Old 12-29-2015, 04:30 PM   #1
Living Riveted
2014 19' Flying Cloud
Carnegie , Pennsylvania
How long should fully charged batteries last when using furnace in 2014 flying cloud?
I recently did an overnight at a nearby barn where the owner let me boondock and stay overnight. The evening got progressively colder, and eventually hit the freezing point and we got a nice layer of snow. This was my first time using the AS in cold weather, so I was excited to try it out and use the furnace to keep warm (there was no option to connect to electric, so I could not use the heat pump the furnace was the only option). I set the furnace to keep the AS at about 60F through the evening hours since my dog was in the AS (2014 flying cloud) while I was in the barn with the horses. Once I settled into the AS for the night, about 10 PM, I adjusted the thermostat up to 65F to get it a little warmer in there, as the temperature outside was dropping. I noticed my AS batteries were depleting at a pretty good pace through the evening, but I figured that since I had fully charged batteries it would surely last a while even with the furnace kicking on and off. At about 2 AM, the battery charge dropped low enough that it would not start the furnace which made for a very long, cold night. By 7 AM, it was so cold inside the AS that I had to go outside, back my TV up to the AS, plug the AS into my TV, and keep the TV running. This began to charge the AS batteries and eventually I was able to turn the furnace on again and warm up the AS for the morning hours. My question is this does that seem normal to you? I have heard of people using their AS all through the winter and staying warm using the furnace are these folks in a campground somewhere connected to electric? It seems disappointing to me if the system is not designed to allow the furnace to come on and off through several cold days and nights without depleting the batteries. Please share any thoughts. Thank you!
Arnoldjeff is offline   Reply With Quote
Old 12-29-2015, 04:41 PM   #2
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
In that temp, yes normal furnace use draws the battery's down fast. A small generator will solve that problem & assure you & you dog a warm comfortable night.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 12-29-2015, 05:03 PM   #3
1974 Argosy 20
Kooskia , Idaho
The furnace in your 19 is probably the same one that is in my FC 20, that is a single outlet, relatively small furnace. Mine takes 3.6 amps with the burner on, and 2.9 amps with it off (in cool down mode). That is not enough to run your batteries down in the time frame mentioned, even if running full time, which I am sure it was not. Mine would drive me out of the trailer if run full time.
So, I have to conclude that either your batteries were not really fully charged, or more likely that they are not good. The two batteries should have a capacity of about 150 amp hours, that is they should supply your 3.6 amp load for 41 hours of run time. Since we prefer not to draw them down to less than 40%, that still would be 25 hours leaving some reserve in the batteries. Even with the refrigerator and water heater load, and some lighting use, you should get about 24 hours of use even with the furnace running.
It is common for the batteries to have a relatively short life if not kept fully charged, but not overcharged. Unfortunately the Airstream converter/charger supplied will often damage the batteries if left plugged in full time.
And if you have partly discharged the batteries and left them without recharging within a few days, you probably have damaged them.
I am not accusing you of battery abuse.... lol, but it may have happened by accident. Here is a post I did on the subject.
http://www.airforums.com/forums/f449...ml#post1602327
I hope that helps some.
Old 12-29-2015, 05:12 PM   #4
crisen's Avatar
2012 25' FB Eddie Bauer
Fairbanks , Alaska
On our 25' with (2) batteries we run the furnace overnight while traveling in cold weather without a problem. If it is very cold, as in sub-zero, I will plug in the generator for a while in the evening while we running more load, vent fans etc. Always shut it off before bed and things are fine overnight.
We do keep the furnace on while driving in these temps so the trailer is not stone cold when we stop. Typically run in the furnace at about 45-50F going down the road, mid to upper 60's in the evening and lower 60's at night. Coldest we have done this is -26F a couple years ago.
Rick
"When you find yourself in a hole - quit digging!"
2012 1/2 Eddie Bauer, 2016 Ram Laramie 3500 SWB 4x4 6.7L Cummins 68RFE
crisen is offline   Reply With Quote
Old 12-29-2015, 08:00 PM   #5
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
Doing the math:
Battery AH (amp hour) rating divided by 2 is the workable power available. Assuming you were at 80% charge.
Heater draw in amps time minutes run per hour divided by 60 gives AH per hour.
Not knowing your batteries or draw here is a guess:
80 AH battery de-rated to 64 AH. Half of that would be 32 usable AH.
4 amp heater, run at 30 minutes an hour is 2 AH used per hour.
Giving you 16 hours of heater run time.
