Old 05-08-2015, 04:02 PM   #15
ckottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I would wonder how two drawers broke in one trip, they just sit there. Or are they breaking while be used? Something may be shaking the trailer up badly. It could be very, very poor construction of the equipment, or the trailer is getting roughed up going down the road. Or both.
Are you on really rough roads? What do you tow it with and what weight distribution hitch do you use?
cheryl
ckottum is offline   Reply With Quote
Old 05-11-2015, 02:25 PM   #16
gpt
2014 25' FB Flying Cloud
sequim , Washington
2014 25'FB, very minor issues all of which were promptly dealt with. patience to no end as we were trying to learn how everything operated. good dealer in Covington (AS-NW) if you ever have to stop there.
gpt is offline   Reply With Quote
Old 05-11-2015, 04:41 PM   #17
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Originally Posted by DKBoger View Post
They don't make them like they use to.
But they are a lot more complicated than they were back then, so there are a lot more chances for something to go wrong.
2012 Dodge Durango Hemi/AWD
Old 05-11-2015, 04:52 PM   #18
2016 30' International
Scottsdale , Arizona
Originally Posted by ckottum View Post
There are Airstream repair shop owners on this forum (and our Airstream Owners Manual) who advise against heavily sprung tow vehicles and too-rigid weight distribution hitches roughing up the Airstream. Another concern is out of balance trailer running gear. These may be a contributing cause.
Cheryl... I am very new to WD systems and have a couple of questions...
1) Is a 3/4 ton Sierra Denali too "heavily sprung" for a new 30' International?
2) is it easier on the Airstream to have little-to-no WD applied? (I don't think we would need much, if any, WD when pulling the 30' Intl. with the 3/4 ton Sierra.)
DHart is offline   Reply With Quote
Old 05-11-2015, 05:02 PM   #19
silverbp's Avatar
LaMarque , Texas
I have a 2014 FC25 FB. Love it but my issue is with the Hinges on the storage compartment below the twin beds. There are large trays in each to place stuff in. When your removing these trays its really very easy to hit the hinge release and the hinge pops off and door comes off. I came up with a fix. I placed a strip of wood behind each hinge that blocks the tray from hitting the hinge release. Oh well seems to work.
Sent from my iPhone using Airstream Forums silver bp
silverbp is offline   Reply With Quote
Old 05-11-2015, 05:20 PM   #20
Wayne&Sam's Avatar
Images: 21
Yes that's always a problem for me too. The forward cabinets use a different hinge that avoids the problem. I don't see why the releasable hinge needs to be used.
Probably my biggest complaint is that they don't align two receptacles that are right next to each other. Looks very shoddy.
Old 05-11-2015, 05:49 PM   #21
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Great idea! I'll be doing that to New Lucy.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 05-11-2015, 06:00 PM   #22
Gypsy Travelers
Deanna Brown's Avatar
2015 30' Flying Cloud
We recently bought our new 2015 30 ft Flying Cloud and have had it now for just two months as of tomorrow (I know not enough time to really chime in). We used to be owners of another brand that never had any issues, but there is no way we would trade our Airstream for any other trailer.
We had a couple of minor issues on the new trailer; small leak (drops) under our kitchen sink where our water filter is, but that was a quick fix and once we had a tiny leak behind the toilet where we just needed to tighten the fitting- no big deal. Although it's only a short time, we have been out just about every weekend and part of some of those weekdays too. I know we have a lot of time ahead of us to really see how she does, but I have every confidence that it will be ok. I had same worries, gee I paid good money for my dream, but I want it to be perfect and last forever and I don't want those kind of surprises!. BUT, well see...we are trying to keep in mind that this our second home, and it will get wear and tear, and we just need to keep moving when it does.
Good Luck with your trailer!
Deanna Brown is offline   Reply With Quote
Old 05-11-2015, 08:08 PM   #23
ckottum's Avatar
We were able to soften the ride of our truck and Airstream by switching to a w.d. hitch with more flexible tapered w.d. bars, moving much of the interior weight in the front of our Airstream toward the center (not the rear where it may amplify sway), and moving all weight loaded in the truck bed to forward of the truck's rear axle (truck bed weight behind the truck's rear axle should be added to the trailer hitch weight when determining size of w.d. bars because the w.d. system must lift both to transfer weight). The result was less tension needed and more flexibility of the w.d. bars.
Setting a heavy trailer on the truck hitch receiver, especially if the truck bed has additional load, will lift weight from the steering axle to some degree and possibly reduce braking and steering control. More so when the roads are slippery, we've had that happen with an inadequate w.d. hitch.
The heavier the truck's suspension, the longer the wheelbase, the more tension needed and difficulty to transfer hitch weight.
Most w.d. hitches also provide sway control or friction sway bars can be added. There are a couple of very expensive hitch designs that eliminate sway.
We went through a few hitches and experimented with w.d. before finding an adequate, relatively smooth setup. Search weight distribution for good sites on proper setup. Probably good to take advice on various forums with a grain of salt, including mine. Learn what will work for you.
Old 05-11-2015, 10:26 PM   #24
gpt
sequim , Washington
Brian
duct tape! all of you do carry a roll don't you???
gt
Old 05-11-2015, 10:32 PM   #25
Thanks for the comments... sheesh... this gets really complex very quickly for someone who has never pulled a trailer before. (5th wheels and motorhome experience only).
Old 05-11-2015, 10:43 PM   #26
mefly2's Avatar
2015 25' FB Eddie Bauer
Two out of three of our new AS have had issues ... self-repaired all problem areas with factory support on parts. There is nothing else to consider except AS if you want long term longevity ... it seems most others shake apart in 5-7 years.
Old 05-11-2015, 10:47 PM   #27
Durango , Colorado
We have a 2015 International Serenity that we picked up last September.
We have already put about 5000+ miles on it, and have used it a fair amount. We live at 8000 feet and the Airstream was covered with about 3 feet of snow for a few months.
So far, no issues. No leaks detected. No molding or drawer issues. We couldn't be happier. The only thing to have happen was a rock flew up and put a pit in our window guard. However that is not an Airstream problem but a poor road condition problem.
I am very pleased with the quality of my Airstream and hope to use it a lot this year.
RVDreamer is offline   Reply With Quote
Old 05-12-2015, 12:05 PM   #28
gpt
sequim , Washington
i now tow a 25'FB with a F350. i am using a blue ox hitch. 7 links is not enough, 9 links are too many. 'heavily sprung' is hardly the issue here. the real issue is setting up your WD hitch properly. you can experiment around a bit without damaging things and you to will learn which link set you need to use all the time with your setup. if the front end of the truck seems too light, not enough links. if the entire setup feels quite heavy and jerky out back, too many links. this is not rocket science, just give it a shot.
Normal to have issues with new Airstream Thomas_G On The Road... 42 05-11-2013 09:00 PM
New member, less than new AS, 1973 Tradewind with some issues aquinob General Repair Forum 14 10-13-2012 07:16 PM
New to us, New issues DryFly All Argosy Trailers 2 10-03-2012 06:45 PM
New Guy - floor issues jolson Member Introductions 3 01-01-2008 06:53 PM
weight issues with new cabinetry? simonhanbury Cabinets, Counter Tops & Furnishings 12 07-28-2004 06:56 PM
