Old 09-04-2016, 09:09 AM   #57
Port Carling , Ontario
http://www.propane.ca/en/about-propane/safety
this forum got me checking and it turns out i was wrong and it is LAW THAT ALL PROPANE BE TURNED OFF AND ALL PILOT LIGHTS TURNED OFF IN RVS WHILE TRAVELLING. This is for some canadian provinces. The more i look it seems it is also unsured in the province of manitoba if the propane is on. Changes my mind i will now turn off and add ice if needed
chandler7003 is offline   Reply With Quote
Old 09-04-2016, 09:58 AM   #58
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Originally Posted by rmkrum View Post
-- snip --
it's detectable at least where my nose is located
And here we have the point. Detectable and concentrated enough to be hazardous are different levels. Lots of chemicals can be detected by our sense of smell at a much lower concentration than the concentration level that is explosive or flamable.
This site below gives some insight into what areas of a gasoline service station might be hazardous with respect to fuel vapors. It is generic but provides some logic as to what might be an issue.
http://www.hsa.ie/eng/Your_Industry/...e_Stations.pdf
Travel safe. Pat
Old 09-04-2016, 11:13 AM   #59
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Good to know for when we visit Canada, thanks!
Rocinante is our 2014 International Signature 27FB
Old 09-05-2016, 07:55 PM   #60
2007 34' Classic S/O
Hillsboro , Texas
Gas on/off while travelling
I run with the gas and fridge on. Truck runs on diesel fuel. Diesel fuel is not as volatile as gasoline and does not create vapor concentrations that are explosive. Ever notice that the big trucks at truck stops don't shut off the engine when refueling. I have a Dodge Ram 3500 DRW truck that originally had a 35 gal. plastic fuel tank. It was replaced 3 yrs. ago with a Transfer Flow 60 gal. tank that mounts in the same spot as the OEM tank. The new tank is made from aluminized steel and coated on the outside with undercoating. It is mounted under the bed and inside the frame rails.
John Green, Eureka, IL
2007 34' Classic LTD S/O
2011 Dodge RAM 3500/Cummins power
WBCCI #4432 ARC member W9CJX
jwgreen is offline   Reply With Quote
Old 09-06-2016, 10:13 PM   #61
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
You do not have to turn off propane in all of Canada despite what a previous poster said. Manitoba and one of the Maritimes are the only ones requiring that last time I looked.
About five years ago I traveled across Manitoba flouting the law and the Mounties never caught me. I remain unrepentant. We did have a good time in Moose Jaw, but that is in enlightened Saskatchewan.
Gene
Gas on, gas off? heavyjumbo LP Gas, Piping, Tanks & Regulators 28 07-23-2011 07:59 AM
Need pictures of gas line for Magic Chief oven gas connection dghaas General Repair Forum 1 01-30-2009 09:04 PM
Gas or No Gas, that's the question... oldtrucksrul LP Gas, Piping, Tanks & Regulators 14 11-16-2008 10:29 AM
Locking Gas Cap for 2003 AS Gas Motorhome spat61 Land Yacht/Legacy Motorhomes 11 10-27-2008 11:37 AM
