Old 05-03-2015, 06:31 AM   #1
2012 25' Flying Cloud
Fort Worth , Texas
Heat Pump in 2012 FC 25 RB not cooling good
I have just bought a 2012 25 RB Flying Cloud. Took it out for a test run yesterday. The out side temp was 82 and the rear I'd the unit was in the sun. It has the front and rear rap around windows. 77 was the best it could get to!
It has a 13,500 BTU duo therm heat pump. Is something wrong with this unit or is it undersized. Live in Texas and it gets a lot hotter than 82.
Are any other 25' owners having the same problem or is it just mine.
Al
Amay is offline   Reply With Quote
Old 05-03-2015, 08:50 AM   #2
Ohiobrits's Avatar
2015 27' FB International
Howard , Ohio
Not sure if this makes a difference, probably does, try setting the thermostat to COOL not HP, in HP the unit is trying to heat not cool. I'm not an AC expert but from what I know, you are running the AC process in reverse, extracting heat from ambient air to heat the interior rather than extracting heat from the interior and dumping outside.
2015 27FB International Signature "Danielle"
ProPride / 16" wheels / 600W solar / 864 AHr Lithium
Victron MultiPlus Inverter / BlueSolar / ColorControlGX / BMV 702
Porsche Cayenne Diesel
Ohiobrits is offline   Reply With Quote
Old 05-03-2015, 08:53 AM   #3
Gainesville , Florida
If the trailer is hot inside it takes a long time to cool all the wood, floor and and ceiling. Peace,jim
Heat pump or heat strips? coolwhip40 Furnaces, Heaters, Fireplaces & Air Conditioning 17 05-03-2018 09:27 AM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
Heat pump and A/C combo. Good idea? adwriter73 Furnaces, Heaters, Fireplaces & Air Conditioning 11 02-10-2010 09:50 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 04:23 PM
