Old 09-24-2014, 11:01 AM   #1
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Flying Cloud 23 Tire/Wheel Changeover
About to change out the 14 inch wheels on my 09 Flying Cloud 23FB. I'm planning to go with Sendel T02 and Michelin 235/75R/15 LTX MS2.
I know a number of owners of this model have made the same change. Before I place the order, I'm hoping someone can confirm that this wheel/tire combination will fit on a 23 footer with no problems.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 09-24-2014, 02:12 PM   #2
2014 27' Flying Cloud
Seguin , Texas
Related question: when did AS switch over to 15" Marathons? We recently took delivery of 2014 FC 27' and it came with 15's
Laidback1 is offline   Reply With Quote
Old 09-24-2014, 05:59 PM   #3
Greg@AirLA's Avatar
1960 24' Tradewind
Riverside , United States
Your 27' has 12" drums, the 23' has 10" so they used a smaller tire/wheel combo.
Greg
Greg Paulsen
Greg@AirLA is offline   Reply With Quote
Old 09-24-2014, 06:33 PM   #4
interstateflyer's Avatar
2017 25' International
Los Osos , California
Greg
So the 10 inch drums won't support 15 inch wheels/tires?
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 09-24-2014, 06:36 PM   #5
TinTin's Avatar
Canmore , Alberta
I haven't heard of any problems with the 10 inch brake and 15 inch wheel combination on 23 footers.
Bob and Nancy
Old 09-24-2014, 07:28 PM   #6
Neither have I. I just put 2000 miles on the combo. They work like a charm. In fact I've had to turn down the gain on my RAM's integrated brake controller to compensate for the larger contact patch on the Michelins. I even slightly flat spotted a leading tire at 50% gain.
I suspect that A/S matched the drum/tire size to the minimum requirements of this particular GVWR on a dual axle trailer. They need to keep the MSRP down and every dollar counts.
Old 09-24-2014, 07:35 PM   #7
TinTin's Avatar
Canmore , Alberta
I've done a little reading on the subject of up-sizing tires (mostly related to cars). In general a one inch increase in diameter, given that there is room for the tire in the wheel well, is not a problem. More centrifugal force but aided by lower rotational speed ... same weight to stop.
Up-sizing more than one inch can become problematic for brakes, and require additional braking power.
Many here have up-sized their Airstream wheels/tires from 14 to 15 or from 15 to 16. Nobody has reported brake overheating or other problems.
interstateflyer: thanks!
Bob and Nancy
Old 10-09-2014, 11:45 AM   #8
2017 25' Flying Cloud
2014 23' FB Flying Cloud
2008 20' Safari
Chino Valley , Arizona
I just made the change from 14" to 15" wheels and Michelin 235/75R/15. I love the ride and handling. The only problem was the spare tire rack. I had to lower the back of the rack 3/4" on the frame for the spare tire to fit. I just drilled another hole in the tire rack 3/4" above the existing hole and reattached it to the frame.
AIRTRVL is offline   Reply With Quote
Thermostat changeover? carver 1 Electrical - Systems, Generators, Batteries & Solar 3 04-29-2014 02:18 PM
2 stage automatic/changeover lp regulator woes Roothawg LP Gas, Piping, Tanks & Regulators 7 03-17-2012 06:54 PM
Automatic Changeover Regulator 66Overlander LP Gas, Piping, Tanks & Regulators 50 10-10-2010 10:16 PM
LP Tank Remote Changeover Indicator Wayward LP Gas, Piping, Tanks & Regulators 1 09-17-2007 07:38 PM
254 Automatic Changeover Regulator Striperv LP Gas, Piping, Tanks & Regulators 11 07-26-2005 09:16 AM
