Old 08-06-2014, 05:54 PM   #1
egraham's Avatar
2016 28' International
Birmingham , Alabama
Dometic refrig 2014 FC
When I left home this morning my refrig was cold and working on shore power.
I get to my campsite and refrig will not work on shore power. Seems to be working on LP.
I have checked the breaker and it looks ok ?
Any ideas
egraham is offline   Reply With Quote
Old 08-06-2014, 06:30 PM   #2
gwg
gwg's Avatar
2015 30' Classic
Glen Mills , Pennsylvania
Flip your store/ use switch?
gwg is offline   Reply With Quote
Old 08-06-2014, 06:59 PM   #3
egraham's Avatar
Thanks I will try that. Wonder how much propane the refrig uses.
Old 08-06-2014, 07:01 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
As your fridge 120VAC outlet is technically 'outside' the trailer, it should be on a GFCI. I would check those, and be sure that you have 120VAC power at the fridge outlet.
If all is good there, you might have a bad fuse at the control board of the fridge. You'll have to check your manual to see which one it is. They are under the black plastic cover that houses the control board.
Does it work on LP?
Old 08-06-2014, 07:10 PM   #5
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Re: propane - it doesn't use much in my experience.
Also - I find I sometimes have to shut it off and turn it on again after going from propane to shore power. I'm not sure why - surely user error - but try that too if your use/store switch was already in "use" mode.
Last - push the door closed. It can sometimes seem closed but it isn't fully. Push the door with your hand firmly to triple check.
Good luck!
SteveSueMac is online now   Reply With Quote
Old 08-06-2014, 07:13 PM   #6
egraham's Avatar
It is working on LP.
I checked the fuse on refrig it looks ok.
I will check the gfi
Old 08-06-2014, 07:15 PM   #7
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
We have a 2014 Sport 22FB. Our fridge does not automatically switch over from propane to shore power (or battery, for which it has an option). We have to switch it manually with the selector on the front of the fridge.
Cannonball, Deep in the Heart of Texas!
WBCCI #4387, Air #84080
Cannonball is offline   Reply With Quote
Old 08-06-2014, 07:31 PM   #8
egraham's Avatar
Flipped the used store switch and that seems to have done it!
Thanks to all
Has anyone replaced a RM100 Dometic refrig? Mrcrowley Refrigerators 0 05-24-2009 06:47 PM
Dometic Refrig Parts Offered 68Glbtrotter Refrigerators 8 12-03-2007 04:16 PM
Dometic Refrig Garages Refrigerators 1 11-16-2006 04:02 AM
Dometic Refrig Tin Hut Refrigerators 3 07-08-2005 07:00 AM
Dometic refrig trio Refrigerators 2 08-12-2003 05:11 AM
