Old 05-23-2016, 11:36 PM   #1
Do I need a 2nd AC unit?
About to pull the trigger on a new FC28 twin.
Do I NEED a second AC unit with the ducted HVAC?
One more thing ... I'm in Dallas
hostage46 is offline   Reply With Quote
Old 05-24-2016, 12:16 AM   #2
2016 28' International
2010 25' FB Flying Cloud
Grand Rapids , Michigan
We went through the same decision on our 28. I can only tell you the best advise we got was its better to have it and not need then need it and not have it. This is something that cannot easily be added later like solar. We got the second unit and will wait on the solar and 16" wheels until later.
Only bad part so far with the second air-conditioning unit is the 50 amp cord is much larger / heavier. We are carrying a 25 foot 50 amp main cord and a 25 foot 30 amp extension cord with the assumption that most 50 amp hookup sites will be within 25 feet of the RV pad.
ArkFortyCal is offline   Reply With Quote
Old 05-24-2016, 04:22 AM   #3
paiceman's Avatar
Upper St Clair , Pennsylvania
This is our third AS and first with dual. Despite the pain of the 50AMP cord I don't think we would have a large AS without dual, ours is 30'. Last summer at Lake Powell in AZ it was 107 degrees in the shade, both ACs ran full time until 10:00 at night then would run off and on as the air "cooled". Actually kept the trailer very comfortable during the day and night.
Bud & Alice (Bud posts)
Abby- Black Lab-TDI Certified
Hopey-Yellow Lab-TDI Certified
2015 F350 6.7 Diesel Crew Cab
USAF - Military Training Instructor (TI) - 68-72
Old 05-24-2016, 07:21 AM   #4
Llando88's Avatar
2016 30' Flying Cloud
Need, no. Want, maybe.
If you plan to spend a lot of time in temperatures above 90, and would like the interior to be say 75 or less, a single AC is not going to work well.
2016 30' Flying Cloud / 2016 Ram 2500 Diesel 4x4
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
Llando88 is offline   Reply With Quote
Old 05-24-2016, 08:46 AM   #5
SteveH's Avatar
Common Sense , Texas
In Texas? Only if you want to be cool in the summer.
"To compel a man to subsidize with his taxes the propagation of ideas which he disbelieves and abhors is sinful and tyrannical."-- Thomas Jefferson
Old 05-24-2016, 10:39 AM   #6
2015 30' Classic
Newport , Pennsylvania
Do O need a 2nd AC unit
not a serious expense when building a new trailer and adding one later will be a night mare
EarlM is offline   Reply With Quote
Old 05-24-2016, 10:54 AM   #7
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Yes, you need a second a/c unit!
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
m.hony is online now   Reply With Quote
Old 05-24-2016, 10:55 AM   #8
extiger's Avatar
2011 30' Classic
Kingwood , Texas
In Texas with the summer heat, the bedroom AC is very welcome. Yes the cord is heavier, but that has not been an issue with me. For me the 2nd AC unit is a must on the 27/30 footers at least as long as I live in this climate.
2011 30' Classic
2015 Ford F250 4X4 Platinum
ProPride Hitch
extiger is offline   Reply With Quote
Old 05-24-2016, 01:34 PM   #9
2011 30' Flying Cloud
Arvada , Colorado
As touched on here, it really comes down to where you camp and when. We just moved from the mid-Atlantic region and found that we used the second unit seldom. But, when we needed it it was great to have. When you are not going to use both heat pumps at the same time, you can work around the monster 50 amp cord by buying the 30 amp cord with the 50 amp female connector that Camping World carries. We use that cord most of the time and it is much easier to handle. Good luck!
Jack46 is offline   Reply With Quote
Old 05-24-2016, 03:07 PM   #10
80Ram's Avatar
2017 25' Flying Cloud
Scott City , Missouri
2nd AC
Hi, I basically asked the same question here on air forums and received a good response that two AC's is better than one. However, I called Airstream and asked them if they recommended two AC units for certain AS lengths. Their response was that the 2 AC units are zoned and that they are designed to keep the AS with in 20 degrees of the outside temp. ( 90 degrees outside 70 degrees inside) Reading between the lines here, I take it that with two AC units it would be easier to keep that 20 degree difference just don't go looking to be at 65 degrees when it's 100 degrees outside. Probably best to call them yourself and ask but that's what I got out of it.
80Ram is offline   Reply With Quote
Old 05-24-2016, 05:13 PM   #11
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
My experience. I owned a 2012 28' Intl CCD. I ordered it with one A/C as I was told it would be adequate. It wasn't. This resulted in adding the 2d A/C later. I had it done at the factory, and the only upside was that it had its own external receptacle. So, if I wanted to use that unit, I had a 2d 30 amp cord. Not a real problem....I had a 50 amp pigtail that I plugged into a 50amp pedestal...there were two 30amp plug-ins on it so if I wanted to use the 2d A/C -- e.g., I was in Texas (!), I used two cables. Otherwise, just one 30 amp for the main 120V circuit. I now have a 50amp trailer, and the incredibly thick cord is a bear to deal with. Especially when it's cold! Just bite the bullet and order the trailer with 2 A/C's.
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 05-24-2016, 05:22 PM   #12
2012 30' International
Dallas , Texas
Yes. Like you, we live in Dallas, and we often travel to climes that are as hot or hotter than home. I don't believe that you would be sorry with two. We haven't been.
russingr is offline   Reply With Quote
Old 05-24-2016, 05:47 PM   #13
2013 31' Classic
billings , Montana
If only using 1 Ac , you might purchase a a 30 to 50 amp cord, mine is blue so it is very flexible when it is cold.....
Old 05-24-2016, 08:35 PM   #14
Greenback , Tennessee
If you are in Texas or in the southeast, you will be glad you have two air conditioners. Our first AS was a Safari 25 with one AC and we struggled mightily to keep it cool. On our trips west, we kept aluminized bubble wrap in the windows until we got to the Rockies. That helped some, but it was still hard to cool down the trailer at the end of the day. With our FC 30, with two ACs, we are able to keep things comfortable. After cool-down, we usually sleep with the bedroom AC off, since it is quieter. When we don't need both ACs, we use a 30-amp cord, which is lighter and much easier to handle.
I don't think you will be sorry if you order the two ACs.
Gneiss Guy is offline   Reply With Quote
Need info on adding 2nd A/C Davis Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-23-2011 08:07 PM
Questions re: installing 2nd ac unit in rear of 34' Excella ciquing Furnaces, Heaters, Fireplaces & Air Conditioning 8 08-16-2010 12:14 PM
Adding 2nd AC Unit in the bedroom? TxToaster Furnaces, Heaters, Fireplaces & Air Conditioning 4 06-12-2009 06:31 PM
Florida Unit 2nd VP SilverCabin WBCCI Forum 4 12-13-2007 10:16 PM
Leaking fuel tank in MH...need 2nd opinion. Astrodokk Mechanics Corner - Engines, Transmission & More... 5 01-07-2005 09:51 PM
Copyright 2002-2015 Social Knowledge, LLC All Rights Reserved.
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
