Old 05-21-2015, 07:06 PM   #1
wscampo's Avatar
Fresh water tank valve question
Name:	ImageUploadedByAirstream Forums1432256320.706243.jpg
2010 Flying Cloud
There are two valves on the underside of the fresh water tank cover. A picture should be attached. One of the valve handles came off in my hand. I don't know what they control or how to reinstall. Can anyone provide information?
wscampo is offline   Reply With Quote
Old 05-21-2015, 07:11 PM   #2
SteveH's Avatar
Common Sense , Texas
I think they are system drain valves, one cold, and the other hot.
Regards,
Steve
Old 05-24-2015, 05:06 AM   #3
wscampo's Avatar
Thank you. I have not been able to find them described or diagramed the parts or owners manual's and there is no leak that I can see. The valve handle has a stem with two o-rings.
Old 05-25-2015, 12:30 PM   #4
gpt
2014 25' FB Flying Cloud
sequim , Washington
low point drain valves for winterizing your trailer. one drains the fresh water tank the other the hot water tank. had a tech tell me what and where they were located as nothing in the literature describes just where they are located.
gpt is offline   Reply With Quote
Old 05-26-2015, 10:48 AM   #5
Rhino33's Avatar
1980 31' International
Cincinnati , Ohio
Does anyone know where these low point drains would be located on a 1980 31' Center Bath International? I have searched all other all of our literature and the trailer itself, but no luck.
Thanks!
Jenn & Robb & our two furry kids
Maizie ('the Black Dog') & Dex ('the Brown Dog')
1980 International 31
WBCCI #4447
AIR #70157
Rhino33 is offline   Reply With Quote
Old 05-26-2015, 11:53 AM   #6
SteveH's Avatar
Thanks!
Not exactly sure, but I do know that on the older trailers the valves were inside the trailer, usually under the kitchen sink, and located in a floor cut out.
At least, that's where they were in our '75.
Regards,
Steve
Old 05-26-2015, 09:29 PM   #7
msipek's Avatar
2012 28' Flying Cloud
Phoenix , Arizona
I was under the impression that those two valves drained the water lines not the tanks. The fresh water tank drain is the white plastic valve at the top of the picture (seen as you look between the tires) and the hot water tank drains by the white plastic plug as seen from the outside of the trailer in the lower left corner of the tank.
msipek is offline   Reply With Quote
Old 05-30-2015, 06:32 AM   #8
wscampo's Avatar
I successfully replaced the valve handle. It is not a position valve, rather a valve you have to hold open while it releases water. If you try to turn it too far it will come off. The valve handle has two rings on it and more or less pushes or snaps into place.
Old 07-02-2015, 12:03 PM   #9
2015 19' International
Snoqualmie , Washington
Had similiar issue with drain valve....
When camping last week with our 2015 bunkhouse I noticed that one of these valves was constantly dripping (even spraying as time went on). I figured out that it was a drain for the hot water lines (and would eventually stop leaking when the lines weren't charged by city pressure or pump), so I was able to effectively ignore it until I got back home.
On the way home I called our dealer, and they thought that in order to address it they would have to cut an access panel and/or tear apart the belly to get at it, and they couldn't even look at it for three weeks. Well, that wasn't soon enough for me since we will need to use the trailer before then to travel to a weeding, so I elected to try and tackle it myself.
The first thing to note about the valves on my trailer was that you cannot spin them off the fitting, as there isn't enough clearance. The lever would stop against the fresh water belly shroud once you turned the entire petcock a bit more than 1/2 way over to unthread it. I figured out that if I removed the handle held on by a hex screw, I was able to just get enough clearance (with a bit of belly scratching) to spin off the entire petcock.
Once I had the valve off the trailer, I noticed that the brass fitting itself was cracked. Given the tight clearance to spin the petcock on the exposed threads, I couldn't find a low enough profile valve at the local hardware store to replace it, so I ended up ordering one from Amazon and just putting a 1/4" brass cap on it for the time being. Now, for the first time ever, the lines hold a full pressure charge overnight - previously the pump would run every 10 mins or so quickly to keep pressure in the lines. This leads me to believe that this fitting has been cracked since we took delivery of the trailer (back in January), and has slowly gotten worse.
Yesterday I did receive the new petcock from Amazon, but as I have a working system now I'm not in a rush to reinstall it until it gets closer to winter time.
If y'all are interested in what I ended up ordering to replace it, I went with this from Amazon, which is low profile and has a removable lever if I need additional clearance to install it: http://www.amazon.com/gp/product/B00...ilpage_o01_s00
I hope this information helps others - I wasn't able to find anything helpful in the manual.
Patman is offline   Reply With Quote
Old 07-02-2015, 01:55 PM   #10
CRH
1995 25' Excella
xxxxx , xxxxxx
That's how mine is.
CRH is offline   Reply With Quote
Fresh Water Tank Drain Valve greatlakes Fresh Water Systems 28 08-09-2011 11:54 AM
Fresh water tank relief valve "bumps" above floor? DanielB Fresh Water Systems 12 01-19-2011 06:00 PM
fresh water tank plug and valve repair john hd Fresh Water Systems 40 06-01-2010 01:45 PM
drain valve on fresh water tank: '79 Argosy 6.0 campman All Argosy Trailers 7 01-26-2009 06:59 PM
Fresh water tank drain valve location? trilink3 Fresh Water Systems 8 11-04-2007 08:23 PM
