Old 04-13-2013, 11:09 AM   #1
Puyallup , Washington
Furnace Question
When I flip on the battery switch the furnace tries to light. The thermostat panel is OFF
srpuywa is offline   Reply With Quote
Old 04-13-2013, 11:41 AM   #2
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Before I got too crazy about this. This is what I would do.
It is most likely fairly cool where your are. I would turn the switch on and off a few times, set the thermostat somewhere above the ambient temperature and see if the furnace will cycle a few times. If that goes well, I would then turn the furnace off. Being warm the fan will most likely run for few minutes to cool the unit off, then shut down.
Wait a while and see if the furnace starts up again. If it does, I would look for a bad switch that is not really turning off.
That is what I would try first.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 04-13-2013, 01:44 PM   #3
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Are you sure it's the furnace, and not the water heater trying to light?
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 04-13-2013, 01:57 PM   #4
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Sounds like you using the battery disconnect switch and turning it on, then the furnace gets 12 v. and turns on. It may be the thermostat is not turning off.
The old thermostats had a tube partly filled with mercury to close a circuit and those could be adjusted. The newer ones seem to be all electronic. Turn the temp way down below ambient temp. You can remove the thermostat from the wall and disconnect the wires and the furnace should shut off; reconnect them and see what happens. If it goes on then with the temp setting below the ambient temp, the thermostat is probably faulty. It could be the switch that turns the thermostat on and off; it may be broken, dirty, or a bug has been fried in there and shorted out the switch (if so, the readout would be lit). You have a 2012, so you should still be in warranty and can get a new one.
If it stays on when the thermostat is disconnected from the wiring, someone wired the system incorrectly, but if it worked ok before, it would be hard to believe that.
There should be a several wires behind the thermostat—A/C and furnace. Mark each one and draw a diagram where each goes to make sure you reconnect them correctly.
Gene
Gene
Old 04-13-2013, 05:24 PM   #5
Is this the thermostat you have?
Products - Dometic
If it is, before the burner lights the fan will come on. Is that what is happening? If the display is off, then the furnace should not be trying to light, regardless of the mode selected.
Are you hearing the burner, without the fan? If so I'd check your water heater switch.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
Old 04-13-2013, 05:57 PM   #6
Dave, I have the Dometic, I will check and see if is the water heater
Old 04-13-2013, 07:23 PM   #7
richinny's Avatar
2011 34' Classic
if the thermostat was turned off while the furnace was in operation it might not have cycled off properly.
Ricky
Old 04-13-2013, 07:27 PM   #8
1981 31' Excella II
New Market , Alabama
Maybe it is a simple short in the thermostat cable.
Perry
Old 04-13-2013, 07:52 PM   #9
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Before the furnace try's to light, the fan will come on first. When the furnace burner shuts down, the fan will run for bit. So, what you are describing sounds more like the water heater fireing up once it receives 12v ignition power. If that's not it, then check the phone cord hook up on the back of the thermostat. If that is ok,try the other end of the hook up in the ac unit. Remove the inside cowling, get some kid with skinny fingers to ensure that the thing is plugged in at that end. That's it for me.good luck. Jim
Jim Flower is offline   Reply With Quote
Old 04-13-2013, 07:56 PM   #10
Went to the trailer this afternoon and made sure the switches were off, flipped the battery switch and - silence - no more clicking
thanks all
Old 04-14-2013, 08:31 AM   #11
Master of Universe
Gene's Avatar
It would be good if the thermostat is self repairing, but I think this may show up again. A loose wire, an intermittent short, or something else may be the underlying cause.
Gene
Gene
Old 04-14-2013, 09:08 AM   #12
mstephens's Avatar
2013 25' Flying Cloud
Cat City , California
Oddly, I had thermostat trouble on the last day of our trip - yesterday. I tried to set the MODE to "FURN - 62F degrees" and the Heat Pump would come on blowing cold air. The outside temp was 52F. I tried cycling this many times to off, and then retry. Each time the HP came on. Later today now that we are home I will investigate, but it had me stumped.
It's the newest model Dometic controller on a 2012.
mstephens is offline   Reply With Quote
Old 04-14-2013, 09:18 AM   #13
That controller is kind of finicky. Sounds like time for a reset.
From the manual
• Make sure the CCC 2 thermostat is in the OFF mode.
• Simultaneously press the MODE and ZONE buttons. The LCD will display
“IniT” and all available zones.
• Release the MODE and ZONE buttons.
• Press the ON/OFF button to exit system set up
Be advised Mode to off means that you see off in the display, not the blank display from the on/off switch.
This should fix it.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
