Old 07-06-2015, 10:09 PM   #1
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
Hit pothole and wow
One pothole, two problems
Took our 2013 25FB out for a trip last week. The first leg was down I-25 from Longmont to Monument, in Colorado. This road has lots of bad concrete pavement that causes our rig to porpoise. We usually have our upright cushions fall over, sometimes tumble to the floor, when traveling this road.
This time, we also hit worst pothole we have ever encountered at speed. When we stopped in Monument and opened the trailer door, we found the table had come completely detached from the wall. It was rotated 45 degrees with one corner on the floor. The big seatback cushion that is belongs next to the door was on the floor in the entry way. This cushion has never moved before.
We see that there is nothing but gravity to hold the table in its brackets. Is that the way it is supposed to be? Or perhaps the factory left out a piece on our rig? My wife did a search for table hardware, and found that at least one brand is sold with an extra piece that holds the rod in its brackets, which would prevent the table from coming loose.
After straightening up, we set the fridge from electric to propane, and went to a restaurant for lunch. Upon returning, we found an error code on the fridge. We identified the problem as a possible bad electrode, so we bought and installed a replacement electrode. That got the fridge working.
We assume the bump caused the electrode to fail, though the failure could be unrelated.
SSquared is offline   Reply With Quote
Old 07-06-2015, 10:21 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Wow... they probably know about this, but I would report that to the HWY dept...
Watch your tires VERY closely..
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-07-2015, 05:24 AM   #3
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
If it were me I would also have the axle alignment checked.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 07-07-2015, 05:38 AM   #4
Lily&Me's Avatar
Normal , Illinois
I hit a deep road rut in a town yesterday, and my frig popped open.
That has never happened before.
Maggie
Old 07-07-2015, 07:24 AM   #5
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
It's sad that road conditions are deteriorating so much across the country. Some states do better than others (Florida is a standout in this category.) Unfortunately, most other states do a poor job of maintaining their roads. Our state of Michigan is notoriously bad. On our last trip we noted that Louisiana is giving Michigan a run for it's money in terms of having the worst roads and that Ohio, which used to have pretty good roads, is slipping.
Bob Martel
WBCCI# 5766
Old 07-07-2015, 08:07 AM   #6
2016 30' Classic
Erie , Colorado
If your table is the type that has a round metal bar that drops into a pair of u-channel brackets on the wall, allows it to drop down to the bed position then there is no safety latch. Big enough vertical movement could pop it out of the catch brackets.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 07-07-2015, 12:21 PM   #7
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Those brackets can be bent a bit to make the swivel bar more difficult to remove..
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 07-07-2015, 06:37 PM   #8
2010 27' FB Classic
Clearwater , Florida
Pot Hole
I have put many miles on our 27 FB Classic. The table was constantly falling down and disconnecting from the wall and the leg collapsed with just rough roads. I finally fixed the problem by screwing 2 sliding bolt barrels over the wall rod and screwing a hinge hasp into the floor and onto the table leg. This allows the table to fold down when I want it to. I haven't had a problem since.
manseyr1 is offline   Reply With Quote
Old 07-07-2015, 06:57 PM   #9
1979 23' Safari
Wayland , New York
Best option on the table is to put it down while traveling. Like stowing sink covers etc. the wall brackets and leg aren't the sturdiest, so putting the table down alleviates lots of potential for damage.
Old 07-07-2015, 08:56 PM   #10
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
This past winter all that "global warming" caused months of "global cooling" and it rained and froze (hard), snowed and froze, and most of our roads cracked and heaved. Now when it rains, the asphalt breaks into segments. No sooner than the Hwy Dept pitches a shovelful of hotmix into it, another hole will develop nearby. Big buck whack-a-mole. Or more correctly fill-a-hole.
I saw one last week that looked like an open manhole. And when it rains, it's invisible. Most of the locals know where it is. I pity the unwary traveler.
I do wish I had a Sikorsky Sky Crane to move my AS with. It would take boondocking to a whole new level.
And don't get me started on fuel tax....
NavyCorpsman is offline   Reply With Quote
Old 07-07-2015, 08:59 PM   #11
2013 27' FB International
mamaroneck , New York
Or you might trying to slow down a bit
jackanddiane is offline   Reply With Quote
Old 07-08-2015, 09:45 PM   #12
SSquared's Avatar
Longmont , Colorado
Thanks for the comments, everyone.
manseyr1, did you put your sliding bolts in a vertical or horizontal position? And what do you do with the hinge on the floor when you fold down the table? Do you pull out the hinge pin?
Old 08-06-2015, 06:59 PM   #13
wwhendr's Avatar
Longmont , Colorado
This is my first post. We just ordered a 27FB and should take delivery in late September. We are also in Longmont so perhaps we can get together and i can learn something from you.
wwhendr is offline   Reply With Quote
Old 08-06-2015, 08:47 PM   #14
SSquared's Avatar
Longmont , Colorado
Welcome to AirForums, and welcome to Longmont. PM sent.
For all AS folks in Colorado, I recommend the DenCO unit of WBCCI. They are a good bunch of folks, and we joined as soon as we got our Flying Cloud.
Pothole Damage to Propane Fill Panel Boxster1971 Sprinter and B-van Forum 8 03-17-2014 07:46 PM
Runners and Argosys hit the pavement. safari62 Airstream "In the News" 0 04-10-2012 07:32 PM
Hit and run-Grab rail damage? A W Warn General Repair Forum 11 08-11-2011 09:46 AM
Did you hit your fire extinguisher on the butt lately? femuse On The Road... 9 05-09-2003 10:15 PM
Attention: Driveway Campers _ time to hit the road ! femuse Our Community 5 04-04-2003 12:01 AM