Sorta sounds like your battery(s), and charging system needs fixing.
sgschwend is offline   Reply With Quote
Old 12-29-2015, 08:46 PM   #6
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I am willing to bet that your batteries were either not fully charged to begin with or have been damaged by the use of the stock Airstream charger. There are lots of threads on this forum about the negative aspects of the stock Airstream charger. I'd suggest you read them for background and then, assuming you believe that you did start out with fully charged batteries before the episode you described, find someone in your area who can properly assess the health of your current batteries. If they are bad, then you need to get new ones and also a three stage (or smart) charger so you can take care of the new batteries properly.
Bob Martel
WBCCI# 5766
Old 12-29-2015, 10:29 PM   #7
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
I'm with the others when they guess that your batteries might not have been topped up of you have a bad one.
We use our furnace a lot as we live in Canada and using it for a night without being plugged in should not be an issue at all. I have even gotten a couple nights out of ours on occasion.
Hope this helps
Cheers
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 12-30-2015, 04:27 AM   #8
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Started at "evening hours",stock batteries?, 32* & colder.....6pm? to 7am @ 60-65 pretty normal.
But test & ck the build date they could be 3+yrs old, and they may have been abused while on the dealers lot.
PFC
RLC
Step aside Starbucks, this is a job for alcohol.
Old 12-30-2015, 12:18 PM   #9
Stay CazuaL
cazual6's Avatar
Reseda , California
I was informed by the dealer to use the Furnace function, but if I am plugged in to either shoreline or generator, what does the heat pump do?
ArnoldJeff, I would also highly recommend you change factory installed batteries to AGM batteries. I would also recommend you get solar just to keep them charged while not in use. Keeping your AS plugged in all the time will cause life of some sort to go short, whether the batteries or other components. I got a single panel solar, which would be enough to charge the batteries during the day.
cazual6 is offline   Reply With Quote
Old 12-30-2015, 12:24 PM   #10
Gainesville , Florida
Heat pump not much use below 40 degrees.
Old 12-30-2015, 12:52 PM   #11
1994 34' Limited
colebrook , Connecticut
running furnace on batteries
when boondocking overnite in my 1994 34' classic i leave the trailer plugged in to my truck. i have a dodge ram diesel and it has 2 large capicity batteries and i have 2 in the camper. I have ran the heat all night, used the lighting and water pump. The truck always had enough battery left to start in zero weather. the furnace could not keep the temperature up without using my big buddy propane heater. i used propane faster than battery lol.
malett is offline   Reply With Quote
Old 12-30-2015, 01:53 PM   #12
kdickinson's Avatar
1969 23' Safari
Palmer Lake , Colorado
we found that the furnace fan will deplete the battery in our trailer, which only has one battery (I think the new models have two now) in about 2-3 hours depending of course on how much it is running. Having the battery run out on us on a cold night that was just getting colder and no electricity to be had led me to buy a back up heater. There are several good ones out there but I settled on a Camco catalytic with a quick connect to the LP supply in the trailer. The catalytic heater requires no electricity.
kdickinson is offline   Reply With Quote
Old 12-30-2015, 04:15 PM   #13
gecko's Avatar
2009 28' International
Pacific Palisades , California
Good luck with that! In our initial shakedown cruise, we managed to drain both the AS batteries and the TV batteries by morning--not a happy situation out in the boonies! Since then we've upgraded both our battery bank and the factory solar, and have not had problems.
gecko is offline   Reply With Quote
Old 12-30-2015, 04:31 PM   #14
2015 30' Classic
Pleasanton , California
Understanding your battery use is key to healthy batteries and your comfort when boondocking. I haven't taken a poll but I would guess that a majority of the folks that boondock often have already invested in a battery monitor. This will display your available battery capacity and show you in real time how much current is being drawn from your batteries. This piece of equipment is key to understanding and caring for your system. Trimetric makes a nice unit if you're not looking to add a solar charger in the future. If you are considering solar, then Blue Sky has an optional battery monitor that also works very well.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Batteries say charged but nothing works OKJerry Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 6 06-12-2011 07:03 AM
Best way to keep 12V charged when not using unit kentuvman Batteries, Univolts, Converters & Inverters 7 04-26-2010 02:04 PM
Are my batteries being charged? Bobdes Electrical - Systems, Generators, Batteries & Solar 13 12-23-2009 06:47 PM
How long should my batteries last? Pops Batteries, Univolts, Converters & Inverters 5 08-12-2009 10:53 PM
Can't get batteries charged -- why not? neil.ervin Batteries, Univolts, Converters & Inverters 23 11-14-2004 07:24 PM
