Old 06-07-2016, 06:39 AM   #43
Ravenna , Ohio
Originally Posted by jcanavera View Post
My failures looked like this. Note the failed tire next to a good tire.
These are the E rated Maxxis tires. Air infiltrated between the belts and the tread. Lucky I caught these prior to blowing out on the road.
Jack
Did you report the failure to NHTSA on their complaint form? Without numbers action to improve quality and fitment questions of tires on RVs will not improve.
Tireman9 is offline   Reply With Quote
Old 06-07-2016, 06:42 AM   #44
Ravenna , Ohio
Originally Posted by Boxite View Post
And your point is....?
The punishment delivered to tires by a 2 or 3 axle trailer is quite different than to a single-axle trailer due to side-loading, twisting, mis-alignment of axles, and such. The Bambis have a much better record of tire durability due to lighter weights and less sidewall stress from maneuvering than multi-axle trailers.
This is not to say that Bambis don't occasion tire failures due to overloading, underinflation, old-age, lack of regular inspection, and other owner-induced problems.
The stress you are talking about have a specific name. Interply Shear.
If you Google "Interply SHear tire" you can learn more.
This is real engineering. Something that seems to be lacking in the RV industry.
Old 06-07-2016, 06:47 AM   #45
Ravenna , Ohio
Originally Posted by m.hony View Post
The tire placard on the side of my trailer says 65 mph.
I'm sure it has to do with weight, GVW, and tire size.
Until earlier this year when under pressure from US Government ST tires had speed limit of 65 mph. Some ST tires are now rated for 75 mph. Only tires with Speed symbol or specific words molded on tire sidewall are so rated.
According to the major tire companies, you know the ones with real R&D departments and understanding of tire usage in the US also limit speed to 75 in RV application no matter what the individual tire rating is.
Old 06-07-2016, 02:30 PM   #46
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
The point is moot.
I won't be buying any more ST tires.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
m.hony is online now   Reply With Quote
Old 06-07-2016, 11:26 PM   #47
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Unfortunately I didn't think about this aspect. Since this was my second set of ST tires with belt slippage in roughly the same period of use, I attributed it to the fact that expecting a full three years of life in my specific application was not reasonable for an ST tire. Note that I said "my specific application", since I know others get much better life. On the other hand those folks aren't pulling trailers that sit on a tandem axle and weigh between 8,600-9,100 lbs.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-08-2016, 12:21 AM   #48
1991 25' Excella
Stanfield , Oregon
My st rated tires Carlisle hd radial have an M speed rating which is 81 mph
SpletKay06 is offline   Reply With Quote
Old 06-08-2016, 03:07 PM   #49
Ravenna , Ohio
Jack
IMO even ST tires should not have this type of failure in 4-5 years.
Old 06-08-2016, 07:47 PM   #50
Tyvekcat's Avatar
2014 28' International
Blacksburg , Virginia
Hercules
I plan to get a set of Hercules tires when the Goodyears time is up.
They make 15 inch tires in Load range ' D' and ' E ' . I have owned them before and never had an issue with them on my previous travel trailer over a three year span.
A friend of mine recommended Hercules to me as he had them on his Horse trailer. 36 month warranty.
They are hard to find. check their website out , it has a chart on load ratings. http://www.herculestire.com/tire-gal...ial/specialty/
If you don't run that ' solid white line' you lessen your risk on picking something up in a tire.
Have a good one
Ra, Chelle & Natasha
For my next trick, I will use my new Airstream & Dodge Ram 2500 CTD to make this pile of money disappear.
Tyvekcat is offline   Reply With Quote
Kendra K31M tires 10ply with load range E, LeeJ Tires 4 12-13-2013 10:05 PM
Tires for 1987 Excella 8300 lbs. Load Range D or E? barbann Tires 7 05-24-2011 06:33 AM
Maxxis Tires -Load Range? Wingeezer Tires 43 12-11-2010 02:35 PM
Load range D instead of C? Tom Nugler Tires 32 05-26-2010 02:48 PM
1/2 ton tires- load C to load E John Tires 75 03-20-2009 10:15 AM
