Assuming that you are plugged into a working shore power outlet, assuming that you do have propane and it is turned on, assuming that all your AC & DC fuses/breakers are fine, and assuming that your hot water worked previously this camping season, I am going to suggest that you have a bad logic board. The logic board is the most likely cause of a simultaneous failure of both the AC and propane sides of the hot water heater. If you are handy you can replace the board yourself, otherwise, it's an easy fix for an RV mechanic. The Atwood hot water heater is used throughout the RV industry and just about any competent RV mechanic/shop will have the part and can fix it inside an hour.
Bob Martel
WBCCI# 5766
