Old 10-17-2013, 09:28 AM   #43
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
In reviewing the specifications of the 2012 FC 23FB that I have just purchased, I have oticed something odd. The hitch weight, as shown in the Airstream brochure for the 23FB is 467#. I have also noted that the hitch weight for the 19' is 550#, 20' is 631#, 23D is 720#, and the 25FB is 837#.
Is this a misprint in the brochure?
I also checked the Flying Cloud spec sheet on the Airstream Website, and it shows the same figures.
Brian
SuEllyn & Brian McCabe
Old 10-17-2013, 09:39 AM   #44
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I also noticed that when we bought our 25FB; I never could find a good reason. I might have preferred the 23FB from a weight standpoint but we could not live with the dinette over the wheel well, which they seem to have addressed now.
Larry
lsbrodsky is offline   Reply With Quote
Old 10-17-2013, 10:10 AM   #45
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
It's not a misprint. The low hitch weight is why we purchased our 2011 23fb International. We pack very light for mainly weekend trips, and I have checked our tw with a sherline scale: right over 500lbs with no water in tank (water heater was full).
Landrum is offline   Reply With Quote
Old 10-17-2013, 11:39 AM   #46
moosetags's Avatar
That's welcome news. That will be about half the tongue weight of our 25FB. We are really looking forward to our downsizing from our 25FB.
Old 10-17-2013, 12:34 PM   #47
moosetags's Avatar
We are planning our switch over from Old Lucy to New Lucy and have decided to empty Old Lucy out into boxes on the garage floor. Those items that we have not used in the last eight years will not be going into New Lucy.
The New Lucy is going to be a leaner, meaner traveling machine.
Brian
Old 10-17-2013, 04:52 PM   #48
1988 32' Excella
Robbinsville , New Jersey
The 23'fb is longer then the other 23' Airstreams and I believe most of that extra length is behind the axles to make room for the door behind the axles, which is why it has less tongue weight.
Old 10-17-2013, 06:35 PM   #49
2011 23' Flying Cloud
Durango , Colorado
Originally Posted by moosetags View Post
In reviewing the specifications of the 2012 FC 23FB that I have just purchased, I have oticed something odd. The hitch weight, as shown in the Airstream brochure for the 23FB is 467#. I have also noted that the hitch weight for the 19' is 550#, 20' is 631#, 23D is 720#, and the 25FB is 837#. Is this a misprint in the brochure? I also checked the Flying Cloud spec sheet on the Airstream Website, and it shows the same figures. Brian
Brian,
That published tongue weight is misleading, at least for our 2011 FC23FB.
I weighed our unit on accurate automotive scales with the following results:
Jalan Jalan Weights, lbs
Tongue 785
Right Front 1260
Left Front 1332
Front Axle 2592
Right Rear 1187
Left Rear 1109
Rear Axle 2296
Total Trailer 5673
% Tongue Weight 14%
Equalizer Hitch Assembly 91
“Hitch Weight” on Receiver 876
Normal Towing Loads
Full Fresh Tank
Empty Waste Tanks
Full Propane Tanks
Digital Scales (4)
Cheers,
Joe
Safe Travels,
Joe & Joan Donnaway
Durango, CO
JamuJoe is offline   Reply With Quote
Old 10-17-2013, 07:13 PM   #50
moosetags's Avatar
Thanks for that info, Joe. Even though your tongue weight is more than I would have expected, your gross trailer weight at 5673# is encouraging. Our 2005 25FB tips the scales at 7420#. We are looking forward to being smaller and towing less stuff around.
Brian
Old 10-18-2013, 04:15 AM   #51
2005 28' Safari
saline , Michigan
Brian , I don't think your diesel will notice the difference.
Kosm1o is offline   Reply With Quote
Old 10-18-2013, 06:48 AM   #52
moosetags's Avatar
I agree. The Duramax will probably not even notice the lighter trailer. We still have and tow with our 2005 Suburban 2500. As a matter of fact, we are now camped over in Jacksonville, and we towed Lucy over here with the Suburban. I do think that the old Suburban will definitely notice the difference when we go to the 23FB.
Brian
Old 10-18-2013, 07:23 AM   #53
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I believe most of the towing resistance on relatively level roadways is not weight, but wind. We did not notice a difference when going from 20' to 25' with a 4.7 Tundra, only on steeper grades or stiff headwind.
Doug and Cheryl
Old 10-18-2013, 07:25 AM   #54
StreamNTyme's Avatar
2007 25' Safari FB SE
Carolina Low Country , South Carolina
Images: 27
Congratulations...
That is a very nice layout!
StreamNTyme
StreamNTyme is offline   Reply With Quote
Old 10-18-2013, 09:29 AM   #55
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
With our DMAX there has not been a nickel's worth of fuel milage difference among the '05 Bambi, '07 23 Safari, or '10 25' FB Cloud. They all have the same frontal area. Our '64 Bambi II with the reduced frontal area gets us a couple more MPG.
BTW. The 23' Safari was my favorite trailer until my wife was incompacitated with a broken leg and full length brace while we were on the road. The rear double bed and bath were almost impossible to use. Hence the 25' FB.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 10-18-2013, 10:23 AM   #56
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . .I'm convinced the deal with the GYM's is 'you get a good set or you don't'. Our GYM's are '07 date code, probably installed on our S 25 in '09, & have been trouble free. zero problems. The new-to-us FC 28 also has GYM's so I'll still be reading these threads, but I'm also convinced there is NO consensus on tires on this forum, & apparently, never will be. Regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
