Old 05-25-2015, 08:01 PM   #1
maerix's Avatar
2006 19' Safari SE
2009 28' Flying Cloud
Piedmont , Quebec
Send a message via AIM to maerix
FC 23 not same bed or trailer size ?
Hi, is there a difference between FC 23D with and without bunk bed ? The mattress seam to be larger and longer and there is a space between bed and wardrobe ?
What do you think ?Click image for larger version
Name:	ImageUploadedByAirstream Forums1432605649.656355.jpg
maerix is offline   Reply With Quote
Old 05-25-2015, 08:07 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
The bed dimensions are on the photo. It does look out of proportion to me.
MICHAEL
Old 05-25-2015, 08:18 PM   #3
2015 19' Flying Cloud
2011 23' FB International
Dayton , Ohio
That 23 bunk diagram has to be wrong. The bed is still only 48" wide since they have the exact same bath and it is still an 8' wide trailer. The may have cut and pasted that bunk bed layout from the 30' bunk model which is 6" wider.
Artvez is offline   Reply With Quote
Old 05-25-2015, 08:33 PM   #4
2015 23' Flying Cloud
Sacramento , California
Jeez, I should know this as I closely looked at both yesterday. the beds are same size. 48x75. I saw no real space between bed and wardrobe. The bottom bed turns into a cave with the the bunk overhead and the bunk is small--- good for a dog or small child. Child's head faces forward as bunk is narrow at corner end. Of course with the the bunk you lose one large window in bed area in exchange for two small portholes. I laid on bed for a few minutes and even when I stretched ( at 6'1") it was long enough. This was a major concern of mine. No space for bed side table in 23D which I don't like but will look into glue mounting a small flat surface onto bulkhead between shower and bed to hold glasses, phone, etc.
ASDreamer is offline   Reply With Quote
Old 05-25-2015, 11:47 PM   #5
Mach5's Avatar
Woodland , California
That floor-plan is not accurate (would be nice though). The below image is from this webpage on Airstream's website (use the pull-down button to find 23D Bunk):
Flying Cloud Travel Trailer Floor Plans | Airstream
Mach5 is offline   Reply With Quote
What size TT have the same size awnings LI Pets Awnings 11 07-19-2014 01:04 PM
Copper pipe and pex aren't the same size Loripep 1970 - 1973 Sovereign 7 07-18-2014 11:10 AM
How is this possible, same manf, almost same frame, diff GVWR carl2591 Tow Vehicles 7 07-15-2014 07:23 PM
Different Tongue Weights same size trailers 28' vs 27' Vitaminsea Towing, Tow Vehicles & Hitches 28 03-06-2014 07:56 AM
Different Size Rivets, Use the Same Gun? uncledan Ribs, Skins & Rivets 6 12-06-2010 09:43 PM
