09-24-2014, 11:01 AM
2009 23' FB Flying Cloud
Canmore
, Alberta
Flying Cloud 23 Tire/Wheel Changeover
About to change out the 14 inch wheels on my 09 Flying Cloud 23FB. I'm planning to go with Sendel T02 and Michelin 235/75R/15 LTX MS2.
I know a number of owners of this model have made the same change. Before I place the order, I'm hoping someone can confirm that this wheel/tire combination will fit on a 23 footer with no problems.
09-24-2014, 02:12 PM
2014 27' Flying Cloud
Seguin
Related question: when did AS switch over to 15" Marathons? We recently took delivery of 2014 FC 27' and it came with 15's
09-24-2014, 05:59 PM
1960 24' Tradewind
Riverside
, United States
Your 27' has 12" drums, the 23' has 10" so they used a smaller tire/wheel combo.
Greg
Greg Paulsen
09-24-2014, 06:33 PM
2017 25' International
Los Osos
Greg
So the 10 inch drums won't support 15 inch wheels/tires?
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
09-24-2014, 06:36 PM
Canmore
, Alberta
I haven't heard of any problems with the 10 inch brake and 15 inch wheel combination on 23 footers.
09-24-2014, 07:28 PM
Los Osos
Neither have I. I just put 2000 miles on the combo. They work like a charm. In fact I've had to turn down the gain on my RAM's integrated brake controller to compensate for the larger contact patch on the Michelins. I even slightly flat spotted a leading tire at 50% gain.
I suspect that A/S matched the drum/tire size to the minimum requirements of this particular GVWR on a dual axle trailer. They need to keep the MSRP down and every dollar counts.
09-24-2014, 07:35 PM
Canmore
, Alberta
I've done a little reading on the subject of up-sizing tires (mostly related to cars). In general a one inch increase in diameter, given that there is room for the tire in the wheel well, is not a problem. More centrifugal force but aided by lower rotational speed ... same weight to stop.
Up-sizing more than one inch can become problematic for brakes, and require additional braking power.
Many here have up-sized their Airstream wheels/tires from 14 to 15 or from 15 to 16. Nobody has reported brake overheating or other problems.
interstateflyer: thanks!
10-09-2014, 11:45 AM
2017 25' Flying Cloud
2014 23' FB Flying Cloud
2008 20' Safari
Prescott Valley
I just made the change from 14" to 15" wheels and Michelin 235/75R/15. I love the ride and handling. The only problem was the spare tire rack. I had to lower the back of the rack 3/4" on the frame for the spare tire to fit. I just drilled another hole in the tire rack 3/4" above the existing hole and reattached it to the frame.
07-15-2018, 07:48 AM
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera
TinTin, did this combo work? We have a 2012 23D and are looking to upgrade to 15" at this time. Thanks!
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Thermostat changeover?
carver 1 |
Electrical - Systems, Generators, Batteries & Solar |
3 |
04-29-2014 02:18 PM |
2 stage automatic/changeover lp regulator woes
Roothawg |
LP Gas, Piping, Tanks & Regulators |
7 |
03-17-2012 06:54 PM |
Automatic Changeover Regulator
66Overlander |
50 |
10-10-2010 10:16 PM |
LP Tank Remote Changeover Indicator
Wayward |
1 |
09-17-2007 07:38 PM |
254 Automatic Changeover Regulator
Striperv |
11 |
07-26-2005 09:16 AM |
