Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Flying Cloud > 2016 - Current Flying Cloud
Old 11-17-2015, 07:19 PM   #1
2016 30' Flying Cloud
Oviedo , Florida
Got Our 2016 30' FC Home
After ordering back in July, I finally picked up our 2016 30' Flying Cloud last week at Foley RV in Gulfport, MS. I took 16" wheels & tires up and the guys swapped them out, and also had them install the SS vent, fresh water door & outside shower. Had an uneventful tow back to Orlando and our baby is now parked under the carport with the AC's humming while we get everything loaded back into her.
Did the full monty corrosion prevention protocol (Corrosion X on rivets and seams, Nyalic brushed on all seams & a couple pinprick scratches I found then washed & waxed with Finish First sealant).
Everything was operational at delivery with a several minor fit & finish items I had corrected before leaving - mostly rough edges on laminate, a bible in a wardrobe door (swapped from another unit) and adjustment of the range top.
I discovered what appears to be a bad LPG regulator/crossover switch on the way home. Ron is having a new regulator sent to me and I'll swap it out here.
I also replaced the Atwood Premier 3000# jack with the 4000# model since I was having difficulty raising the trailer & truck high enough to get the Blue Ox bars latched. More powerful jack did the trick plus it has more travel.
I have a new charger/converter inbound from Randy so I don't cook my batteries, and I am planning on swapping out the skylights for Maxim units next year.
A few interesting things I noticed relative to older units ...
  • The skylights no longer are screwed down - they are held on only with sealant/butyl tape. I guess they had enough issues with the screws craking the plastic and leaking
  • The vacuum breaker on the sewer flush line is now a brass unit rather than plastic.
  • Everything attached to the skin (except the tailight housings) is isolated by a gasket to help prevent corrosion from abrasion.
  • The AIRSTREAM logo on the end caps is plastic letters instead of the decal-like stuff - like auto badges.
  • While the cabinate/countertop fit and finish was a bit dodgy in spots, the fit of the skin, interior metal and window frames is better than my 2005.
  • There are no longer any Thor decals on the trailer.
Ron & Blake at Foley were great to work with. I wish they were closer, but I was 100% satisfied with my decision to purchase there.
Keith & Barb
2016 Ram 2500 diesel
Southeastern Camping Unit, WBCCI #1675
khollister is offline   Reply With Quote
Old 11-18-2015, 07:55 AM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Wow..
Congrats!!! Plus a spare Bible!!
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-18-2015, 09:56 AM   #3
Luckyducks's Avatar
2018 27' Flying Cloud
Panama City Beach , Florida
Congratulations Keith! Looking forward to seeing her (and you guys too of course) at the Canopener. Russ
Russ and Linda
2018 Flying Cloud 27'
2012 F250 Powerstroke 6.7
AIR#24440 WBCCI#11740
Luckyducks is offline   Reply With Quote
Old 11-18-2015, 11:25 AM   #4
Everyday is a GIFT !!
Nelson428's Avatar
2015 30' Classic
Collins , Mississippi
Send a message via AIM to Nelson428
Congratulations on your new Baby, and personally I don't think you could have made your purchase from a better dealer. Ron is a great person and will assist you in any possible way as will the service department. I give them high marks on resolving issues.
Once again Congratulations !
J Nelson
J. Nelson
TAC # MS-12
WBCCI # 5314
AirForums # 66116
Nelson428 is offline   Reply With Quote
Old 11-18-2015, 12:38 PM   #5
Oviedo , Florida
Thanks Russ - looking forward to Canopener. Say hi to Linda for us.
Keith & Barb
Old 11-19-2015, 10:42 AM   #6
2012 25' FB Flying Cloud
Grand Rapids , Michigan
Congrats! What are you getting for a new charger/converter and are you planning on doing the install yourself? Curious because I'm thinking of swapping out mine in our 2012 for a new one. j
Jwestman is offline   Reply With Quote
Old 11-19-2015, 11:09 AM   #7
Oviedo , Florida
I have a Powermax Boondocker 60A deck mount on the way (I have a 50A trailer). I am doing the install myself.
Keith & Barb
Old 11-19-2015, 12:06 PM   #8
2003 31' Classic
Terra Alta , West Virginia
Congratulations! Maxims are a smart move.
Dave in turning colder WV
wvstreamer is offline   Reply With Quote
Old 11-19-2015, 12:09 PM   #9
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Terrific, good job!
