Old 02-14-2011, 09:08 PM   #1
troutbum
sldflyfish's Avatar
2010 27' FB Flying Cloud
Phoenix , Arizona
Foggy in Phoenix - 2010
My wife and I recently purchased a 2010 27'FB and are getting it ready to take out for the first time. We're having a heck of a time getting the windows clean on the outside. Is there a secret formula?
Trout bum
sldflyfish is offline   Reply With Quote
Old 02-14-2011, 09:18 PM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
No different than any other glass, I would think. The previous owner may have put some silicon grease on the surrounding rubber seals to keep the windows from sticking shut (a common problem), and it is getting on the glass as you attempt to wipe them clean?
Doug
Old 02-14-2011, 09:29 PM   #3
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Outside of the glass? Is it something more that hard water spots? Some kind of glue?
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 02-14-2011, 09:30 PM   #4
Harry W's Avatar
1978 31' Sovereign
Scottsdale , Arizona
If you are using paper towels, sometimes they have some additives that will cause streaks when you polish the glass. Try some micro fiber cloths or newspaper or some really cheap paper towels.
Harry W
4CU Charter Member
AIR # 13858, WBCCI # 2420
Harry W is offline   Reply With Quote
Old 02-14-2011, 09:36 PM   #5
Harry W's Avatar
1978 31' Sovereign
BTW - we would like to see that 2010 Airstream at Deadhorse this weekend. You can get the details in the "Upcoming Rallys" section at the bottom of the forum homepage.
Harry W
4CU Charter Member
Old 02-14-2011, 09:39 PM   #6
troutbum
sldflyfish's Avatar
Phoenix , Arizona
Thank you for the replies. The windows have hard water spots on them and Windex didn't seem to work. The windows are glass aren't they?
Old 02-14-2011, 09:46 PM   #7
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Try some vinegar. See if that works.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 02-15-2011, 01:04 PM   #8
2005 19' Safari
GLENDALE , AZ
You are correct; these are hard water spots from letting Phoenix tap water dry on the windows. It will come off eventually with repeated washings. In the future, this can be avoided by not letting tap water dry on the glass. We use Rain-X on the windows periodically, which greatly reduces streaking and spotting. Otherwise, make sure to dry them after washing with the hose, or use softened water. (If you have a water softener at your home, there may be an outside tap that provides softened water.)
Homemade window cleaner recipe (from Consumer Reports, years and years ago):
* 1/2 cup of sudsy or regular ammonia
* 1 pint of rubbing alcohol (isopropyl alcohol, exact strength is unimportant)
* A few drops of food coloring, if you want colored window cleaner liquid
* A few drops of dishwashing detergent (Dawn works great), enough to make slightly sudsy (not too much)
* Enough water to make 1 gallon of liquid, total.
This works as good as Windex, is cheap, and also disinfects.
Old 02-16-2011, 09:48 PM   #9
troutbum
sldflyfish's Avatar
Phoenix , Arizona
Thanks all. Will try again and report back.
Old 02-16-2011, 11:33 PM   #10
tpi
Trabuco Canyon , California
I'd be careful about using Lime Away or other harsh products that could start corrosion if it gets into the aluminum seams. If it were mine I'd try to polish out the spots with some fine Meguiars polish. Too bad Glass Wax is no longer on the market.
tpi is offline   Reply With Quote
Old 02-17-2011, 07:57 AM   #11
345bill's Avatar
Las Vegas , Nevada
For the inside of windshield on our MH we found a applicator at wally's that has a 'boot' that forms to the curvature, along with a small spray bottle for water, since we're both smokers this makes cleaning it quite easy.
On the outside water and crumpled up newspaper works great for washing and drying.
345bill is offline   Reply With Quote
2010 flying cloud
