Old 09-09-2014, 10:25 AM   #71
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Get the 16" Sendel T02 or T03 sized and drilled for your Airstream. You should be able to order them.
Doug and Cheryl
Old 09-09-2014, 10:26 AM   #72
Images: 59
You can get an exact knockoff from eTrailer called "Americana".
But don't get one of the recalled lot.
Old 09-09-2014, 06:25 PM   #73
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
I ended up ordering a wheel by Allied Components #870-66060. Here is a screenshot on the spec's on it. (screenshot below)
At least my local supplier can get it for me and I need it very soon. We leave for the Albuquerque Balloon Fiesta in a couple weeks, so getting this done is sort of under a bit of a time crunch. I'm told the new tires will be in tomorrow and the wheels by the end of the week. So I should be in good shape....
Thanks everyone for your help and input on this
Cheers
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 09-09-2014, 07:14 PM   #74
Images: 59
Don't know if these are with or without the center hubs.
My Sendel wheels came without center hubs and I needed to order separately.
Best to check now before the wheels arrive.
Old 09-09-2014, 07:41 PM   #75
Arcticfox's Avatar
Central , Canada
Thanks for the heads-up on the caps! I just checked the email they sent me and the quote includes caps. So we should be good to go
Thanks again
Doug
Old 09-09-2014, 07:57 PM   #76
terryV's Avatar
2002 31' Classic
Monroe , Iowa
I have read enough here to convince me to switch to Michelins.
terryV is offline   Reply With Quote
Old 09-09-2014, 08:04 PM   #77
Arcticfox's Avatar
Central , Canada
Hi Terry:
I think its the way to go from what I read and i'm hoping I will be glad I did it.
That said, it will also be nice to stop spending $$ on the Airstream and finally get using it a little now that winter is starting to arrive....
By the way - Is there a general agreement on tire pressure that I should be running?
Doug
Old 09-09-2014, 08:16 PM   #78
Cheers
Doug
Good choice.
Old 09-09-2014, 08:27 PM   #79
dkottum's Avatar
Doug
Funny, after all the agreement on the reliability of 16" Michelins, you would ask about tire pressure, where there is general disagreement. And for good reason if the Michelins are causing a rough ride for your Airstream.
The Airstream factory placard for 16" Michelin-equipped models is 80 psi. Many say that is too much, so the question is what is too little, the point where we might get sidewall "wobble" from sway forces. Or overheating in some climates.
I'm trying 70-75 psi next long trip for our Airstream as we load it (lightly) depending on where we are. A particularly rough road may have me letting a little air out, we'll see how it goes.
Doug and Cheryl
Old 09-09-2014, 09:18 PM   #80
Arcticfox's Avatar
Central , Canada
Thanks for this Doug:
I was not aware that there was a difference of opinion on tire pressure. It will be fun to see if anyone else jumps in....
Cheers
Originally Posted by dkottum View Post
Doug
Old 09-09-2014, 09:49 PM   #81
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
I'm still glad you truck tire guys are testing the LT tires on your trailers and not mine. That said, going to 16 inch rims in order to install LTs of an "E" rating should be fine (unless you get funny and start letting to much air back out to get some sort of unknown softer ride.). Let me comment here to post #42 by 2012FB, I wouldn't run 15 inch "P" tires on my 25 footer. Remember you must drop the allowed load on those tires when used on a trailer.
If you are not going to use "D" or "E" trailer tires designed for use on a trailer, at least put "E" rated 10 ply LT tires on so you have as much excess weight carrying capacity as possible. Then if you want to soften things up a little by deflating to 65, 75 psi, you have plenty of tire capacity to spare. How much? You must get into the load/inflation chart for your tires. If you stay inflated well above that which is required for your trailer weight, you will have tires carrying much less load than they could, running cool with solid sidewalls and little sway.
Howard L. is offline   Reply With Quote
Old 09-10-2014, 06:42 AM   #82
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The reason we have gone to 16" tires as there are no appropriate tires in 15" size.
Airstream installs the 16" Michelin tires with the SenDel T03-66655T wheels on the Eddie Bauer models for load capacity and they are now standard on the 2015 31' Classic with a GVW of 10,000 pounds.
Thus the early adopters were using what Airstream was using. Since they are also installed on customer's trailers at the Airstream factory service center as an option, there will be no grounds for denial of a warranty claim for vibration or road damage if inflated to their recommended pressure.
Old 09-10-2014, 09:36 AM   #83
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
For some this may be true, but I tend to disagree. There are 15" LT tires that will work very well for even the heaviest tire loads on an Airstream.
Such as-
Pirelli Scorpion ATR LT235/75/15 LRD
Nokian Rotiiva AT LT235/75/15 116/113S (LRE)
Lance
Top is offline   Reply With Quote
Old 09-10-2014, 07:46 PM   #84
switz's Avatar
2014 31' Classic
Images: 8
Those two brands (Pirelli and Nokian) will not be in stock at the typical local tire store. At least Michelin is available nearly everywhere if a replacement is needed.
Goodyear Marathon Tires Ins. Man Tires 48 11-13-2011 06:57 AM
Goodyear Bias Ply Tires StingrayL82 Tires 10 07-29-2010 04:17 AM
Goodyear G670 RV Tires??? TRAPEZE Airstream Motorhome Forums 16 11-27-2006 03:19 PM
Goodyear G670 RV Tires??? TRAPEZE Tires 2 07-08-2002 05:38 PM
Goodyear tires available at Camping World 83Excella Tires 0 05-09-2002 08:29 AM