Might as well spray the under body steel, axles, drums, step and spare tire assembly, stabilizers, various bolts and screws with CorrosionX or Boeshield T9 while you're at it. As well as spray and wipe down the shell accessories, taillights, hinges, locks, grab bar, etc with CorrosionX.
Congratulations on the new Airstream!
Doug and Cheryl
Old 11-19-2015, 01:33 PM   #10
Oviedo , Florida
Originally Posted by dkottum View Post
Terrific, good job!
Actually I did spray the stabs, steps, wheels and exposed frame/shocks with Boeshield. Got tired of typing 😀
I'm actually thinking of masking off the tail light castings and hinges and spraying them with Nyalic to seal them better. It has either been windy or rainy here, so no go on that yet. I did hit a couple suspicious looking spots with C-X in the meantime.
Keith
Keith & Barb
Old 11-19-2015, 01:39 PM   #11
dkottum's Avatar
Good to hear Keith. In four years using these products from the start we have no corrosion on or under our Airstream.
Doug and Cheryl
Old 11-19-2015, 07:08 PM   #12
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
Keith
I did that with the tail light housings and Chrome plastic rings. Done in 2012, no corrosion to date.
Howard
Howard L. is offline   Reply With Quote
Old 11-19-2015, 07:46 PM   #13
Anna Maria , Florida
Howard
Hello everyone!
I hope I am not asking a dumb question but why the corrosion protection spray? This is the first thread I read talking about it.
BTW. we have a 2013 International 30' we bought from
Foley as well. Great experience, good people.
franklyfrank is offline   Reply With Quote
Old 11-19-2015, 08:27 PM   #14
lindaebrewer's Avatar
2015 23' FB Flying Cloud
Sacramento , California
Do we need corrosion protection in the central valley of CA? No humidity & no salt air.
lindaebrewer is offline   Reply With Quote
Old 11-19-2015, 08:54 PM   #15
Oviedo , Florida
Originally Posted by franklyfrank View Post
Hello everyone!
Really? There are several threads on here about filiform corrosion and how to deal with it. It has been a pretty hot topic for a while now.
The extremely short answer is ... The aluminum panels AS uses are pre-coated. When they cut them and drill them it breaks the clear coating and offers an opportunity for filiform corrosion to start if any moisture is present.
Keith & Barb
Old 11-19-2015, 09:18 PM   #16
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Congrats on getting the new trailer home and all the preventative maintenance you have done. Look forward to looking it all over in January.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
Alphonse is offline   Reply With Quote
Old 11-19-2015, 09:22 PM   #17
Oviedo , Florida
Thanks, Al. Busy reinforcing the wardrobe shelf and floor lately - pretty dodgy design if you ask me.
Keith & Barb
Old 11-19-2015, 11:01 PM   #18
2016 30' Classic
Maitland , Florida
Congratulations on your new rig! We'll also be making a trip to Foley the week after Thanksgiving to pick up our new Classic and bringing her home to Orlando. All that stuff you did -- I guess we need to do it too...
FreshAirStmr is offline   Reply With Quote
Old 11-20-2015, 01:34 AM   #19
Sag Harbor , New York
Congratulations!
Thanks for the thorough reporting, especially on the small detail of the brass vacuum breaker. I am hoping to replace my plastic one soon, but access will require moving the FC20's rear dinette seat (as a unit which will not be too bad). Having owned a 25' AS in the 1990's, I have come to think of any travel trailer as a "full-scale model" of what we really need built.
Improvements, tweaks and adjustments are up to us.
"The devil you know is better than the one you don't know?" -- with Airstreams requiring less work to bring them up to speed than most other brands.
Sad but true IMO in our profit-oriented world.
Have fun with that great new trailer!
Old 11-20-2015, 06:11 AM   #20
Hiho Silver's Avatar
2016 27' Flying Cloud
Overland Park , Kansas
J Nelson
It seems to be unanimous, and I totally agree, everybody including the owner, at Foley will help you in any way they can. Better call Ron if you are in the market for a new Airstream.
Hiho Silver is offline   Reply With Quote
2016 AlumaFandango 9/20-25/2016 Glenritas Other Rallies & Events 14 09-26-2016 09:40 AM
2016 AlumaFandango 9/20-25/2016 Glenritas Other Rallies & Events 2 10-26-2015 04:57 PM
Just got home with our new Baby mello mike 1960 - 1964 Overlander 14 05-19-2010 09:32 AM
Just got home with our new 07 Interstate "B" alann Member Introductions 10 08-27-2007 11:04 AM
Just got home with our Argosy.... Moonshot All Argosy Trailers 18 09-14-2004 06:41 PM
