Old 08-25-2014, 05:50 PM   #29
Van1's Avatar
2014 27' Flying Cloud
New Bern , North Carolina
Has anyone considered using Nitro gas in their tires instead of air. They advertise that the tires don't heat up as much as with air.
Van1 is offline   Reply With Quote
Old 08-25-2014, 06:00 PM   #30
interstateflyer's Avatar
2017 25' International
Los Osos , California
I used nitrogen in racing tires to stabilize their size and temperature for a more predictable setup.
The difficulty in Airstream touring is sourcing nitrogen along the way. You could carry a heavy nitrogen tank if it were in line with your cargo weight targets.
http://www.tirerack.com/tires/tirete...jsp?techid=191
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 08-26-2014, 05:14 AM   #31
CapriRacer
CapriRacer's Avatar
I'm in the , US
Originally Posted by r carl View Post
I hope you don't think Marathons and Michelins run the same temps.
I'm hoping that it is obvious that if the tires have different load carrying capacities, but are actually carrying the same load, the operating temperatures would be different. In other words, there are several factors at work here, not just brand.
CapriRacer is offline   Reply With Quote
Old 08-26-2014, 05:15 AM   #32
CapriRacer
CapriRacer's Avatar
I'm in the , US
An old wives tale. Nitrogen and air react very very similarly when used in tires.
Old 08-26-2014, 11:41 AM   #33
To clarify....we used Nitrogen in Sprint Kart (go cart) racing to promote a more predictable handling setup in relatively short races, 15-30 minutes at speeds up to 100 mph. The tires swell, change shape at a lower rate with Nitrogen in those conditions.
Nitrogen expands at a slower rate than compressor air by nature primarily because pure nitrogen from a pressurized tank assumedly isn't contaminated by moisture (H20). Compressed air takes on whatever moisture exits in the environment and expands more rapidly when heated.
I'm not sure that you would see a significant benefit in trailers tires in the long run especially considering the hassle in maintaining a predictable Nitrogen supply.
Old 08-26-2014, 11:54 AM   #34
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
I use nitrogen in my Airstream tires.The only benefit I have seen is less pressure fluctuation and not having to add any in 1.5 years.Who knows..........................
Old 08-26-2014, 01:05 PM   #35
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We use a mixture of 78% nitrogen and 21% oxygen and haven't lost any pressure in two years.
Doug and Cheryl
Old 08-26-2014, 01:13 PM   #36
Moflash's Avatar
To get the desired benefits for tires, nitrogen needs to be at least 93 percent pure, according to nitrogen service equipment providers quoted on Tirerack.com.
Old 08-26-2014, 04:52 PM   #37
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Good one, Doug! I've gone even further by setting myself up to breathe the same mixture for nearly 58 years, so far no blowouts!
Bob Martel
WBCCI# 5766
Old 08-27-2014, 07:38 AM   #38
Images: 59
I replaced a pair of 6 year old Marathons with Maxxis ST tires before my trip west.
1. I never had a problem with the Marathons, even though they are run at near full load capacity on a single axle Tradewind. Tire load is about 2450 lbs. Always ran 65 psi cold, although they read in the upper 70s when up to temp at 70 mph.
2. The new Maxxis have about 4000 miles on them. I keep them inflated to 75 psi. One of the wheels failed halfway across Montana and I replaced that wheel. The original wheels were filled with nitrogen, and the replacement wheel was filed with regular compressed air. I saw no difference in cold or hot pressure (up to 88 psi hot) between the nitrogen tire and air filled tire.
Your results may vary. I am a scientist and engineer so I understand that a single set of data points is not statistically valid.
Old 08-27-2014, 08:03 AM   #39
1998 30' Excella 1000
Livingston , Texas
Markdoane, I don't what you are towing, but I thought Airstreams OEM wheels might not be rated to handle those higher pressures. Did you change them out, and if so, who made the wheel that failed?
Siegmann is offline   Reply With Quote
Old 08-27-2014, 10:42 AM   #40
Images: 59
The original wheels on my '59 Tradewind were 7.00-14.5 trailer wheels, which I replaced with Dexstar steel wheels rated 75 psi.
My tire retailer said they would be alright for the Maxxis 10 ply rated tires. Turns out he was wrong. One of the wheels split (slow leak at the weld), but I noticed it right away on my TPMS sensor. I was able to make it to a Tire-O-Rama with 67 psi left in the tire.
Now I have a white spoke wheel ($39.95) on one side and a black baby moon on the other.
My new SenDel T03BMs will be here on Friday.
Old 08-27-2014, 02:39 PM   #41
Livingston , Texas
Ah, a TPMS saved the day. Nice to hear. And it was a Dexstar wheel... thanks for the info.
Old 08-31-2014, 12:47 PM   #42
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden , Colorado
One of the first things I did on our new 2012 was replace the factory tires with Michelin LTX M/S 2 P235/75R15XL. I had to remove the wheels/tires and take them into Costco to have the new Michelins mounted. I had nitrogen put in the tires and simply stop by Costco at the start of the season and have them checked. They have not lost more than a couple of pounds which is well within normal equipment error. I also had the cheap lug nuts replaced with solid chrome ones.
Why? I drive the speed limit which is more often than not over the 60mph rating. I have had two blowouts over the years with one causing a fair amount of damage that took a great deal of arguing with the insurance company to cover. I think it handles and stops better especially in the wet. It would also appear to ride softer.
I don't run monitors, measure air pressure/temps when I stop, or otherwise worry about them at all.
2012FB is offline   Reply With Quote
Goodyear Marathon Tires Ins. Man Tires 48 11-13-2011 06:57 AM
Goodyear Bias Ply Tires StingrayL82 Tires 10 07-29-2010 04:17 AM
Goodyear G670 RV Tires??? TRAPEZE Airstream Motorhome Forums 16 11-27-2006 03:19 PM
Goodyear G670 RV Tires??? TRAPEZE Tires 2 07-08-2002 05:38 PM
Goodyear tires available at Camping World 83Excella Tires 0 05-09-2002 08:29 AM
