight and receiver hitch. Even with a weight distribution hitch I felt maxed out.
The Ford Expedition EL gives you added wheel base and independent suspension which helps. Ours had the tow package which now has a built in brake control and 31 gallon fuel tank.
We really liked the Expedition because of all the room inside and comfort. They are pricey and cost more than many trucks with better towing ability.
When we moved up from the 23FB in Airstream size we discontinued use of the Expedition and moved to my Ram SRW 3500 4x4 Megacab Cummins. That was a truck I already had and does a excellent job towing our 26U.
The pros say anything over 6000-7000 lbs should be towed by a 2500 /3500. Moosetags post above confirms that. Shame they stopped making that 2500 Suburban. That would have been a perfect SUV choice for your 27'.
cabinetmaker is offline   Reply With Quote
Newby question , exterior water drip Jackcat2 2006 - 2010 Classic (all lengths) 15 07-05-2013 11:50 PM
Newby question- cable input Jackcat2 Electronics & Connectivity 7 05-13-2013 07:25 PM
Newby Hitch Ball Height Question kscherzi Hitches, Couplers & Balls 8 02-14-2013 12:07 AM
Newby with roof question. AIRmason Clearcoat, Exterior Paint & Trim 2 10-16-2012 05:17 AM
Newby question, electric brake problem howco Brakes & Brake Controllers 5 06-11-2010 04:33 PM
