Old 10-31-2011, 04:34 PM   #15
Splitrock's Avatar
Sioux Falls , South Dakota
An amp meter on the supply cord should read the amperage in use. At least the one I have does.
Old 10-31-2011, 04:43 PM   #16
Ottawa , ON
The old furnaces were designed to run for several minutes after the flame was extinguished in order to ensure that all exhaust gasses were expelled from the combustion chamber.
No idea if the new ones do that too. No such concept as "overhead" heating in my '74 though, so this may not be of any interest to you.
Old 11-05-2011, 04:16 PM   #17
tdmaymac's Avatar
2011 27' FB Flying Cloud
Moschelle , Nova Scotia
I think I discovered why the overhead fan unit comes on when the furnace setting is selected. There are four fan positions that are available under the FURN mode and these relate not to the furnace blower but the overhead AC unit. I noticed that mine was set to LOW and the overhead fan was running, but when I changed it to AUTO, the overhead unit shut off and didn't come back on. I think this may be the trick for avoiding cold air blowing from the overhead unit when the furnace is selected. If someone has better insight into this problem, please chime in. Thanks.
Tom
tdmaymac is offline   Reply With Quote
Old 11-05-2011, 05:13 PM   #18
lewster's Avatar
Naples, FL , Hood River, OR
Tom
First, ALL furnaces have an initial purge cycle and after running on heat cycle, the thermostat is satisfied, the gas valve closes to extinguish the LP flame and the blower continues to run to purge any LP from the burner area and to cool the unit after operation. All modern LP furnaces follow the same operational routine.
Tom,
When you toggle your CCC to furnace, is the fan setting still on? When you exit the cooling mode, your A/C fan should automatically go off and should not have any operational relevance to the furnace.
If you have a heat pump unit, the furnace will automatically commence operation in low ambient temperatures (around 40*F) when the heat pump can no longer produce interior heat. The furnace should automatically take over.
If you are getting the A/C blower when your CCC is set to furnace, you might have your dip switches on the relay board of the upper A/C unit set improperly, the unit might be mis-wired or you simply need to do a re-set of your CCC.
Check it out and get back with what you find.
Duo-therm and furnace question... NoMoSOBs Furnaces, Heaters, Fireplaces & Air Conditioning 13 10-21-2011 09:17 AM
Looking for furnace LRPorter Furnaces, Heaters, Fireplaces & Air Conditioning 4 09-29-2011 01:52 PM
Need advice on furnace. SilverRanger Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-28-2011 03:47 PM
Suburban furnace replacement for '66 Trade Wind Ben in MT Furnaces, Heaters, Fireplaces & Air Conditioning 0 05-17-2011 08:12 PM
Furnace Noise azflycaster Furnaces, Heaters, Fireplaces & Air Conditioning 12 03-06-2011 11:36 AM
