Old 09-20-2015, 09:37 AM   #29
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
In less than 2,000 actual miles I pulled the new 2015 23D International Serenity (it was trucked to the dealership), the dinette leg had worn through the really thin (cheap) factory linoleum. The factory flooring is being replaced with Marmoleum like we did in the Classic along with a 0.064" x 2" x 4" brass wear plate under the dinette leg.
So far, both of the dinette tables have remained attached to the wall when underway.
Old 09-20-2015, 10:23 PM   #30
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
Photo attached
Originally Posted by SSquared View Post
We've done two things for the table.
First, we attached the foot to the floor with a hinge. The hinge pin was replaced with a removable clip.
Second, we put a rectangle of rubber material behind each of the tabs in the upper wall brackets. That makes the table more stable in general (it had a tendency to shift when you put even a small amount of weight on the table corners.
We have not been on the road with these modifications yet.
Couldn't get the photo to upload yesterday, here we go:
SSquared is offline   Reply With Quote
Old 09-22-2015, 05:09 AM   #31
Long Island , New York
Originally Posted by HiJoeSilver View Post
Best option on the table is to put it down while traveling. Like stowing sink covers etc. the wall brackets and leg aren't the sturdiest, so putting the table down alleviates lots of potential for damage.
Ditto -- it takes a few extra minutes, but table down -- sink covers stowed -- is SOP when we hit the road.
Old 11-02-2017, 09:37 PM   #32
J-Dog's Avatar
2014 27' Flying Cloud
Fullerton , California
... we put a rectangle of rubber material behind each of the tabs in the upper wall brackets. That makes the table more stable in general (it had a tendency to shift when you put even a small amount of weight on the table corners...
If you had a picture of that, I would like to do the same. Our table has gotten kind of sloppy, and it's annoying when trying to do any type of writing.
J-Dog is offline   Reply With Quote
Old 11-02-2017, 10:12 PM   #33
SSquared's Avatar
Longmont , Colorado
I don't have a picture and won't be visiting the trailer for a while. But a picture won't show much....the rubber pieces are behind the metal tab.
By the way, the table has stayed stable since the changes. We've only taken it down once, when we needed to roll back the flooring to dry out after a leak.
Pothole Damage to Propane Fill Panel Boxster1971 Sprinter and B-van Forum 8 03-17-2014 07:46 PM
Runners and Argosys hit the pavement. safari62 Airstream "In the News" 0 04-10-2012 07:32 PM
Hit and run-Grab rail damage? A W Warn General Repair Forum 11 08-11-2011 09:46 AM
Did you hit your fire extinguisher on the butt lately? femuse On The Road... 9 05-09-2003 10:15 PM
Attention: Driveway Campers _ time to hit the road ! femuse Our Community 5 04-04-2003 12:01 AM
