Old 01-22-2015, 09:38 PM   #15
2015 27' Flying Cloud
maple grove , Minnesota
What about a dimmer switch for the scare light
thebreezeman is offline   Reply With Quote
Old 01-22-2015, 11:06 PM   #16
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
My bride loves the 'lighting' of the AS... once the awning is out... here comes a box of 'camp' lights.. LED's... we plug directly into the external 120v outlet and run over to the steps then to the ZipDee arm, up to the Airstream drip strip on the length of the awning... and down the other ZipDee arm..
To hold in place, I bought a box of "plastic clamps". They are colorful...and various sizes. I use the LARGE ones on the Awning arms... and the small along the awning fabric... and also small on the steps. This gives quite ample, indirect light on the underside, around the step. Then LARGE ones lights the 'head banging' ZipDee awning arms..
The nice part is that they remain on the light wires.. just squeeze to remove.. no rust or damage to the AS or ZipDee.. and coil them up in the storage box...
To go the route of 'permanently' mounting on the exterior of the AS... well, it is YOURs to do with as you please. Just remember, nothing lasts forever.... especially when exposed to the elements...
If you do route externally, you could run the FUSED wires out of the battery box vent holes using an SAE connector... which you can pull back inside the battery box hen traveling... make sure you FUSE it. You can then 'hide' the 'control' box inside the Battery box as well... and discretely run the FUSED wires out to the desired location.
Peace and Blessings..
Channing
WBCCI# 30676
2012 Edition: LED lighting upgrades Jammer Lights - Interior & Exterior 11 03-15-2012 11:36 PM
Changing LED lighting to halogen lighting dreamstreem Electrical - Systems, Generators, Batteries & Solar 14 10-12-2011 06:42 AM
Track Lighting & Lighting Ideas ClassicRides Electrical - Systems, Generators, Batteries & Solar 8 08-29-2008 02:03 PM
Interior lighting upgrades Jaxon Lights - Interior & Exterior 6 08-17-2007 10:22 PM
