Old 10-19-2012, 12:01 PM   #1
Terratravels's Avatar
2011 27' FB Flying Cloud
2008 16' International
Dunedin , Florida
Dometic CCC 2 Thermostat (12 button style)
Outside temp on control center reads 81 (here in FL) Inside temp reads 51. Fan runs but AC will not cycle on.
Terratravels is offline   Reply With Quote
Old 10-19-2012, 12:05 PM   #2
dznf0g's Avatar
Oswego , Illinois
I don't own one of these, but my-bro-in-law was having all sorts of weird stuff going on a couple of weeks ago. There is a reset procedure in you manual that basically "hard boots" it. Tried that, and all was well.
It appears, per dealer, that if you get confused and confuse it by starting to press buttons at random, it goes nutso. Reboot and read how to operate the functions and set programs. Follow closely. Not very user friendly till you get the hang of it.
-Rich-
Old 10-19-2012, 12:06 PM   #3
dznf0g's Avatar
Oswego , Illinois
He actually had one A/C running and one heat pump running at the same time!
-Rich-
Old 10-19-2012, 12:13 PM   #4
Dunedin , Florida
I do not have the manual. This used unit was missing a few things. I have found the
The manual online but cannot seem to find it today. Perhaps bc I am hot! I know there's a a little voo doo hoodoo that resets it.
I have not had this particular problem before.
Old 10-19-2012, 12:48 PM   #5
dznf0g's Avatar
Oswego , Illinois
Bottom of page 18 is the reset instruction. Bookmark this page and you can print out later, when you're not hot!
I think this is your model.....
http://www.dometic.com/1f24ead8-6316...87ce6bad.fodoc
-Rich-
Old 10-19-2012, 12:49 PM   #6
dznf0g's Avatar
Oswego , Illinois
Wait, that's the CCC 1. Hold on a minute I'll find it.
-Rich-
Old 10-19-2012, 12:53 PM   #7
dznf0g's Avatar
Oswego , Illinois
http://bryantrv.com/docs2/docs/opera...314150.016.pdf
http://dodgenmobiletech.com/sites/de...Roof%20Air.pdf
Page 11 of the second link has the reset procedure
-Rich-
Old 10-19-2012, 06:47 PM   #8
richinny's Avatar
2011 34' Classic
i had an issue with the connector inside the ac getting wet.
http://www.airforums.com/forums/f427...out-94680.html
Ricky
Old 10-20-2012, 05:52 AM   #9
Dunedin , Florida
The reset did not work this time. My inside temp shows 0. I guess there is a short in the thermostat. I left the unit off all night because sometimes that has helped the reset cycle. I did down load the manual to iBooks this time. :-)
Thanks!
Old 10-20-2012, 07:54 AM   #10
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
The same fix worked on my identical problem. The telephone connector simply was not plugged in correctly when the thing was built.
Jim Flower is offline   Reply With Quote
Old 10-20-2012, 08:59 AM   #11
richinny's Avatar
2011 34' Classic
mine was plugged in ok but had water in it. i had to unplug the wires, paper towel the ends and blow dry the connector with a hair drier. i made a shield for the connector with some plastic food wrap.
Ricky
Old 10-20-2012, 03:34 PM   #12
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
Good job on the fix. So much effort for such a small but significant problem. Hope others can benefit and save some time and money.
Old 10-22-2012, 06:53 AM   #13
Dunedin , Florida
After being off for 24 hours the unit reset itself.
The inside temperature gage cycled I to the negative numbers...below zero. Interesting.
I think the trick to this unit regarding high humidity is to keep the fan on high at all times when the unit is on Cool.
I have been advised to do that in the past but I had it set on automatic as we are getting chilly nights and not so hot but still very humid days.
The trick is to not build up any condensation inside the box.
My connections inside the box look high and dry so I was pleased to try the unit "one more time" before tearing it apart only to find it was reading normal temps and cycles on and off normally.
Thanks for all the advice. I'm sure this finicky little
Unit has more in store for me. I think getting the cover off and scaring it with tools works as well as anything!
