Old 12-22-2014, 05:34 PM   #1
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden , Colorado
Does good to look your new 2015 over!
Pictures speak for themselves. Toilet water feed pipe on my new 2015 30' Bunk. There is a small chaffed hole already starting at the cover sheet metal point to PEX contact point. Would you build it this way and just let it go? It does not look like I can get the covers off without removing the toilet. Very disappointed!
Name:	Toilet Water Feed 1.JPG
ID:	229071   Click image for larger version
Name:	Toilet Water Feed 2.JPG
Name:	Toilet Water Feed 3.JPG
2012FB is offline   Reply With Quote
Old 12-22-2014, 05:39 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
That is some sloppy construction, I definetly would not it let go. Can you wrap some heavy duty tape around the pipe until you can get it properly repaired? Start making a list of warrenty items. It might worth a trip to Jackson Center.
MICHAEL
Old 12-22-2014, 07:16 PM   #3
Fort Worth , Texas
I agree with you. I wouldn't do any kind of work like that to include a repair on my wooden fence. Your photos sure supports the notion that even top tier RV's don't arrive without some problems. I suppose the good news is you have an Airstream while we are still looking for an Airstream. Which means I'd rather be in your shoes than in my shoes! At any rate, best wishes this Holiday Season.
Traxless is offline   Reply With Quote
Old 12-22-2014, 07:42 PM   #4
2002 19' Bambi
Lafayette , California
I suggest using a pair of pliers to bend that corner up to a bit more than at a right angle. That will make a nicely rounded edge where the corner used to be. See the picture.
Alternately, you could cut along the same line with a pair of tin snips. The ones commonly called aircraft shears would be best.
Tim
Tim A. is offline   Reply With Quote
Old 12-22-2014, 07:53 PM   #5
Fort Worth , Texas
It looks like the right piece of the sheet metal should have been installed behind the left piece. And then the plumbing holes would be aligned. I would still attempt to place some kind of gasket or material around the PVC to help reduce movement in the future. And I certainly agree with the above post to bend that sharp corner piece as a preventive step. The retaining metal screw's position is another matter.
Old 12-22-2014, 08:07 PM   #6
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Unhappy
Yep....sure looks like those panels were installed bass-akwards, plus you have one of JC's famous 'air screws' holding them together.
Had at least 1/2 dozen on our Classic. :roll eyes:
Old 12-22-2014, 09:27 PM   #7
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
No excuse for that. Maybe you should apply for the quality inspector opening in Jackson Center.... they obviously need one.
Amazing, considering what they want for these AS's.
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 12-22-2014, 10:41 PM   #8
Free Range Human
Drathaar's Avatar
Twin Rocks , Oregon
Take it to the dealer and have it fixed on warranty. Observe the repair process.
Old 12-22-2014, 10:45 PM   #9
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Warranttteeeee! lousy build!
Peace and Blessings..
Channing
WBCCI# 30676
Old 12-22-2014, 11:13 PM   #10
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I don't think you guys are being fair to the company. The only possible reason for this sort of thing is that they don't check out the finished trailers. If that's the case, how can you blame them for not seeing it.
Ken
P.S. before anyone gets PO'ed at me, this is satire.
Old 12-22-2014, 11:15 PM   #11
Free Range Human
Drathaar's Avatar
Twin Rocks , Oregon
Originally Posted by Ag&Au View Post
I don't think you guys are being fair to the company. The only possible reason for this sort of thing is that they don't check out the finished trailers. If that's the case, how can you blame them for not seeing this sort of thing.
Ken
Nice sarcasm.
Old 12-22-2014, 11:20 PM   #12
Ag&Au's Avatar
Originally Posted by Drathaar View Post
Nice sarcasm.
Unfortunately, I'm better at that than I am with really helpful information.
I'm sure there is someone in my past that I can blame that on, though.
Ken
Old 12-23-2014, 12:00 AM   #13
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
The problem started, and should have ended, with the installer doing the work!
SeeMore is offline   Reply With Quote
Old 12-23-2014, 05:01 AM   #14
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
To me it looks like the plumbing didn't line up, maybe it has to pass through another hole we can't see. The right hand metal has an even hole drilled or stamped out. The left side looks like someone took a pair of tin snips to it so the pipe could pass through.
2012 Dodge Durango Hemi/AWD
AI 2015 steering wheel vibration at speed over 65 gambita Sprinter and B-van Forum 44 01-23-2015 02:45 PM
2015 MOUNTAIN AIR Rally April 17-20 2015 shermantic Forum Rallies & Meet Ups 2 01-13-2015 07:43 AM
Does this look like a good deal? Scott39 1972 Overlander 4 08-15-2013 02:08 AM
1972 airstream **look**look**look** eBay Watch Airstreams on eBay 0 07-03-2010 05:20 PM
OK- what does your A/S weigh & what's your tow vehicle John Our Community 17 03-19-2003 10:38 AM
